Yezdi Classic 250 | Starting Issues Hello everyone,
I own Yezdi Classic 250 from 1981. I recently changed the carburettor and installed a new one (Pacco 47 Y. Pics attached). I tuned the bike using the idle screw and the air screw and it rides fine. I test rode it a couple of time to get the right air mixture and have now settled somewhere slighty higher than a 1/2 turn out (counter clockwise). I have adjusted the needle clip of the main jet 3rd slot from the top. the Main Jet is 90 and the Idle is I guess either 40 or 50 (cannot make out). Now the problem is as follows
The bike does not start whatever I do unless I do one of the following
I loosen the idle screw quite a bit (almost 3 more turns out from its normal setting) and then the bike will start or
I place my hand and partially block the air intake (after removing the rubber pipe) of the carburettor and the bike will start almost immediately. It seems the vacuum/ pressure that is created helps
It almost seems it needs a good air pressure (vacuum) to start. Since when I loosen the idle screw it does reduce the aperture of the slide and when I put my hand on air intake it does create more air pressure in the carburettor
So can anyone help me with what could be the possible reason for the same? The bike usually restarts if I just switch off the engine and start within a couple of minutes. But maybe after an hour or so, it wont start again till I do either of the two tricks !
I tried different air screw setting between rich and lean but it really does not have any impact. I changed the spark plug, and I even serviced the point. I also tried different main jet needle position however, the problem persists.
Any clue whats going on?
Pratz |
