Old 26th April 2016, 20:48   #2506
graaja's Avatar
Thanked: 25,620 Times
Re: Volkswagen Jetta : Test Drive & Review
Originally Posted by Chethan B G View Post
Eagerly awaiting your feedback on this.
Mud flaps fixed. Got them from the below AliExpress link. Cost INR 1,050/-
Jetta Mudflaps
They are a perfect fit with the holes matching the ones on the Jetta wheel well. They are a little soft as well and if hit by speed breakers, will flex without breaking.
Volkswagen Jetta : Test Drive & Review-mudflap-rear.jpg
Volkswagen Jetta : Test Drive & Review-mudflap-front.jpg
graaja is offline   (6) Thanks
Old 27th April 2016, 11:01   #2507
bharat4ever's Avatar
Thanked: 608 Times
graaja, where did you get them installed?
Also, there's a candy white MK6 pre-facelift Jetta in HSR layout, Bangalore. Is it anyone on here?
bharat4ever is offline
Old 27th April 2016, 11:31   #2508
graaja's Avatar
Hi bharat4ever,
The 3M guys installed the mudflaps when I had left the car for exterior and interior treatment. I have described this experience in the below post in my ownership thread.
Mudflaps Installed
If you have a wrench set with torx bit, this can be a 10 minute DIY. As I did not have torx bits in my wrench, had to get it done outside.
graaja is offline   (1) Thanks
Old 27th April 2016, 11:43   #2509
Thanked: 608 Times
Hi bharat4ever,
Mudflaps Installed
I'm looking for a place to install aluminium pedals. Would the 3M guys do this as well?
Anyone in Bangalore near HSR can advice?
Old 27th April 2016, 12:06   #2510
graaja's Avatar
Not sure if 3M guys would do the installation because they may not have the tools. In my case, the 3M guys happened to have the wrench set and did this as a courtesy.
I would suggest find a good garage and get it done.
On a side note, isn't installing the aluminium pedals a simple DIY job?
graaja is offline
Old 27th April 2016, 12:08   #2511
Thanked: 608 Times
Not for me. I checked out a few videos on youtube, and for the accelerator pedal, they take out the entire unit... I'm a bit scared to do it.
Software on the other hand, I can manage.
bharat4ever is offline   (1) Thanks
Old 27th April 2016, 19:43   #2512
ethanhunt123's Avatar
Thanked: 1,035 Times
My first 6 month check-up is due in a week. Any advice ? This is going to be a simple inspection service right with liquid topups ? I can only see one small issue with my car - the co-passenger side window makes a slight screeching sound when being wound up.
ethanhunt123 is offline
Old 28th April 2016, 00:50   #2513
iliketurtles's Avatar
Thanked: 4,996 Times
Indeed. It shouldn't cost you a paisa. They'll just lubricate that window and the screechy sound should vanish too. Don't let them sell you anything unnecessary by way of services
iliketurtles is offline   (1) Thanks
Old 28th April 2016, 08:40   #2514
sunsbhp's Avatar
Thanked: 111 Times
Not for me. I checked out a few videos on Youtube, and for the accelerator pedal, they take out the entire unit... I'm a bit scared to do it.
Hi Bharat, I think that was just for demo purpose they used a brand-new accelerator pedal assembly. There're some comments also below where someone tried fixing it without removing the assembly. Not sure how eas its going to be to fix that steel-plate over the pedal. A screw-on type would have been much easier, like in some other car-brands.
Btw, where did you get the steel-pedals ? Am also looking for a good one.
sunsbhp is offline
Old 28th April 2016, 09:31   #2515
Thanked: 608 Times
Ok, I will attempt it today or tomorrow <gulp>.
I got this from aliexpress on the recommendation of people here.
http://www.aliexpress.com/item/RHD-O...274869174.html
Also, what tire pressure do you guys maintain? I tried 32 psi, somehow felt sluggish, 34, again felt sluggish, now at 36, and it feels bouncy.
The Jetta's fuel tank lid recommends 36 for 1-2 persons, and 44 for full load.
I also fear that at 32-33 the fuel efficiency will take a hit. No?
Old 28th April 2016, 09:42   #2516
VW2010's Avatar
Thanked: 4,556 Times
@bharat4ever,
The air pressure changes between 3-5 PSI from early morning to actually on the road. So if you are talking about early morning PSI i would recommend around 33-34. This will reach all the way up to 38PSI.
How do i know, i have this TPMS that i picked up few weeks back and its such a wonderful feature to look at your tyre pressure.
In fact its so easy that i usually just screw the TPMS BT module into the air valve to take measurement and remove it. Its a 2 second job and a peace of mind that you dont have to worry about someone stealing it.
I am sticking to 33 or 34 early in the morning tyre air pressure.
VW2010 is offline   (1) Thanks
Old 28th April 2016, 12:29   #2517
Thanked: 608 Times
Originally Posted by VW2010 View Post
@bharat4ever,
Alright, I'll change the pressure to 33 and ride around a bit to see how the car feels. Can you please link me to the TPMS module? Aliexpress?
Also, has anyone with a Halogen headlamp unit changed their halogen DRLs to LEDs? Will this work? Can I please see a photo to see how intense the beam is?
Old 28th April 2016, 16:54   #2518
Thanked: 3,036 Times
*SNIP*
Huh? My 2015 Jetta TDI Highline DSG has 35 and 39 in the fuel tank lid as the recommended pressures. Yours says 36 and 44?????
This is weird.
Or does it depend on the trim level (and therefore probably the weight?) of the car? Apologies if that was a stupid question.
tilt is offline
Old 28th April 2016, 17:36   #2519
graaja's Avatar
This is weird.
Here is the tire pressure recommendation on my 2014 Jetta HL DSG.
Volkswagen Jetta : Test Drive & Review-jetta-pressure.jpg
For 2 passengers in the front, the recommendation is 33 for all the tires. For 5 passengers and fully loaded boot, 36 for the front tires, and 44 for the rear tires.
However, I have never went this high. Usually I run 32 on all tires. For highway runs with my wife and 2 kids and luggage, I use 32 for front and 34 for the rear. With this I am very satisfied with the ride comfort, grip, cornering etc. Any higher, the ride gets bouncy.
graaja is offline
Old 28th April 2016, 18:28   #2520
Thanked: 608 Times
This is weird.
And here's mine. A minimum of 36 all around, and 41 and 44 for the heavy loads.
When the tires and engine is the same, any guesses as to why the variation?
Volkswagen Jetta : Test Drive & Review-2avx5gm.jpg
