Originally Posted by KhalDrogo Question for all the Bullet Gurus in here. What's the difference between the CI Bullet 350(Right side gears) and a modern UCE Classic 350/Standard 350. I was always of the opinion that it was essentially the same bike, with just an updated engine and slight changes. But I've read a few posts on Team Bhp that say that the new bikes are Bullets only in name. So my question is, what's the difference between the old and new bikes mechanically. |
I am not a bullet guru but I will put forward my points because this is a discussion that interests me , I learnt to ride on a cast iron bullet and my first bike as such was one ('86 model ).
Mechanically -
Old cast iron bullets engine transmission and gear box were 3 separate units , this and comparatively poor machining increased transmissions losses to levels completely unacceptable in 21st century vehicle .
The new motor as the name suggests is unit construction as in all 3 units in the same case . Roadside mechs call it "pulsar engine" because they cannot work on it with the same ease with which one can attend to a cast iron motor . Other differences are the new engine is aluminium while the old was of course cast iron , the old motor had pushrods while the UCE uses hydraulic "pushrods" to reduce the load on the valve springs thereby allowing the motor to rev a bit further , another difference is carb vs fuel injection . There are differences and there are similarities , considering the original was designed back in late 50's , I won't call the new motor that different .
As for differentiating within the different bullets over the decades-
1. Many differentiate within the cast iron motors itself , prior to circa 1975 , the 350cc (500cc was a late arrival , 94 or 95 I believe and I will only speak from the perspective of 350 ) bulls had a 14 kg flywheel . This reduces acceleration and vibrates less, but increases the ability of the engine to lug in high gears at very low rpm and also the flywheel mass that results in the best exhaust note(exhaust note is the decisive factor ) .
From 14kg it first went to 11.5 and then by mid 80's 8.5 kg , acceleration and fuel economy improved but vibration increased and there is a distinct difference between the exhaust note . Many differentiate as such based on crank mass itself . Listen or better ride an original '68 model , it will be very hard to digest any other bullet after that even cast irons
ps: just before being phased out , enfield rolled out the last couple of the bullet(not electra's , just bullet ) batches with 14kg flywheel . I am not sure about this but I was told this along with that they command astronomical price .
2. Between CI and UCE - I am not sure why many learned owners scathingly put down the UCE , this is my guess but I assume it is down to the stark difference in exhaust note and the general feel of riding both bikes (this is probably a vague observation but it really does feel different to ride a cast iron ). Also the flywheel mass in current models differ greatly , the thunderbird for example even in 500cc has 5.5kg or 7kg mass while the 500cc bullet has 14kg mass - I recently came across a dark green 500cc bullet on road with a short bottle up-swept silencer and it sounded very good .
Also many hardcore owners love to attend to their cast iron bullets , it is a connection building exercise for them and something they miss with the new bulls which don't break down as much and when they do , it is hard to attend to it on the road side .
I personally detest only one thing with bullets , it is silencers which are obnoxiously loud but have no beat , it is very common to see cast iron riders especially sporting such silencers (Patiala silencer is one such variant) but they completely fail to grasp the beauty behind the exhaust note of a fine tuned bullet .
