Team-BHP > Motorbikes
Old 14th October 2007, 15:11   #1
Rpm does'nt go above 9k
hey guys,i have a pulsar 180 old classic and my bike doesnt go above 9k rpm in top gear,can u all help me out!!!!!!!!!!
speed140 is offline
Old 14th October 2007, 17:21   #2
turbo_v12's Avatar
Wow dude...where do u manage to reach 9k in top gear?
Were u able to do so before now? From what I know, ignition maps in the CDi drop drastically from 9k to kind off cut of the bike engine to avoid damage to it.
I maybe wrong, but just have a look.
turbo_v12 is offline
Old 14th October 2007, 18:04   #3
yogesh sarkar's Avatar
Thanked: 38 Times
I have only managed to taken my bike over 9k (bike does a 130k on speedo) 4-5 time in past five and a half years and that too only when the wind condition were favorable and my bike was in top condition. So unless you have a good tail wind, bike's running perfectly and you have really long and open road, you won't be able to cross 9k!
yogesh sarkar is offline
Old 14th October 2007, 19:19   #4
dustDevil's Avatar
Thanked: 16 Times
wow..... does the pulsar actually rev to 9k?? Most of the pulsears i've ridden choke by 8000 revs, that too when strained really hard!
dustDevil is offline
Old 14th October 2007, 19:48   #5
hyper123's Avatar
I have a 2006 P150, I could rev it to around 10500 RPM in top gear. 110kmh+ on the speedo. What bothers me is I've heard that DTSi has a rev limiter. If yes, to what RPM is it limited??
hyper123 is offline
Old 14th October 2007, 21:19   #6
Thanked: 38 Times
@dustDevil the OP has a classic 180 (which had one spark plug), there is no rev limiter in classic pulsars. You can easily take it beyond 12,000 in first gear and in neutral (not at all recommended). As for pulsars choking at 8000rpm, I have regularly seen alloy wheel versions hitting the rev limiter in fifth gear! Of course you need straight stretch, favorable wind conditions and a good rider.
the limiter hits in at 9500-10000rpm (forgot the exact spot)
Old 14th October 2007, 22:35   #7
hyper123's Avatar
So I must've hit somewhere around 10000rpm. Is there anyway you could remove the limiter. I know its not recommended, but just curious.
hyper123 is offline
Old 14th October 2007, 23:09   #8
hey guys,thank u for everything,but i am able to do 9k rpm on my bike every day,yestarday i had a race with an 200 pulsar fully modified and my bike is completely stock,accept the racing spark cable and a twin head plug thats it,still i was ahead then him at the start but after tat my bike got locked on 132 at 9.2 rpm and then he started movin little little ahead,guys 2,3 mnths back i was able to go till 10rpm in top gear but now it isnt goin more than 9.2 rpm!!!!!should i get my clutch changed or should i put a new cdi of 180 dtsi!!!!!!!!
speed140 is offline
Old 15th October 2007, 09:35   #9
vivekiny2k's Avatar
Thanked: 212 Times
get yourself a bigger bike
vivekiny2k is offline
Old 15th October 2007, 11:45   #10
Thanked: 38 Times
Limiter is programed into the CDI in order to prevent the engine from revving excessively and damaging itself. So the only way you can get rid of it is by getting a custom made CDI without a revlimiter.
Getting a DTS-i CDI isn't going to do any wonders if your bike is already revving till 9200rpm. My 2 cents be happy with it!
Old 15th October 2007, 13:55   #11
Spitfire's Avatar
Thanked: 777 Times
Get your maths right the 180 dtsi is not geared to reach those speeds.
Spitfire is offline
Old 15th October 2007, 14:30   #12
hyper123's Avatar
He has the first gen P180, so it does reach those speeds (indicated by the speedo that is).
hyper123 is offline
Old 15th October 2007, 17:40   #13
Spitfire's Avatar
Thanked: 777 Times
LOL you have your answer. On the speedo i can make a Enfield Mofa reach 300kmph.
Did the firstgen p180 have a revlimiter?
Spitfire is offline
Old 15th October 2007, 18:55   #14
Thanked: 38 Times
don't do it, you will go deaf!
Nope
Old 16th October 2007, 12:48   #15
Spitfire's Avatar
Thanked: 777 Times
Not ridden a p180 to the max revs. Has anyone one seen 9K+ on their Pulsars. The old gen Pulsar made max power at 8000 rpm so ithnk it might rev out to 9K, not sure though. Any pulsar owners here who have?
Spitfire is offline
