Re: Royal Enfield Queries Quote:
Originally Posted by ArizonaJim Speaking of the 2009+ UCE powered Royal Enfields, they do not have any rubber washers or spacers in the mount system used by the fuel tank.
There is one large 10mm bolt at the front of the tank and one at the rear. These use steel washers and flange nuts to secure the projecting tabs on the fuel tank directly to the frame.
Do not put rubber washers/spacers into the assembly. |
Jim mate I have seen rubber dampers on RE motorcycles here in India including the new UCE's. I am not sure about what they are using on export models. The front portion on the chassis(the triangle vertex where the two chassis tubes meet) where the fuel tank mounting is done does have a rubber damper within the hole through which the bolt passes. The job of this rubber damper is to avoid/cancel vibrations caused by metal contact. The rear mounting of the fuel tank too has a rubber damper. See the pictures below: Quote:
Originally Posted by abhijeetK I fitted this Ralco Speed Blaster 110/90*19 last month on my STD 350 for Rs 2800. Since for 19 inch rim we already have limited options, getting this tyre was not easy and the price was not negotiable. I got this from my mechanic, he ordered it from somewhere else. I am sure this should cost much less than what I have paid.
It has average grip in wet condition but it looks better than the skinny stock tyre. |
I have come across some riders who have opted for Ralco tyres but never got a chance to interact with them about the feedback on these tyres. Kindly share some more feedback with regards to wear and tear and rubber compound. Looking at the average wet grip I believe it has hard compound rubber. But I maybe wrong as it is a brand new tyre and will need some time to break in. It would be great if you can share some more feedback. Quote:
Originally Posted by tharian I am experiencing an issue with my CDI ignition run Enfield.
The bike has been having starting trouble since few months now, but not that bad, except that I need to kick more than what required unlike before when it used to start in the second or third kick.
Firing missing frequency has increased as well, but just once or twice over 5 kms. |
Have you checked the battery health as well as the spark plug? Quote:
Another point which makes me feel it is the ignition system is the engine was running hotter than usual and there was a slight change in the exhaust note which makes me feel the spark is not strong.
Is there any other part that needs checking in this case?
Have you checked the carb tuning as well. I believe you are not running to lean for this issue to crop up. Quote:
Originally Posted by ashwin1224 Brothers, I would like some opinions on Army bullets. I have been offered a 2004 350 at a tempting price with all papers in running condition (However I feel at least 15k would be needed to get it done right with minor nick knacks). I am 23 and I ride a Duke 390, but restoring an '82 Yezdi D250 too. I am considering this RE only because of the tempting price, and since I always was enamored by "bulleteering". What should be the price for such bikes? What to look for? And most importantly, What to expect in terms of ride, thump and other bullet things? |
ashwin mate I am not sure if the military disposes their bikes in just 10 years of usage. But I may be wrong as the papers suggest the other way. Kindly get the papers scrutinized properly if it is an auctioned bike. I follow a thumb rule of setting aside at least 10-15K for repairs and maintenance whenever I buy a second hand Bullet. So suggest you also to do that in addition to the buying price. Also the "tempting" price should be taken with a fistful of salt, as Bullets in used market don't come cheap. Kindly check the bike in and out with the help of a knowledgeable mechanic along with papers to finalize your decision. Coming to your questions, RE Bullets of 2004 vintage would cost around 75-90K. Look for things like rusting, oil leaks, pickup speed, smoke from exhaust and condition of the tyres/battery/electrical parts. The thump will be good since it is has a CI engine. Since you are already restoring a Yezdi 250 you know what to expect from vintage bikes like Bullet CI. Quote:
Originally Posted by StallionAmit Hi All, which Synthetic or mineral engine oil is best for Royal Enfield Classic 350 CC ( year 2011) model. And how much qty should be put. Instead if going to the service center i am planning DIY for oil change. |
The manual recommends Motul 3000 4T Plus 15W 50 oil for UCE RE's. The UCE engine takes about 2.75 litres of oil. Apart from the mineral oil mentioned above, Motul also offers synthetic oil. There is an entire thread on TeamBHP on oil related queries for RE Bullet titled "Royal Enfield Bullet oil change". You can go through it to find out which suits you better. Quote:
Originally Posted by B O V Yep the pushrod adjustment is fine. When I took it to a local mech(whom I don't trust), he said that the piston is hitting the head ![EEK!](https://www.team-bhp.com/forum/images/smilies/eek.png) I don't really know if he looked at me and saw his next EMI or whether he genuinely voicing his opinion.
Another issue is that I feel like there may be some kinda block in the oil supply lines, since there is a lot of oil leakeage through the screws of the timing cover and from the sides of the timing cover. And yes the screws are all brand new. Its the first thing I did to try and stop the leak.
I'm planning on removing the head and inspecting for myself, any thoughts on what to look for in case of the piston hitting the head? |
BOV mate one of my Standard Bullets had the same oil leak issue from the same timing cover location as mentioned by you. There were two culprits that we found out. One was the timing cover casing itself which was worn out and the stud holes that had expanded in addition to leaky gasket that is placed between the timing cover casing. The second culprit was the oil circulation itself which was very weak. Once these issues were resolved the leakage stopped and the bike returned to normal. As you are removing the head first check whether oil circulation is proper or not by removing the rocker covers and starting the bike. Let the bike be on idle while you can see if the oil circulates through the rocker arms. About piston hitting the head am not very sure of that aspect. It may be that the piston hitting the valves. Quote:
Originally Posted by tharian Anyhow, last morning I removed all the ignition electrical parts , cleaned them and plugged them back ,which is when I noticed none of these parts had been replaced. All have the year 2002 marked on them. |
tharian mate there were some similar electrical gremlins I was facing when I bought my first used Bullet(1996 model) in 2010. I changed the entire wiring harness just a year back and all the problems associated with the electricals vanished. Quote:
I also noticed there is a stand alone regulator box under the seat apart from the regulator/rectifier box.
Is that the CDI unit itself? |
