Interceptor 650 - Neutral indicator "N-light" delay after changing the electricals Namaste everyone! This is my first post on this great forum and I am excited imagining all the insights I would potentially gain about my machines talking to the passionate and knowledgeable riders and drivers like you all.
I recently bought a used 2020 Interceptor 650 from beepkart and had to get its complete electrical system changed (ecu, relays, side stand sensor, you name it) within a month of the purchase. The motorcycle ran fine for a couple of weeks, but then started showing issues like engine misfiring and shutting off unexpectedly. One hot afternoon, in the middle of Bangalore traffic, it shut off completely.The vehicle apparently had an accident a few months ago that had damaged the electricals. This was obviously not disclosed by beepkart at the time of selling.
The RE service folks replaced my motorcycle's electricals under extended warranty and the engine has been running quite smooth since then. But as a by product of the electrical overhaul a couple of new problems surfaced:
1. Neutral indicator:
The N light stays on for about 6 to 8 seconds even after putting the bike in 1st gear. Similarly, the N light doesn't turn on for upto 5 seconds after setting the bike to neutral. I have checked it multiple times, and I can confidently say that the time it takes for the N light to turn on or off is the same. When I asked the service folks, they said they need to check the sensors once again (basically leave the motorcycle at the center for a couple of more days). I didn't do that because the service folks didn't sound like they really diagnosed the actual issue. Like how sometimes a doctor goes "umm..., hmm..., okay let's take these 10 tests and then we will see what the issue is" . It's obvious that it's a by product of changing the sensors and the ecu. An experienced mechanic must be quickly able to tell whether it is a sensor issue or the ECU tuning issue.
So, I want to know your opinions on what could it be?
2. Side-stand sensor
The engine shouldn't crank while the side stand is down, and this was indeed the case until I got the electricals replaced. Now however, the engine does sometimes crank with side stand down, but then immediately shuts off. Once again either it is the sensor issue or the new ECU issue. I seek your opinions on this as well.
Despite the past owner not having taken the best care of this Interceptor, I would very much like to. That's why I want you to recommend some trusted RE mechanics/service centres where you had good experiences taking care of your beloved machines. This is my first time owning this brand and so my knowledge is limited in that respect. I would like to hand over this tuning task to someone familiar and experienced.
Thank you. |
