My one year old Arai XD-5 has been giving me trouble. I bought it from Bikegear.in in April last year. Very prompt and very pleasant service. Before I go about explaining my issues, here’s a picture explaining what parts are giving me trouble.
The peak pressure plate and the holder
The small, triangular plate is called the peak pressure plate. The screws can be loosened to adjust the peak. The broader plate on which this triangular plate is mounted is called the holder. It has push button which releases the holder from the helmet and the visor can then come off.
I used this helmet for a few long rides last year with no issues at all. The trouble began in February this year. Here’s how it went:
(1) February 2025 – I noticed that the left peak pressure plate was cracked and the screw, too, had started to break. I took out the plate, glued it with feviquick temporarily and ordered a new set of these plates.
(2) When I went to install this new set, I saw that the left holder, too, had cracks in it. I ordered a new set and replaced them.
(3) Earlier this month, I saw cracks developing on the visor around the pinlock pins. One of the pins fell out while cleaning. So, I ordered a new visor.
(4) Two days ago I was cleaning the lid and to my horror I realized that the plates had started cracking again.
Here are some pictures:
The plates on the top are the new ones.
Old holder plate. The other side had similar cracks too.
Every time I open up the helmet to clean, I find broken pieces like this.
Now there’s only one thing that I have changed since last year. The exterior and interior cleaner that I use for the lid. Here’s a picture of the one that I used till February this year:
And here’s the one that I have been using since then:
They’re both the same brand but the latter one cleans better (produces a little foam when being wiped off), smells better and is easier to carry around on rides thanks to the bottle shape.
I used to believe these Motul cleaners to be helmet safe otherwise I would not have even brought them anywhere near my helmet. Now that I think about it, I should not have used anything other than water. Hindsight is 20/20 as they say.
I have a Ladakh ride coming up in May and I wanted to know if someone here knows what I am doing wrong. Is it the exterior cleaner that I am using? Am I tightening the screws too much? Or am I riding too fast with an ADV helmet on? In addition to adventure riding, I often do long expressway rides with sustained high speeds (120-130 kph). And what cleaners do you guys use? Should one even use any cleaners at all? Any help is appreciated.
