re: Hero Honda Hunk Ownership Review: 20,000 kms & 165cc (Joel'ed)! It's been 20 months and 17000km on the odo and everyday makes me love the bike even more! I use Mobil1 10W40 oil now and will try Motul 300V oil soon. I have made some changes though. They are as listed under: 1) Full DC Lighting: The bike now runs on full DC. It's been close to 4 months now and no real electrical issues since. Still the same rock solid reliability even with 4 hours of riding with the lights on. No battery charging issues either. Got it changed at Ruby Electricals. May be an engine kill switch soon fitted from there as well. The DC Lighting required me to change the Regulator Rectifier unit to that of the Piaggio Ape, costed me a cool Rs. 1100. Besides that, the rewinding, labour, 'maget charging'(I know I got tricked) all inclusive cost me close to 3k inclusive of a Philips Xtreme Vision 55/60W bulb. No burned reflector yet and I'm almost certain I'm not going to have any issues later on as well. 2) Half Naked Chain Case:
I swapped the 4kg heavy metal full chain case for a lightweight, plastic half chain case from the Honda Stunner, cost me Rs.65. It wasn't a direct fit, only needed slight adjustments. It is a DIY essentially. Yes, I know that the stock chain isn't made up for this stuff, but this way, I lube it and clean it every fortnight, which the full chain case helped me ignore. But yes, I do plan on changing it with the X-Ring chain of the Unicorn Dazzler that I bought close to 5 months ago thinking my bike's chain had reached the end of its lifespan. I'm not sure when my chain will reach its full adjustment because it's been 7000km since I believed it was finished. The Chain+Chain Case: 3) R15 Handle Grips:
I always found the stock grips lacking in grip when they got wet during the rains. Not like it used to be as slippery as an eel, but I always knew there could be better grip on offer. That's when I laid my eyes on the R15/FZ's handle grips and realized that they were of top quality. Got myself a pair and fit them myself. Yes, wasn't a direct fit as such, the accelerator cable needed a few adjustments(not the diameter wise) of the part that holds the accelerator cable. Was a perfect fit where the R15 grips would end right at the end of the Handle Bar whereas the stock grips would extend a few millimeters beyond the bar, hence the bar end weights also needed a few modifications, those were easily done as well. I feel it looks better than stock and definitely feels better than stock. The accelerator grip: The clutch grip: The gap between the grips and bar ends: Planned Changes: - Brakes: The new CBZ Xtreme and Hunk come with Bybre brakes post the Hero and Honda split for the front and the brakes on my bike being a Hero Honda, has very spongy brakes. Would like to get the Master Cylinder changed to the newly available ones, get a pair of KBX asbestos pads and some DOT4 fluid and check out how effective the braking might be.
- The footrests of the CBZ Xtreme: The footrests of my bike are of horrible quality and especially the rider's footrest's rubber is all pegged back. The CBZ Xtreme on the other hand has top quality footrests and spring loaded footrests for the rider.
- Sprocketing: I've always found the bike to be short geared and in constant need of a 6th gear, so I'm probably going to shift to the Unicorn's 15T front sprocket to make the gear ratios a little taller. (43/15=2.8 vs 43/14=3.07).
The Issues: - Carburetor Issues: The mechanic who used to service my bike ever since the beginning is no longer working and no one is actually able to get the tune right. The idling RPM varies and everyone claims it to be normal. But I am paranoid about this and have tried one local mechanic and the authorized service center, but neither could help. It still varies and returns a mileage of 38kmpl. The ASC dismisses my claims of low mileage by saying that 38 is high by itself. I have got 48kmpl on a consistent basis and even 50kmpl once. Woe is me!
- Damaged Master Cylinder Screw: I wanted to change the brake fluid on the front brakes since the fluid has turned from red to brown almost. I tried removing the screws on the master cylinder, was successful in removing one, but ended up damaging the other. I have no idea what to do next. Someone help
 The Ray of Hope:
I've been on the lookout for a good place to get the bike serviced and I just got a new tenant. Coincidentally, he happened to know a good friend of his who owns Om Bikes, an authorized Hero Honda showroom on Mysore Road. I've also read good reviews about them online. They're open on Sundays too! So I'll just go on a Sunday morning, get the bike serviced, come back home and sleep again.
So that's about it. I've leave you to admire two photos of my trustworthy steed. |
