It's been a little over 13 months since this highly underrated bike in the premium 150cc Segment came home from Prakash Motors for Rs.77,371. And I must say that ever kilometer of the 10,000 has been special. The silent thrum of the single cylinder, 2-valve, 149cc bore still delivers low-range torque I find hard to match in bikes of the same segment.
10,000KM old bike,
WRONG!
10,000KM and still rearing to go like a curious youngster.
Let me get to the details:
1)
Headlamp: 35/35W AC stock headlamp looked reasonable enough at first, but a few trips later, found it lacking in throw at corners. Change to a Xenon Bulb of sorts for Rs. 350 and it's a whole new story. Visibility, throw and intensity all increased. The focus from the dome seems to be a let down. The Pulsar series seem to have a better made reflector system.
2)
Brakes: This version of the Hunk came with Rear and Front disk brakes. So my expectations from the brakes were very high. The rear brake assembly is from Nissin while the front bears no imprint. Possibly explains why the Rear Disks are way way more effective compared to the front. Front disks don't make for confident late breaking and sometimes feel insecure. Rear disks on the other hand are exceptional, sharp and precise response really ups the confidence level while riding in a city with Pedestrians with Cow-ish behaviour. The disk pads have been changed on both sets, the front cost around 300 while the rear pads are shared with the ZMR and cost a princely 1300! That gives me just an insight of sorts as to why the rear disk is so much better. Overall, braking can definitely be improved by slapping on a Nissin or Bybre brake system up front.
3)
Tyres: Tubeless and have had issues with air leaking out of the beading in the front tyre. Went to Tyre Professionals and they were unable to solve the problem. Went down to a local puncture shop and a few strips of insulation tape later, I am good to go again. The tyres are a letdown to be honest. Start up the bike, hold the front brake hard, slot into first gear, accelerate and let go of the clutch slowly, the brake locks the front wheel but the front wheel keeps skidding ahead. The tyres are not confidence inspiring in the wet. Nearly lost the back once while navigating a corner. In the dry, well, nothing to rave about. But does the job like any other tyre. Managed Lean Angles are repectable, you can't scrape your knees on the tarmac, but you could scrape the footpeg if you find a curve wide enough.
Like most others, I save the best for last.
4)
Seating: The Rider's Seating Position is the most comfortable amongst most bikes. The tall upright seating and the tank cowls shaped to accommodate even a 6 footers legs comfortably. The seat for the rider has a nice spongy, soft cushion which makes for comfortable long distance rides. But the same cannot be spoken about the pillion though. A complete lack of cushion at the far end of the pillion seat where the seat plate is easily accessible, But yes, pillion comfort is least on manufacturer's priority these days. So it's acceptable. I mean, just look at the R15 v2.0! But in the case that you have a girlfriend(Which is obvious when having a bike like this
) with you, I'd recommend carrying an air pillow under the seat.
5)
Gearbox: To start with, will admit it is indeed harder than most other bikes. But the smoothness in the gearbox makes up for it. The gear ratios are appropriately designed to ensure a highly decent amount of acceleration at first and second gear. While the higher gears allow you to sustain a consistent 50kmph at 5th or a more highway-friendly 80kmph without much effort. A few false neutrals when you tap the toe-shifter too lightly, but you'll get over it in a while.
6)
Looks: The design is 5 years old, but still gathers attention while in motion and while stationary. Aggressive and no obviously questionable design. Everything has a certain flow to it and there is nothing more I could ask for. Maybe a half naked chain case, but I can live with that.
7)
Engine: A proven Honda engine still proves it mettle. Ride as if you derriere's on fire or if you have a nice pretty girl behind you. The bike still delivers. Preferred speed would be between 40-50kmph at 5th gear. There are absolutely no vibrations transmitted into the footpegs and the engine barely makes a sound at the preferred speeds. But cross 105kmph and you get a free massage. Massive vibrations run through the bike but settle down a little beyond 105kmph. Acceleration is definitely something that deserves a special mention. The bike pulls ahead like no other, twist the throttle and your pillion will nearly suffer a heart attack!
8)
Fuel Efficiency: Aah, the age old,
Kitna Deti Hain? Delivers a decent enough 45kmpl when ridden sanely inside city limits with peak hour traffic plaguing my daily 13km journey to college and back. Or a more ridiculous 29kmpl if ridden like a madman. The choice of indulgence is yours to make.
9)
Handling: Heavier than every other 150cc bike. But doesn't feel that heavy. Try pushing it against an incline and you'd wish you were born in Krypton. But get on the bike and weave your way around traffic and suddenly the bike feels a lot lot lighter than it looks on paper.
10)
Maintenance: This is where these stalwarts stand out. No issues whatsoever. Some tender careful washing every Sunday leaves the bike still looking like new ever after 10,000KM. While fully synthetic Top1 Evolution oil leaves the engine still having me smiling each time I crank it. That equates to barely any expenses on the bikes barring the usual Disk Pads, Brake Fluid and Engine Oil.
Overall: I could not have made a better pick last year when I was asked to choose between the FZ and the Hunk. No regrets at all. In a way life came full circle. The Hunk was the first bike I ever wanted back when I was in Std. IX and eventually swayed to a Pulsar, Gladiator, R15 and eventually landed back to the new refreshed Hunk. Probably the inclusion of the Kick-Start lever wouldn't leave me wondering over what I'd do in case the battery ever runs out, but it's one of those things that don't occupy your thoughts every day.
Dear Triple-H,
Here wishing ourselves many many more 1000s of kilometers ahead of us. Thanks for the countless memories you have been a part of and created for me!
