For the record, when it comes to the force applied to the brake pads and disk, there is no difference between DOT 3 and DOT 4. They are both a type of hydraulic fluid (polyethylene glycol-based fluid) that does not compress when pressure is applied to them.
In other words, the pressure they transmit to the brake caliper when you step on the brake pedal or squeeze the front brake lever is exactly the same.
The lubricity of both fluids is also the same so one does not make it easier to apply the brakes than the other one does.
The difference between the two fluids is the temperature they can be heated to before they begin to boil.
DOT 3 fluid has a minimum dry boiling point of 401°F (205.00°C). The "dry boiling point" is for new fluid that does not contain any water.
DOT 4 fluid has a minimum dry boiling point of 446°F (230.00°C).
The minimum "wet boiling point" of DOT 3 fluid is 284°F (140.00°C).
The minimum "wet boiling point" of DOT 4 fluid is 311°F (155.00°C).
The "wet boiling point" applies when the brake fluid contains 3.7 percent water. (Brake fluid absorbs water out of the air if it is exposed to it.
The rubber bellows that is between the brake fluid and the outside air in the master cylinder prevents most of this type of contamination but over time, some water will make its way into the fluid.)
Now, getting back to temperatures: The high temperatures brake fluids are resistant to only happen when the brake has been applied for relatively long periods of time, like riding down a long hill with the brake applied. Of course, the heavy braking while racing also will cause these high temperatures.
For normal riding, even on the hottest summer day, the brake fluid in a motorcycles brake system will never approach these temperatures.
I have heard of cases where the brake caliper did not release the brake disk and similar heating has happened but this is very rare and it takes a long distance for the caliper and fluid to heat up to these extremes.
When this overheating does happen the fluid will boil. The gas it produces is compressible so as the gas compresses, suddenly there is no braking happening at all.
Obviously, this is not the case with the Pulsar brake that started this post.
I agree with the others who have pointed out, new brakes need breaking in. They do not have their full grip until this has happened so if the scooter, motorcycle or car is new, or if the brake pads have been replaced, ride/drive carefully so you won't need to stop quickly.
Ride safe.
