Team-BHP > Motorbikes
Old 30th March 2024, 13:06   #1
Thanked: 29 Times
Triumph Speed 400 | Front fork oil leakage
I'm really starting to question the reliability of the bike in recent times. Starting with Coolant Leakage from the Engine Head to now the Oil Leakage from the Front Fork. I rode the bike last 4 days ago and when I took off the covers today, found oil spilled on the floor. The right side fork was moist with oil and was dripping on the rim. I rode it for about ~20 kms to see the changes, it rides perfectly fine but the suspension have gotten soft.
I seriously have no idea how can this be possible all of a sudden but lets see what the service centre has to say on this.
Dtovio is offline   (1) Thanks
Old 30th March 2024, 14:03   #2
2legit2quit's Avatar
Thanked: 429 Times
re: Triumph Speed 400 | Front fork oil leakage
Looks like you have a busted Fork oil seal. Not uncommon with bikes that have USD suspension and are ridden in dynamic road conditions like India where dirt and debris can cause the seal to rupture and cause fork oil to leak. Get the fork oil seal replaced and invest in a pair of fork oil seal protectors which will minimise the risk of this occurring again
2legit2quit is offline   (12) Thanks
Old 14th May 2024, 13:26   #3
Thanked: 25 Times
Re: Triumph Speed 400 | Front fork oil leakage
For all motorcycles with USD suspension, it is aways good to have fork seals in place.
Kriega Fork Seals are good and you could get a set online. I suppose lazyassbikers sells them.
CloserToTheEdge is offline   (1) Thanks
Old 14th May 2024, 17:35   #4
neith's Avatar
Thanked: 221 Times
This happened on our speed with around 8k on odo and know another case on a scrambler400 with 1k on odo.
neith is offline   (1) Thanks
Old 6th October 2024, 12:28   #5
Thanked: 154 Times
Hi, are there any downsides to fork seals? Like slightly worse suspension performance? or something else?
nr07 is offline
Old 6th October 2024, 14:35   #6
Thanked: 692 Times
Absolutely not. These are very versatile and good additions to your motorcyling experience. Fork seals are made of stretchable material so they only provide protection from dirt and dust. They are not too tight that may cause any loss in suspension performance.
chiefpk is offline   (1) Thanks
Old 6th October 2024, 20:07   #7
Thanked: 429 Times
Do you mean the fork oil seal protectors?
Old 7th October 2024, 09:12   #8
Shonith's Avatar
Thanked: 495 Times
I think you mean Fork protectors, they work well as long as you maintain them as per their intended condition,
Dirt, dust and sand particles can get in between the protectors and the fork legs, this can cause scratches on the fork legs as a result of fork movement. So it is advisable to remove the protectors once in a while depending on your riding conditions and clean them thoroughly to avoid damage.
Ktm forks come with a dust cover which you need to pull down and clean the insides. The older models (first gen, first few lots i believe) didnt have these.
Triumph unfortunately doesn't seem to come with a cover like this.
Shonith is offline
Old 19th February 2025, 20:25   #9
Thanked: 15 Times
My scrambler 400x now has a fork oil leak, it is less than 2 months old and has 1300 Kms on the odo! I've been riding it in dirt roads with lots of pot holes. So maybe this is expected?
400Xrider is offline
Old 20th February 2025, 12:45   #10
Thanked: 333 Times
Yes. It is bound to happen.
Get the fork serviced and use a fork seal protector. Clean the fork seal protector at a regular frequency.
skviknaraj is online now   (1) Thanks
