Team-BHP > Motorbikes
Old 19th February 2009, 19:28   #1
Thanked: 21 Times
Supercharged DI 2 stroke on a Fiero
working on a vane type supercharged 2 stroke direct injection engine ,using the fiero engine.Designing one, for some students from kerala.based partly on the lotus design.
cheers
EH
venugopal is offline
Old 19th February 2009, 21:29   #2
motomaverick's Avatar
Thanked: 989 Times
cheers
EH
Thats great news....How was the other experiment with supercharger for 4 stroke motorcycle?
motomaverick is offline
Old 19th February 2009, 21:55   #3
Mpower's Avatar
Thanked: 1,735 Times
Why Fiero?
Would'nt it be much more simpler to start with a existing 2 stroke engine?
Are you planning to use an injector from P220/R15?
Mpower is offline
Old 19th February 2009, 22:26   #4
Thanked: 57 Times
Great news, project will be ballistic, and why the fireo and not the stroker from TVS? what cylinder and head combo [I mean for the two stoke conversion] And direct injection using what injector and ECM?
dinar is offline
Old 19th February 2009, 22:36   #5
rranjith_kum's Avatar
Thanked: 21 Times
Originally Posted by Mpower View Post
Why Fiero?
Exactly! how are you going to get the ports into the block. I guess the block may need serious working and in worst cases I am worried about its structural integrity.
rranjith_kum is offline
Old 20th February 2009, 10:17   #6
Thanked: 21 Times
Why Fiero?
The project is all about,having the NOx emission of a 2 stroke and CO and HC emissions of a 4 stroke.Therefore there has to be a sump like 4 stroker,and it is goin to be a mechanical injection like a diesel.
Since the ports are BDC of the piston no such issues.
The earlier
one was a roots type and noisy,so making vane type.Did get 1 bar boost on the old one as planned.
cheers
Last edited by Rehaan : 20th February 2009 at 11:31. Reason: Please read the Team-BHP FAQ (link on top bar) about quoting multiple posts. Thanks
Old 20th February 2009, 10:39   #7
Rennjit's Avatar
Thanked: 188 Times
Sump ?
...,having the NOx emission of a 2 stroke and CO and HC emissions of a 4 stroke.Therefore there has to be a sump like 4 stroker,and....
Sir, could you pls share a bit more on the 'Sump requirement' for lower emission ?
Rennjit is offline
Old 20th February 2009, 15:12   #8
Thanked: 21 Times
Hmmm , how exactly is the air and the fuel mixture going to get to the combustion side !?
Old 20th February 2009, 21:32   #9
Thanked: 21 Times
using the charger for both filling and scavenging.
so you wont have to lubricate the piston and bearings with 2 t oil.
cheers
Old 20th February 2009, 21:48   #10
Mpower's Avatar
so you are going to open intake at BDC of the power stroke and fill, exhaust and compress on the upstroke so that you can fire the plug at TDC.
Mpower is offline
Old 20th February 2009, 22:24   #11
Thanked: 57 Times
So your going use the charger to push in the air and pull out the exhaust , with just open holes through the cylinder block of the engine? so need for a reed valve. And no pumping losses.
dinar is offline
Old 21st February 2009, 16:21   #12
Thanked: 21 Times
The injection will happen after the closure of exhaust on the way up,
Old 22nd February 2009, 23:08   #13
veyron1's Avatar
Thanked: 54 Times
Hm. So you'll be using the supercharger as an EGR propagant of sorts to serve as both the the scavenger and blower.
Lemme get this straight. The ports are at BDC. But the Fiero's crank is not designed to act as a regular 2 stroke pump (as in the normal 2 strokes, where the crank acts as the air-fuel pump to suck in air/fuel and pump it into the cylinder).
So what you intend to do (or are already doing) is place the injector & spark plug at the TDC (head, so to speak), and let the blower do the breathing instead of the crankcase, right? Ignition and injector mapping would be taken care of by customized mapping via CAS (I'm assuming)? And is the blower belt driven or gear-driven?
Suck, squeeze, bang, blow, (pun intended) just like a stroker, I presume..?
I'm wondering of the mechanical efficiency of this thing. Any dynos to check out the output in KW/HP? Could we have sectional cutouts/pics/more details, puh-lease...? This seems interesting...
veyron1 is offline
Old 23rd February 2009, 14:55   #14
Thanked: 21 Times
So what you intend to do (or are already doing) is place the injector & spark plug at the TDC (head, so to speak), and let the blower do the breathing instead of the crankcase, right? Ignition and injector mapping would be taken care of by customized mapping via CAS (I'm assuming)? And is the blower belt driven or gear-driven?Is driven off the magnet nut.
yes like i have already mentioned,it is partly based on ltus design.
cheeers
Old 23rd February 2009, 23:08   #15
Mpower's Avatar
Mixing will be a challenge. might end up with a stratified situation.
Mpower is offline
