Team-BHP > Motorbikes
Old 2nd June 2012, 07:16   #286
Sudipto-S-Team's Avatar
Thanked: 290 Times
Re: Enfield Queries
@ Rennjit - I got two of these the other day and fitted them to my bike (standard of 86) for Rs 980, replacing the older ones which should have been pensioned off long ago. Ride comfort and braking have improved remarkably but that's probably because my existing shocks were really really bad.
Incidentally, Armstrongs are now made in India not by Gabriel any more. It's by another American giant called Tenneco (that also owns the famous Monroe brand). It's not very clear to me why. Probably some global brand acquisition or realignment. You could ask their customer service cell (contact details in graphic below) about the softer and harder varieties that you were talking about. But these shocks are themselves adjustable and you can tune them to your personal specification if you are really keen.
I haven't really tried to find out about Endurance but they have a very elaborate website and I am sure you could ask them. If you want I will ask the spares store from where I buy my stuff.
Sudipto-S-Team is offline   (3) Thanks
Old 3rd June 2012, 17:42   #287
adrian's Avatar
Thanked: 1,263 Times
Re: Enfield Queries
Can anyone please elaborate the front fork oil replacement procedure in the new UCEs ? Can it be done as a DIY ?
Regards Adrian
adrian is offline
Old 3rd June 2012, 20:30   #288
Randhawa's Avatar
Thanked: 355 Times
Regards Adrian
If you don't have the right tools then it's not a DIY thing. It requires removal of the forks to change oil. Get it done at the workshop.
Randhawa is offline   (1) Thanks
Old 4th June 2012, 11:23   #289
voodoochild's Avatar
Thanked: 180 Times
Re: Enfield Queries
Originally Posted by Sudipto-S-Team View Post
...I got two of these the other day and fitted them to my bike (standard of 86) for Rs 980, replacing the older ones...
Sir, please excuse the OT, but would you have any info on availability of new Yezdi shocks by Armstrong? Mine seem to be at the end of their life, and I'm not willing to do a 'gasification'. Would prefer to stick to stock.
Any info would be helpful.
Cheers,
Rahul
voodoochild is offline
Old 4th June 2012, 13:03   #290
adrian's Avatar
Re: Enfield Queries
Thanks for the info Randhawa. I thought it was possible to change the oil without dismantling the forks from the machine. It is deceiving from the looks. There is an L key nut in the bottom of the forks and one at the top. What I thought was to remove the lower nut to drain oil and fill 195 ml through the top, bump the forks and shut it Now I am happy that I didn't try it prior to consultation with the experts. Will take the machine to the service and report back
Regards Adrian
adrian is offline
Old 4th June 2012, 14:31   #291
Thanked: 290 Times
Re: Enfield Queries
Cheers,
Rahul
Rahul - I would suggest speak to the customer care cell of Tenneco - makers of Armstrong. The phone number is given in my second image. If that does not help I guess you should also talk to any traditional old spare parts shop in your locality, they might know which size is needed.
Endurance also makes traditional shocks. You could try their number as well.
All the best. Please keep us posted about your progress. I started my two-wheeling life with a Yezdi.
Old 4th June 2012, 16:04   #292
Thanked: 141 Times
Re: Enfield Queries
Originally Posted by KkVaidya View Post
Only thing to do is get the threads re-done by a lathe machine operator. Basically what he will do is flatten the surface and re-thread it (something like re-boring). You will have to use a thicker bolt confirming with the new re-bored threads.
Thanks for reply.
Does it need to get down engine from chassis? How long it is stable?
(Alok) is offline
Old 4th June 2012, 16:42   #293
KkVaidya's Avatar
Thanked: 771 Times
Re: Enfield Queries
Originally Posted by (Alok) View Post
Thanks for reply.
You don't need to get the engine off the chassis. There is a thread tool available which can do this job. You will need to consult a lathe shop who can rub-out the old threads and make new threads on the re-bored surface. Any other experienced workshop can also guide you with this problem by a different solution other then this.
KkVaidya is offline
Old 7th June 2012, 12:21   #294
abhimanyuargal's Avatar
Re: Enfield Queries
Can anyone please suggest a good mechanic in bangalore to give my bulls gearbox a onceover? I have a 1978 Standard 350. I had gone to a mechanic on nandi durga road. But he's just managed to make it worse and i hate to see her struggling while she's being ridden.
abhimanyuargal is offline
Old 7th June 2012, 16:14   #295
adrian's Avatar
Re: Enfield Queries
Hi abhimanyuargal, just look at the previous page of this thread. You are from Bangalore and it surprises me that you have not heard of Mr. Gurunandan !
Regards Adrian
adrian is offline
Old 7th June 2012, 16:24   #296
starter's Avatar
Thanked: 917 Times
Re: Enfield Queries
Regards Adrian
Hey Adrian,
I've got a strong hunch that the mechanic who abhimanyu is referring to at Nandi Durga Road is Gurunandan himself
Cheers,
Deepak
starter is offline
Old 8th June 2012, 08:31   #297
Re: Enfield Queries
@Adrian: Thanks for the contact. I'm actually new to bangalore so I don't know the who's who of the Bullet worlds local chapter. Should I call the man or do I go to the address that's mentioned? Someone says that the garage in question has shut down.
@Starter: The guy I had gone to the last time was not Mr. Gurunandan. In fact another guy had suggested the mechanic I went to. Turns out we were both taken for a ride. and that too one that wasn't the least bit enjoyable.
do keep this thread alive as I'll be able to sort out all the other queries regarding good workmanship in bangalore.
Old 8th June 2012, 09:52   #298
adrian's Avatar
Re: Enfield Queries
Originally Posted by starter View Post
Hey Adrian,
Cheers,
Deepak
@ Deepak :What a small world Any idea of the address change of Mr.Gurunandan.
@ abhimanyuargal : Why don't you discuss your problem in this thread. There are many experts who could help you out.
Regards Adrian
adrian is offline
Old 8th June 2012, 10:49   #299
starter's Avatar
Thanked: 917 Times
Re: Enfield Queries
Its been more than months since Mtech is closed.
He is planning to move out of Bangalore.
Till then, you could still reach him on his mobile and take it to his residence in Sanjay Nagar.
Cheers,
Deepak
I've already replied to your query above Adrian.
He is currently servicing limited number of bikes at his residence in Sanjay Nagar (a couple of kms away from M.Tech).
Let me know if you need any help with directions.
Cheers,
Deepak
starter is offline   (1) Thanks
Old 8th June 2012, 13:08   #300
adrian's Avatar
Re: Enfield Queries
@ Starter : Thanks friend, I had e mailed Mr. Gurunandan as an enquriy on the possibility of a practical class on Bullet repair. He replied that he is giving classes on sundays alone in a month and is impossible to conduct the course for one week continuously as it would saturate the newbies to the point that they won't absorb a thing. So the dream has capsized since I cannot commute from Trivandrum to Bangalore every Sunday.
Regards Adrian
adrian is offline
