Team-BHP > Motorbikes
Old 28th March 2009, 12:58   #256
praJEEP's Avatar
Thanked: 12 Times
There is other model which provides backlight in dark too, forget the model number what your take on it it costs 2.9k inr.
praJEEP is offline
Old 28th March 2009, 14:28   #257
Thanked: 9,250 Times
Battery may run out sooner with the backlight on. But the question is do you really need a backlight?
Sankar is offline
Old 29th March 2009, 13:15   #258
Pradeep whats a Sigma?
diecastfreak is offline
Old 29th March 2009, 17:18   #259
Thanked: 2,260 Times
Sankar/Prajeep
Where can I buy the BC 1106 in Bangalore? On the sigma website, I could just find the Indian distributor based out of Delhi.
JayPrashanth is offline
Old 10th April 2009, 17:05   #260
whitemm550's Avatar
Thanked: 111 Times
Originally Posted by praJEEP View Post
I haven't got the rubber washer for the fork legs, the suspension is bit on the stiffer side now, minus this problem everything is perfect and doing good. taking the bike to bike world jaynagar tommorow.
Some pics :
hi, can you please tell me how much did the Petal disc brake set up cost you. i have a RXZ 5 speed, but the previous owner has removed the disc saying that the nipple is broken, the rotor and the parts do really look to be in a bad condition, so i was jus wondering whether i should change the full set up, or repair the older one. kindly advise
whitemm550 is offline
Old 10th April 2009, 17:22   #261
whitemm550's Avatar
Thanked: 111 Times
Originally Posted by mail4ajo View Post
Prajeep, are those ceat tyres? Any reason why these knobby tyres? Although they give you good grip, the ride will not be all that great compared to regular street tyres.
you are right, the sport pattern on rear tyres is not such a great idea on tarmac, when cornering . the knobs do tend to flex, thus giving some anxious moments.
Old 12th April 2009, 10:03   #262
praJEEP's Avatar
Thanked: 12 Times
Whitemm just go back a few pages back you will find the necaasary info.
praJEEP is offline
Old 12th April 2009, 14:42   #263
straight6's Avatar
Thanked: 303 Times
Hey whats the best 2T oil you've used so far?
straight6 is offline
Old 12th April 2009, 20:47   #264
praJEEP's Avatar
Thanked: 12 Times
Just took a speed test yesterday with a speed gun, no tacho on the bike rite now so i have no idea whats revs its doing in 3rd and 4th gear. will update about the revs once the tacho is up and running, any ways here are the results of the speedtest.
Motul 800 till date.
EDIT : @sankar yes it was done after the port and carb change.
praJEEP is offline
Old 12th April 2009, 20:55   #265
Is this speed test done after porting and carb change?
Sankar is offline
Old 12th April 2009, 20:58   #266
praJEEP's Avatar
Thanked: 12 Times
duplictae post mods please delete.
praJEEP is offline
Old 7th June 2009, 11:41   #267
Thanked: 61 Times
pradeep,
first off, my congratulations on such a great job with your rx. i am inspired. but there is so much work going on your bike, i wouldn't even know where to start from.
anyways, my question is, why would you need a sigma on your bike ? i see quite a few people have it. what are the exact features that you find useful ?? i don't think it has an rpm indicator does it ??
hell_rider is offline
Old 7th June 2009, 17:07   #268
praJEEP's Avatar
Thanked: 12 Times
Sigma is required for those who need accuracy in speedo readings for others speedo would do, no it doesn't have an rpm indicator.
praJEEP is offline
Old 8th June 2009, 20:42   #269
prsnck's Avatar
Thanked: 81 Times
3.25/16 tyre on RX 135
try 3.25 * 16, apache sized rims with Yezdi tyres for the back. improves grip, lowers FE. There are many guys in shivaji nagar and mavalli (near Lalbagh) specialized in yamaha's.
I too right that. Been using 3.25/16 Yezdi tyres for past 5 years on my RX 135 - Excellent grip and perfomance. Mileage slightly compromised - should not matter I say - Since lookwise it gives more space to wheel wells and gives that macho look.
Prsn
prsnck is offline
Old 8th June 2009, 20:48   #270
prsnck's Avatar
Thanked: 81 Times
Bajaj shocks for RX 135
Some pics :
Hey Prajeep,
For suspension to be on the softer side use Bajaj Discover SNS rear shocks. Will do wonders to your shocks and really good cushion effect since it has double coil springs. I just changed a week back for my RX 135 which has been using the stock shocks from 2003 till 2009.
Let me know - u will get the money's worth I bet.
Rgrds
prsn
prsnck is offline
