Re: Renault Duster : Official Review Update: my brakes failed catastrophically on Friday despite regular maintenance & I am upset by Renault/ Dealer's nonchalant response to it.
Basically, I was parking the Duster in the basement garage & the brakes just went limp. The rear LHS drum cylinder gasket had failed and all the brake fluid just dumped on the floor. Luckily, I was able to stop the car from hitting the Crysta parked already. I got the car out of the garage & parked with a bit of trouble as I did not want the Crysta blocked.
I called Renault Roadside Assistance & got the car towed to the Silk Board Trident Renault dealership on Saturday
Since I had taken the 80k - 4 year extended warranty, the car was towed at the company's expense. The service manager there, Santosh, assured me that he will take care of it. He called me back & told me that the problem was with the drum cylinder and also assured me that it would be fixed under warranty. The car was fixed by Monday and I went to pick it up
So far so good. I was quite happy with the dealer's approach & responsiveness.
What I am upset about is how come the brake failed when I had serviced the car promptly according to the recommended service intervals. Something as fundamental as brakes have no business failing when the car has been serviced.
This is basic issue. The SA compounded my frustration with his answers & evasion:
- When I asked him the same question, he said the rubber gasket in the drum cylinder fails in 40k kms. I asked him why then it was not replaced, he callously said "There was no complaint and hence we did not replace it." He also claimed that there is no way to check that part of the brake system without a tear down. I have replaced the front brake pads twice and the rotors once until now. In all that time, I am shocked that they could not check this.
- There was no answer forthcoming when I asked why it was not replaced for 35k kms after its design life.Note that they had never suggested that the cylinder was up for replacement in the 75k I have driven it.
- Even now, only one cylinder has been replaced. The RHS cyclinder is stock.
- I asked for a report on what failed in the brake system as is my right. He said there is no report & refused to give it. When I pressed, he said he will ask his supervisor & revert, thereby increasing my frustration.
- He asked me to pay 500. When I asked him why I should pay for a warranty repair, he said only parts are covered and labour is not. When I refused to pay, he came back with "It is for the clutch bleeding, sir" (I had asked for the clutch to be checked). I told him that I believed that he was lying and asked him if the clutch was fine. He replied that it is fine. I paid the amount
- 2 months & 2000 km ago, I had sent the car to the same service centre because the clutch pedal went limp & started working after I pumped it a few times. At that time the SA (Different person) told me that the entire clutch & the master cylinder has to be replaced for around 30k. Now, this guy is telling me the clutch is fine. I believe he has swindled me of the money and not checked the clutch at all. The clutch is 75k km old & due for replacement.
- They do not have the drum brake shoes in stock & have given back the car to me with the same old shoes saying "it will run another 1500-2000 km. We will call you once we get the parts in stock". I am grateful to them for turning it around but am not entirely sure that it was the safe thing to do.
I called the Roadside Assistance number and have made a formal complaint to Renault ( a person called Hema called me back). I am not sure what action will be taken. No one has either apologized to me for the failure nor does anybody seem to understand what a close shave it was.
Net result, I have lost confidence in the car & the way Renault specifies it be maintained. I was just lucky that the brake failed when I was at low speed & when I had the presence of mind to handle it. Just 30 minutes earlier the entire family had gone visiting relatives & I get nightmares thinking what would have happened if the brakes had failed at that time.
I will probably sell the car & go back to either Maruti or Honda.
