Old 3rd May 2017, 17:03   #2656
anuragn's Avatar
Thanked: 51 Times
Re: Skoda Rapid : Test Drive & Review
Originally Posted by motorworks View Post
I think Skoda and VW haven't rolled out the emission update for 1.6 TDI in India as of now. It's only the 1.5 Tdi which is receiving the update, please correct me if I'm wrong.
I confirm that Skoda has rolled out the emission update for 1.6TDI. I got my car updated when I gave it for warranty repair job last Friday (i.e. 28th April 2017).
The electric motor which unlocks/opens the boot went kaput and the boot lid was not opening by using remote or the switch. I was able to open the boot only by inserting the key. Got it replaced under extended warranty.
anuragn is offline
Old 3rd May 2017, 22:25   #2657
Thanked: 268 Times
Service update:
The car is in the workshop ready for delivery. Will pick it up tomorrow.
The following has been done:
Paid service.
Break discs and pads replaced.
Rear suspension bushes replaced
Timing kit replaced.
Total bill Rs. 33,600.
Yet to be done:
Battery is flat. Will get it replaced with amaron, since skoda was expensive.
deepfusion is offline
Old 9th May 2017, 19:06   #2658
500ContyCruiser's Avatar
Thanked: 771 Times
Took my car for Summer (Heat) Campaign. Wherein they do some 15 point AC checks.
And received this kit for free.
Skoda Rapid : Test Drive & Review-img_3091.jpg
500ContyCruiser is offline   (2) Thanks
Old 11th May 2017, 16:02   #2659
narsi_6989's Avatar
Thanked: 237 Times
I had a chance to drive my Rapid after a log time today. Since I got a new Kwid in Jan for my use in Bangalore, my Rapid is doing its duty in Chennai and I do not get a chance to use it often. I noticed today that both the center AC vents is not as powerful as the corner ones. I could feel the difference as soon as I started driving and stopped to check if I had missed any settings/the vent is closed. But no, the vents were fully open but the air coming out was not strong enough as it used to be. Has anyone faced similar issue? Or am I missing something here, like it is designed like that I have never noticed.
PS: Mine is 2014 Rapid Elegance with ACC
narsi_6989 is offline
Old 13th May 2017, 23:28   #2660
motorworks's Avatar
Thanked: 4,340 Times
Facing a weird issue. This evening when I was coming back from a long drive, noticed wetness on top of the dashboard when the AC was on. I switched off the AC and tried it on again after sometime and noticed water marks again. Any one experienced something like this ever before?
Another point, not sure if it's relevant, but the Windows were open when this incident happened.
motorworks is offline
Old 14th May 2017, 14:25   #2661
motorworks's Avatar
I think this issue might have primarily been due to the Windows being left open. Checking it again today and tomorrow with the windows closed.
I had to Keep the windows open since my kid was with me and he usually feels a little uncomfortable when there is no fresh air in the car. At the same time couldn't avoid turning on the AC since it was quite humid.
Old 15th May 2017, 01:50   #2662
karansm4u's Avatar
Thanked: 93 Times
Yes, dont worry about water on dashboard. I have seen it sometime on my car as well and main reason is open window, humid environment.
It was 7-8 months ago and everything working fine as usual.
karansm4u is offline
Old 15th May 2017, 07:14   #2663
drpullockaran's Avatar
Thanked: 388 Times
Originally Posted by halfbytecode View Post
Even in some VW 1.6 TDI owner's manuals, it is indicated at 120,000 kilometers. However, in the service centers it is now mentioned that it is 90,000 kilometers or 5 years, whatever is earlier.
Change the ribbed serpentine belt at the interval mentioned by the service center and the entire kit which includes the idler bearing and the tensioner bearing at 1,80,000 km. This is under the premise that you do not drive the diesel with pedal to the metal mode most of the time. If the car is used 90% of the time in the city then only does the kit need to be changed as a whole. It is regular rpm variation and contaminants that kill the belt and rpm variations alone that kills the needle bearings.
The needle bearings usually last one belt change in most cars including the skoda.
Originally Posted by deepfusion View Post
One thing he was insist ING on was the timing kit replacement.
Get the belt changed and not the entire kit which includes the bearing. The bearing will last 1,80,000 km.
Last edited by Gannu_1 : 16th May 2017 at 12:59. Reason: Back to back posts merged.
drpullockaran is offline
Old 15th May 2017, 10:15   #2664
Thanked: 268 Times
I have the whole kit replaced. Both the bearings have been replaced.
Old 16th May 2017, 12:22   #2665
Horizon81's Avatar
Thanked: 264 Times
Originally Posted by narsi_6989 View Post
--SNIP-- I noticed today that both the center AC vents is not as powerful as the corner ones. I could feel the difference as soon as I started driving and stopped to check if I had missed any settings/the vent is closed. But no, the vents were fully open but the air coming out was not strong enough as it used to be. Has anyone faced similar issue? Or am I missing something here, like it is designed like that I have never noticed.
Had this issue in my Rapid. If I remember correctly, there was a 'flange motor' that went bad. Got it replaced under warranty.
Horizon81 is offline   (1) Thanks
Old 17th May 2017, 07:32   #2666
Thanked: 366 Times
Usually, the driving patterns change over time and more so if multiple people drive a particular car. We are talking 1,80,000 kms.
Going by that, the needle bearings may need to be replaced any time between 90,000 kms and 1,80,000 kms. Provided a car does have some life left in the needle bearings at 90,000 kms, you are on your own to regularly inspect them and hope they do not fail.
The service center guys will not do the inspection of the needle bearings, at every oil change. To each his own, I had the entire kit, belts and tensioner changed at 84,000 kms/5 years mark.
halfbytecode is offline   (1) Thanks
Old 17th May 2017, 18:14   #2667
Thanked: 388 Times
I made an error in the figures. The needle bearings (IKN Brand) in most cars are manufactured to last 1,60,000km. They will start whining by 1,63,000km. The figures are not 1,80,000km. The fraying of the serpentine belt will start by 85,000km when looked at through a magnifying glass. Belt breakage will result in loss of power-steering and alternator function.
The timing belt is another matter all together and I would take the advice of the service engineers to the tee as its breakage will result in catastrophic damage to the valve assembly and possibly cam shaft too if at high rpm.
Old 17th May 2017, 21:50   #2668
Thanked: 366 Times
It really varies for everyone. In my car, the serpentine belt was full of cracks, clearly visible to naked eye, at 84,000 kms. It was about to break.
The needle bearings would be affected way earlier, as you mentioned depending upon the usage profile.
Old 24th June 2017, 11:31   #2669
Thanked: 771 Times
Anyone recently got software updated on Rapid? I think there is some new update related to emission for 1.6TDI.
If anyone has, wanted to check car performance post update.
Old 24th June 2017, 14:34   #2670
narsi_6989's Avatar
Thanked: 237 Times
A separate thread is already started to discuss the update and a poll added to it as well. Here you go - http://www.team-bhp.com/forum/showthread.php?t=187880
To answer your question, I got my 2014 Rapid 1.6TDI updated and the pick up is more linear now. The 'pinning to the seat' when you hit the sweep spot is missing
narsi_6989 is offline   (1) Thanks
