Royal Enfield Guerrilla 450
What you'll like:
All-new, well-rounded and well-differentiated roadster from the Himalayan platform
Sporty and youthful motorcycle, targeted at a younger audience. More exciting colourways than with any Royal Enfield motorcycle ever
Looks substantial compared to some rivals, with a long wheelbase and some elements like the tyres being the largest in class
Very approachable motorcycle with a seat height of 780 mm and a kerb weight 11 kg lighter than the Himalayan. Feels well balanced as well, not top-heavy!
39.5 BHP Sherpa engine has been retuned for a very peppy midrange. Refinement levels are slightly better than the Himalayan too
Slick 6-speed gearbox with a decently light slip and assist clutch helps to stay in the torque band all day long. Best experienced between 3,000 to 6,000 rpm
Competent city ride and handling package from Showa - compliments the urban nature of the motorcycle well
Excellent instrument cluster carried over from the Himalayan - now with updated features. Navigation, though not a perfect implementation, is still useful
What you won't:
Not for everyone! With its scrambler-inspired looks and loud colourways, the Guerrilla is set to polarize opinion
The Sherpa motor has a slightly erratic idle, followed by a slightly jerky low-end below 2000 rpm - best kept within the torquey mid-range even when in the city. Not newbie-friendly
Single-cylinder vibrations, though made smoother now compared to the Himalayan, are present throughout the revv range. No deal-breaking resonance experienced at any rpm range, but certainly not dismissible either
Runs hot - The radiator fan was unexpectedly busy even on rainy and cold Bangalore days. Summer performance needs to be monitored
Suspension is good for the city but feels significantly less sophisticated than in the Himalayan when ridden hard. 11L fuel tank could also affect touring abilities!
Poor lamps all around. The headlamp is woefully inadequate and the quirky new indicator stalk + tail lamp vibrate on bad roads, making it blurry for traffic behind
Fit and finish could be improved. Good overall build is marred by poor execution of touchpoint items like the joystick switch, indicator switch, etc. Also, the stock mirror is useless at highway speeds
Missing features for rider control like traction control, IMU / cornering ABS, quick shifter, adjustable clutch and brake levers, backlit switchgear, etc.
Review Link Triumph Scrambler 400X
What you'll like:
Quintessential
Triumph design that looks distinctly like its bigger Scrambler siblings for the most part
Build quality, fit and finish are among the best in the segment
Thanks to its taller and more substantial stance, it does better visual justice to the 400cc big bike feeling than the much more compact Speed 400
Larger riders will also appreciate its relatively roomier ergonomics compared to the Speed
Nice bespoke touches that lend aesthetic value as well as utility where needed - sturdier metal bash plate, headlight grille, twin barrel exhaust with the black cladding, round indicators, tank grips, step-up seat to highlight some
19 wheel, superior ground clearance, longer wheelbase and better suspension travel, all make for a much more stability-biased ride, in keeping with its Scrambler DNA
39.5 BHP engine is reasonably tractable with a strong pull. Smooth & refined power delivery at a kerb weight of ~185 kg results in fairly peppy performance aided further by a slick 6-speed gearbox
Still a hoot to ride despite its taller stance and longer wheelbase
Generous 16,000 km / 1-year service interval. Parts and service costs are also expected to be kept competitive
What you won't:
Missing features like connected tech, riding modes, adjustable clutch and brake levers, etc.
Inexperienced riders (especially shorter ones) may find the 835 mm seat height a tad challenging
Analogue + digital instrument cluster doesn't suit the bike's character
Some ergonomic issues such as mirrors fouling with hand and footpegs flexing downwards while stand-up riding
Vibrations at higher rpms
Split rear seat is compact. Riders should carefully evaluate how comfortable the bike will be for two-up touring with luggage if that is a key use case
Only single-sided saddle bag luggage is being offered by Triumph as of now. You will have to look at aftermarket solutions for double-sided saddle bags or wider luggage options
Entire service experience remains uncharted territory with Triumph leaving a negative perception on this front in some parts of the country. Whether one can have a positive dealership experience under Bajajs watch is something that remains to be seen
Review Link Harley Davidson X440
What you'll like:
Single-cylinder, 440cc engine has good low-end torque to make city riding as well as highway cruising comfortable
NVH and refinement are really good. Combined with good ergonomics, you can cruise at 80-100 km/h all day long
Well priced. It is on par with its peers, albeit with an extra ~40-90 cc
Built by Hero, who knows the Indian two-wheeler consumer extremely well
Decent level of kit - standard dual-channel ABS, Bluetooth connectivity, connected features, etc.
What you won't:
Design and styling can be polarising. Not your typical Harley
In a segment that has heated up with lots of new offerings, the X440 doesn't ace any specific aspect
No riding modes or traction control. Essentially not a lot of ways to customize your ride
This is the first product of the Harley Davidson - Hero partnership. Sales, after-sales and service support and experience are unknown
Review Link Hero Mavrick 440
What you'll like:
Single-cylinder, 440cc engine has good low-end torque to make city riding comfortable. Fairly responsive mid and top-end keep highway cruising engaging
Superb ride comfort; gobbles up bad roads without letting the rider, or even pillion feel them
Features such as standard dual-channel ABS, Bluetooth connectivity, turn-by-turn navigation etc. are standard on all variants. Top variant gets e-sim connectivity
Hero's sales and service network is unparalleled, even in tier 2 and 3 towns
Well priced for what it offers. Undercuts most competitors
What you won't:
Very basic instrumentation cluster in terms of look, feel and functionality
Missing features such as riding modes, traction control, upside-down suspension fork, etc.
Built to a cost. Cost-cutting is evident in a couple of areas
Ride gets unsettled at higher speeds
To many people, the Hero brand doesn't have the badge cachet of Royal Enfield, Honda or Harley-Davidson
Long-term reliability of the new engine is unknown
Review Link Husqvarna Svartpilen 401
Ownership Review
