Originally Posted by sumitkalindi
when i take her for a long ride and keep my speeds at the range of 80kmpl and above constantly for a quite long distance, the engine oil level drops significantly.
I need your help to sort this out. The terrain I ride on is hilly terrain. So you can understand she does around 7k~8k rpms during theese time.
Hope for some pointers to resolve the issue soon. |
I guess you mean speeds of 80 KPH and above.. A few pointers:
I'm just confirming the method you use to check the engine oil. Because, when the engine is running, the oil is circulated within it. In order to check the level of engine oil, you need to park the bike on the main stand; over a gradient free surface for at least 30 minutes, so all the engine oil flows back and collects at the bottom (known as sump). Then pull out the dipstick, wipe it, and put it back in without screwing the top. The engine oil level should be between the two marks/shaded portion on the dipstick. As long as you can see oil on the indicated marker; there shouldn't be a problem.
A 4-Stroke engine consumes engine oil only when the piston rings are fried; which allow oil to leak into the combustion chamber. Since you have done just 12K on the odo, and your exhaust is smoke-free- the chances of the piston rings being fried are highly unlikely (unless it is a manufacturing defect). Quote:
Originally Posted by sumitkalindi Anotherthing I noticed is Black deposites, on the side of the big nut on the front part of the engine near Top. Most probably dirt attracted by engine oil vapour escaping from its side. Is this possible explaination of loss of engine oil in a Pulsar. |
An ideal 4-stroke engine should be leakage-free. The dirt will only be attracted even when there is a slight oil leak. Check all the rubber-washers and crankcase gaskets to ensure that there is no leak. Also ensure that the oil draining bolt at the bottom is secured and also check the oil seals. |
