*Added to the Engine Post on the 1st page*
Other changes to the review:
- Picture of the lower variant's steel wheel added.
- A better picture of the 3rd row seat has been added.
84 BHP Diesel Engine:
The Duster 85 variant churns out 84 BHP (@ 3,750 rpm) and 200 Nm of max torque (@ 1,900 rpm). It runs nearly the same tune as the Sunny’s version of this engine. The two main differences are that the Duster makes 1 BHP less and max torque at a 100 rpm lower than the Nissan. Compared to the more expensive 110 variant, the Duster 85 has 25 BHP & 48 Nm of torque less. Is the Duster 85 underpowered then? Not at all. It's power / weight and torque / weight ratios are still superior to the Scorpio, Safari and Innova – thanks to a lighter kerb weight. Further, the power ratios are about the same as the Maruti Ertiga, and within 10% of the more expensive Mahindra XUV500 and Skoda Yeti.
As expected, the Duster 85’s USP is the outstanding in-city driveability on tap. Turbo lag is too negligible to mention, with the engine feeling immensely tractable. While the Duster 110 only really wakes up after 2,000 – 2,200 rpm, the Duster 85 pulls clean from as low as 1,200 rpm. The engine behaves like a naturally-aspirated diesel! Translated, you’ll seldom need to downshift within the city. The Duster 85 passes the 2nd gear speed-breaker test with flying colours; it is even possible to drive away from 0 kph in 2nd gear, with just a little clutch slip. BHPian
Parrys didn’t face any problem in climbing city flyovers in 5th gear itself. In traffic that the Duster 110 would require frequent downshifts, the 85 happily rolls along in the same gear. You can use the versatile 2nd or 3rd gear (choice dependent on traffic speed) just like an automatic. With liberal usage of the accelerator pedal, the Duster 85 is reasonably peppy in the city. That said, it somehow doesn’t sprint as fast as the Sunny Diesel.
Power delivery is fairly linear, but the 110’s mid-range punch (and initial torque steer
) is missing. The 110’s highway performance is noticeably superior. With the 110, you have a decent amount of reserve power in most highway conditions; this isn’t the case with the 85. Don’t get me wrong, the Duster 85 isn’t under-powered. Performance is completely satisfactory up to 120 – 130 kph, only after which power delivery starts tapering off. The engine doesn’t enjoy spinning over 4,000 rpm either. Since the motor runs out of breath sooner, the 85 is best suited to a sedate driving style on the expressway...the same conditions where its more powerful sibling runs like a horse. Anything that the 85 does on the open road, the 110 does better (
as long as the needle is hovering over 2,000 rpm). With a full load of 5 occupants and luggage onboard, the difference between the two will be even more. The Duster 85 gets a 5 speed gearbox (unlike the 110’s 6 speed) and therefore, 100 kph cruising comes at a higher 2,400 rpm. On tight & twisty ghat sections, there isn’t a doubt that the Duster 85 will perform better, simply because you don’t have to contend with turbo lag. Remember my comparison between the Innova & Duster 110 on the Munnar incline? The Duster 85 would easily do that climb in 2nd gear as well.
Just like the Duster 110, the 85’s clutch also requires a certain amount of effort to operate. It seems to have a slightly shorter throw and isn't as aggressive as that of the 110. Nevertheless, the 85’s clutch isn’t what I'd call a light & easy clutch at all. I found the Duster 85’s NVH levels to be excellent overall. However, just like the 110, wind noise is quite noticeable at 80 – 100 kph. Overall, if there is any difference from the 110 variant in terms of NVH, it's not much. As a result of having lesser power though, the 85 has to work harder (higher rpm) than the 110 on the highway and thus, sounds louder at the same speed.
Overall, does the Duster 85 do the job? You bet. Power delivery is adequate, even if it lacks the muscle of the 110. If you drive primarily within a congested Indian city, the Duster 85 is the more sensible choice. It’s cheaper and more fuel efficient too! This is sort of off-topic, yet worth a mention : The power steering of our 600 kms run Duster 85 had gone bust.
