Old 23rd December 2013, 15:20   #3466
acroback's Avatar
Thanked: 127 Times
Re: Renault Duster : Official Review
Heads up folks.
If your Duster has spongy brakes like mine, get to service center and ask for brake bleeding.
Do not listen to BS they give you back no matter what on reasons of sponginess.
I asked my SA to get bleeding done properly and now brakes are a world apart from spongy spongebob I lived with for 1 year.
Also this bleeding was done after new front brake pads, but I believe it is irrespective of brakes' age.
acroback is offline   (1) Thanks
Old 25th December 2013, 18:58   #3467
rajamuneeb's Avatar
Thanked: 160 Times
Hi. Just noticed on the Duster website that in 110 ps they are offering two models RxZ Option and RxZ Plus for 12.34L and 12.29L Ex Showroom prices respectively. But in terms of features both are equally loaded. Wonder what the difference in models is then? Can someone please update on this as on their website i couldn't find any.
rajamuneeb is offline
Old 25th December 2013, 20:10   #3468
AshwinThekkan's Avatar
Thanked: 236 Times
Duster 110 ps Rxz Option pack have rear A/C with independent blower control.
AshwinThekkan is offline
Old 25th December 2013, 20:33   #3469
rajamuneeb's Avatar
Thanked: 160 Times
Thank you. Thats a very minor variation dont understand why Renault has to make two models with such a small variation.
Old 25th December 2013, 20:38   #3470
ampere's Avatar
Thanked: 13,297 Times
To start with they had just one. viz the RXZ. The rear blower was a big let down for many. But still people wanted rest of the comforts of the RXZ. I think that is why Renault corrected it by taking out the blower for RXZ and providing as an option.
ampere is offline
Old 25th December 2013, 21:09   #3471
KPS
KPS's Avatar
Thanked: 11,644 Times
I was visiting my relative who has a Duster 110PS which has done 38K. He is having severe inner tread wear on the front wheels. This was first noticed at 10K. Since then all bearing have changed under warranty, however the front tyres continue to have inner tread wear. I inspected the tyres and noticed that the wear is not even but very irregular, which would normally indicate a bearing fault. However, as stated before the bearing have been changed.
Has anyone faced a similar problem?
KPS
KPS is offline
Old 26th December 2013, 10:02   #3472
ahmad.007's Avatar
Thanked: 97 Times
KPS
Do get the alignment and wheel balancing done. I don't know about this, but can the camber angle be adjusted?
ahmad.007 is offline
Old 26th December 2013, 10:27   #3473
arjab's Avatar
Thanked: 5,849 Times
Symptoms indicate vehicle is running acute negative camber, thus sending the scrub radius for a toss which in turn is eating up the tyres.
If you remember this was a common thing in the original Tata Sumo's as well.
As the Duster has struts in front - and the camber angle for struts is fixed, get the front suspension's lower arms checked for integrity. Also the steering knuckle assembly (specially where the tie rod/ball joint ends are meeting up with the knuckle assembly.
I don't know whether your friend is running stock rims or any fatty rim upgrades - if that is the case, then the excessive rim width sometimes plays truant with the toe settings to cause premature wear.
PS: Also get the strut bearings checked and the strut itself. sometimes strut bearings develop slack causing some lateral play causing the struts itself to shift laterally when the vehicle is running.
arjab is offline   (2) Thanks
Old 26th December 2013, 23:09   #3474
acroback's Avatar
Thanked: 127 Times
My vehicle has done ~21000 kms and wear on all 4 tyres is very even and without any issues. I got wheels rotated and balanced at each 10K mark.
Looking at more and more posts about uneven wear on tyres, I am planning to continue this ritual at every 6K from now on, just to be on the safer side.
acroback is offline
Old 26th December 2013, 23:34   #3475
Thanked: 518 Times
Apologies if already discussed in this thread. But searching for the information is difficult. My Duster is due for its first 10k service. Would appreciate help with critical things to do.
- Brake bleeding
- Change to synthetic oil. Any specific brand?
- Wheel rotation, alignment, balancing
- Air filter change
Anything else? Thanks !
desidino is offline
Old 27th December 2013, 16:46   #3476
acroback's Avatar
Thanked: 127 Times
- Brake bleeding
- Air filter change
Air Filter change? I think cleaning would be just fine. Mine was cleaned up at 10K and changed only at 20K mark.
Get Oil filter changed.
No need to switch to synthetic right now. Anyway, Renault uses ELF mineral Oil.
Rest you have got it covered.
HTH
Old 29th December 2013, 16:48   #3477
vskesavan's Avatar
Thanked: 25 Times
- Brake bleeding
- Air filter change
At my 10000km service I am told that wheel alignment and balancing are not necessary for alloy wheels by service people and they did not do it. But, after that service, when I took a long journey, from Chennai to Erode, the steering wheel got severe vibration between 120 and 140 kmph speed. Hence, after I reached Erode, I did wheel balancing and alignment at MRF authorised tyre store. Now, I felt the change in driving, which turned to very smooth. As well as the vibration in steering wheel is also gone. So, in my opinion wheel balancing and alignment must be done periodically.
vskesavan is offline   (1) Thanks
Old 2nd January 2014, 09:15   #3478
jaisha8's Avatar
Thanked: 201 Times
I have booked a Duster 85 RxL and waiting for the loan processing from SBI. Is it true that there is a price hike from Jan 2014 for Duster as informed by my Sales Advisor.
I am presently abroad and they are calling home frequently saying that if the car is not invoiced before 5th Jan, the booking would cancel and the new prices would prevail.
Please confirm if this is true?
jaisha8 is offline
Old 2nd January 2014, 11:08   #3479
RideRanger's Avatar
Thanked: 84 Times
Hai everyone, this is my third post, just made it to Team-BHP last week. Congratulations on all the Duster owners.
I found a video review sometime back that the high wind noise in Duster is caused by roof rails (Sorry I can't find the link again). Can anyone confirm the same? If so is it possible to modify or fit an alternate roof rail?
I've been looking between Ecosport and Duster for sometime. I have very less monthly running. Is petrol duster competent enough? Found Ecosport ecoboost very good. Didn't get to drive petrol Duster though.
RideRanger is offline
Old 2nd January 2014, 11:19   #3480
ahmad.007's Avatar
Thanked: 97 Times
Petrol Duster is just about average. And so is the petrol Ecosport. Even if your running is low, you can still look for the diesel ecosport, as the ecoboost is slightly costlier than the diesel, upsetting any advantage of the turbo petrol. If you are a petrol enthusiast, go for Ecoboost anyways (Cheaper than the Duster alternative). Or if you like duster more, then better ger the 85 ps version, the petrol will leave you with much to desire. Atlast you can also go with Duster petrol, not a bad car if you are not looking at performance. In the end the decision is yours.
ahmad.007 is offline   (1) Thanks
