re: My Yamaha RX100 restoration thread - A tribute to my childhood crush Quote:
Originally Posted by pramodkumar Sriram, i dont think i understand what you meant. Let me be little dumb to gets my doubts cleared  .
The chain cover is intact, no dents or bends and absolutely no rust. Do i still need to replace it? About the sprocket, i get a huge thud sound some times in the morning while engaging the first gear, do you think i should replace it? I have done a max of 100kms on it so far after i got it. I thought i have original rx 100 seats, is it not so? the seat is as good as new no tears etc. The lock set costs 350 without the helmet lock and its of the minda make and has the new types of keys, like i posted a couple of pages back. I wanted a rx 135 tool box, do you think it would be a straight fit? The petrol lid is little differently colored and not a shiny chrome.. more like a dull finish, i thought of giving that for electro plating.
I am putting 10 ML of oil per liter of petrol and the 2t reservoir is dry as of now so i don't think more 2 t will mix in it, apart from smoke the pistons will also slip if more 2t is added correct?
PS: I have sent you couple of mails, would you reply and let me know what you want me to do? I might be there this Sunday/Monday.
Pramod |
My point is, while restoring the bike, it is equally looked into some new cosmetic outlook. Chain cover might not have dents or scratches, however, giving a new shiny look would be nice.
Sprockets: I would suggest you to take a look at the sprockets if worn out and duly change both front and back wheel bearings. The front wheel comes with one bearings (wheel bearings) and rear with two (wheel bearings and sprocket bearings). To be sure of your chain, would suggest to go for complete new Chain sprocket kit to give a new lease of life.
When you take out the bike in the morning, follow few steps to see if the thud sounds still emits when you engage the 1st gear:
1. Pump the clutch (say 4-5 time)
2. Move a bit from the stranded position before you kick start.
3. One or two empty kicks before you switch on ignition.
4. Turn on the ignition and fuel tap, kick start the bike
5. When you engage the first gear, it should not give some huge sound/ jerk. It should rather be smooth.
I would think it is because of the stationary position of the vehicle for a long time and thus gear box oil need some lube on the cogs for smooth shift.gear box might have got the oil dripped off to the bottom.
If you are running on Pre-mix, recommended is 30ml/liter. If you want to run on oil pump, then I would suggest you to check at regular intervals if it is working. Also, you might want to add some oil on to the tank to reduce the risk of corrosion. |
