2025 Kawasaki Eliminator launched at Rs 5.76 lakh Kawasaki has launched the 2025 edition of the Eliminator, priced at Rs 5.76 lakh (ex-showroom), which makes it Rs 14,000 more expensive than its predecessor.
No mechanical changes have been made to the Eliminator. The bike continues to be powered by a 451cc, parallel-twin engine, which is shared with the Ninja 400. It produces 45 BHP @ 9,000 rpm and 42.6 Nm @ 6,000 rpm, thanks to a longer stroke, bigger throttle bodies and a larger airbox. The engine is mated to a 6-speed gearbox via a slip/assist clutch.
The suspension setup comprises a telescopic fork at the front with dual shock absorbers at the rear. The bike rides on alloy wheels with an 18-inch rim at the front and a 16-inch rim at the rear. Braking is handled by 310 mm and 240 mm discs at the front and rear, respectively.
The 2025 Eliminator is available in the same Metallic Flat Spark Black colour. It features a circular LED headlamp and a single-pod LCD instrument console with Bluetooth connectivity. Other features include Kawasaki's Ergo-Fit system and dual-channel ABS. Link to Team-BHP News |
