Re: Royal Enfield 500 Classic 4100 km Ownership Review Quote:
Originally Posted by hexanerax The main function of the sprag clutch is that it
Naren |
Thanks for the post! Quote:
The main function of the sprag clutch is that it is a one way freewheel clutch similar to that found in a bicycle rear hub. Torque from the starter motor is transmitted to the crank through the gears but not vice versa. A running engine will not spin the starter motor since the sprag clutch will slip.
Agreed. The starter has to be disengaged from the engine when it fires and picks up speed. Otherwise the self-starter will spin at a zillion rpm and self destruct. This is the one and only work of the freewheel. Everything else is a side effect.
In cars there are alternative schemes for disengaging the starter once it had done its job. Quote:
The problem occurs when the engine turns in the reverse direction as happens when there is a back kick. The reversed rotation will cause the sprag clutch to lock , trying to transmit torque back into the starter motor. This , if repeated a few times will damage either the sprag clutch or the starter motor.
You can have freewheel designs where once disengaged, the driven side cannot cause engagement of the freewheel. Essentially the power transmission mechanism (rollers or balls etc) will be clear of the outer race, and only come into contact with it because of inertia, or centrifugal force. I take it that the rollers/ sprags in the RE design always touch the outer race? Quote:
Advanced timing on a cold engine is bound to occasionally cause back-kicks or rather reverse rotation of the crank.
Which is why vintage cars had a ignition retarding mechanism, generally controlled from the steering wheel. You would have a lot of broken wrists otherwise. Quote:
This happens because advance spark timing means that the plug fires well before Top dead centre position of the piston. A slow moving piston does not have the inertia to continue to compress the now ignited mixture, which forces the piston back down ,
Agreed. So my original question: why not retart the spark at startup? Quote:
The ecu on the C5 / CL 500 calculates crankshaft speed and the timing / mixture is adjusted to prevent full advance on a cold / low speed condition.
We'll come to ECUs later on. There is a reason for it. Quote:
The LB 500 and the electra 5s Es had issues not just due to the advanced timing but also because switching off the engine by means of the key or the kill switch traps compressed air in the combustion chamber which causes the piston to move down on an upstroke , causing reverse rotation for a few degrees. The common solution was to open the decompressor before cutting the ignition so the hi pressure air in the cylinder would release , allowing the piston to come to a smooth stop without reversing.
Why should the UCE differ. (Note to myself- Get full details of the auto-decompressor) Quote:
Another is to reduce load on the starter motor, allowing the crank to build up speed before the decompressor closes, starting the engine without extreme variations in the torque required on full compression.
Why can you feel the engine crossing over TDC on the kick? Quote:
Multi cylinder engines donot have this problem because of the high polar moment of inertia of the crank and the fact that other pistons are offering resistance to the one that is trying to reverse on shutdown.
They do, though very minimal. Watch any large genset being shut down. In any case it does no harm. Quote:
Cars use a Bendix starter that pulls back the spline shaft that transmits torque , totally disconnecting the starter motor from the engine once a certain flywheel speed is achieved.
Yes. Used in the Ambassador. Acceleration based, rather than speed. Not the most reliable of systems.
Would really like the answer to the ignition questions posted before. Too many queries.
Eg. Was the delay (AVL 500) a retarding of the spark, or a timed delay which prevented a spark till the starter had built up some speed so that inertia would carry the piston over TDC?
Sutripta |
