Originally Posted by Sudarshan42 Honda's vibe free engines are those with a lower compression ratio and are largely unstressed engines. Case in point- the CB350 brigade. Very smooth engines, but you have to be ok with a lower power output. Can't have both in the single cylinder domain. I think you should look exclusively at multi cylinder bikes then- also look at Benelli if you don't want to increase your budget to Kawasaki levels.
Or- add 2-3 more lakhs and get a Ninja 650- it'll be a 10 year purchase. |
I realised I liked the low compression engines a lot. Those in the range of 10.6 :1 to 11:1. 12-ish is busy and fuel guzzling in my opinion. Benellis are a bit of a risk considering the service network and spares availability issue.
Ninja 650 made me realize that I'm in poverty lol. Its almost 9 lakhs Chennai OTR! Ninja 500 too is a little far fetched for me at 6.5 Lanks OTR. But the ground clearance worries me a lot. I live in that part of Chennai where we need a minimum of 150 mm to cross the obstacles course!
Originally Posted by aa-Crecy I would recommend CB300R, relatively smooth, cruses at 100-110 comfortably. Light weight agile bike for the city rides. Should give an economy of about 35KMPL. |
Now that's a fab ride for a single man. It even gives as high as 46 kmpl according to few riders! The non-existent pillion seat and puny fuel tank made me steer clear of it :(
Originally Posted by R-Six It certainly is a good deal. If you change your mind to look at pre-owned bikes, you should certainly take a look. It is fairly new, and run less than 10K kms. Even the asking price seems to be fair, given that the first owner has already taken the depreciation hit. Give it a try, may be you will like it.
Otherwise you can wait for a couple of more months and Honda is expected start importing the NX500 early next year.
The only pain point I could envision for these Hondas would be the availability of spares.
Cheers,
R-Six |
Noted! Will do my homework on the CB500X. NX500 for some reason has its service charges boosted by almost 100% even though its mechanically the same as CB500X :(
Originally Posted by Siavi As per me there are two options...
1. You could go ahead with the CB500x. I think it's a steal for 4.5 lakhs, subject to its current condition. It's a great bike, a true jack of all trades. Also you'll be getting it with all the accessories already fitted ( I'm hoping the owner has installed some). The only con is that it feels a bit unexciting and the availability of spares in future.
2.Just saw the spy shots of the Himalayan 650. Since you have already waited for so long, why not wait for some more time and then go for this. I'm also waiting for it with my fingers crossed. It will fit all your needs and also the spares availability will not be an issue. The only con will be that you'll have to wait for atleast 1 more year for it to launch and then some more if you don't wish to buy from the initial batches... |
Waited for 3 years due to indecision. Waiting for another year is gonna make me go mad I guess. But yea thanks buddy, will keep these 2 in my mind!
Originally Posted by robby0707 Owned the Ninja 300 for 7 years.
It satisfies all your criteria.
There is no heat in the city.
Still looks good
Reliable.
Can do 140 easily. I currently own a Versys 650. The Ninja has a better mad top end acceleration than the v650. I’ve done higher speeds (speedo shown speed on a closed road whereas the max i could do on the v650 was 170)
Absolutely vibrations free.
Will give 30 kmpl if driven normally and 25 in any case.
I also think that the Aprilia RS 457 will meet your needs. But I do not have any personal experience.
I honestly miss my Ninja 300 at times. |
Ninja's engine heat and low ground clearance worry me (would change the suspension linkages to boost the ground clearance. But engine heat?).
By the way, did you drive your N300 in the cooler Kannur of Karnataka or the Tropical Kannur of Kerala? I need to know that since Chennai's humidity makes an engine behave in an altogether different manner to be honest.
Originally Posted by RodRowdyBiker I think the Suzuki Gixxer SF 250 is the perfect fit. It is vibration free below 120 kmpl and gives approx 32kmpl. It is quite and well built. It can cruise at 120 kmph all day. Very reliable and low servicing costs.
I think it looks killer and is quite comfortable to ride with an upright riding posture.
I however feel that you are set on spending 5.5L and this bike less than half of it.
I think the next best bike to meet your requirements is the Ninja 500 which is within your budget if you look at ex-showroom only. It is a brand new model and I think it is VFM as well! You should be able to get more than 25kmpl if you hyper-mile it. Butter smooth engine. Insane Kawasaki reliability. I think it is worth it to stretch your budget by 50k to 6L for this bike. If you feel that it is relatively expensive, remember that it is a CBU and Kawasaki CBU build quality is on another planet compared to the REs and its about 40kg less. |
Gotta agree with the Suzuki 250 traits that you mentioned. But when I took a test ride, I came back with an aching palm (the bottom of my palm became a bright red in just 2 kms of riding) Found it straining. Surprisingly the RS 457 didn't strain me although its more committed than the SF 250!
N500's at 6.5 lakhs OTR and its menial ground clearance of 145 mm keeps me thinking long and hard to be honest.
Let me test ride it if possible.
Originally Posted by VW2010 Ride it at red line. The ktm awakes and gives a fabulous ride when you keep it above 7k rpm. Many ride it at its worst rpm between 4000 to 5000.
It is a single pot generating close to 35bhp in the 390 and it will be vibey.
After all the exchanges here I believe you may like the rs457 as it fullfills most of your requirement. It can keep up with big boys too.
Used 650 is also not a bad option or used bonnie. |
4k-5k rpm is where any bike spends 60% of its lifetime in my opinion. Correct me if i'm wrong. Wish I didn't have sensitive hands, or there was an oil that magically boosts engine refinement to another level, even if it costs 3000 per litre! Might as well wait for the Gen 2 Adv 390.
As for a used Bonnie?! Whoa,tasty. Never ever thought of that! I know very little of it. *intense googling begins*
As for the RS457, its fuel tank range of less than 300 kms stopped me for booking what is otherwise the best bet for me as you said.
Originally Posted by prakash_ajp I think anything around 4 will be a reasonable price for CB500X. What goes for it is also its Achillies-heel - that it sold in few numbers making it a rare find but also means maintenance is going to be hard to find spares etc. |
All bigwing bikes unanimously suffer the spares issue, dont they? Sigh!
