Team-BHP > Motorbikes
Old 20th August 2023, 21:14   #1
adrian's Avatar
Thanked: 1,273 Times
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350
This thread is about installing a backrest for your bench seat Bullet (Standard and Electra) the easy way. Yes, this is a jugaad.
I speculated the need for a rider backrest on my Bullet for the Ladakh ride from Trivandrum. Wanted a cheap backrest which could be installed without heavy modification of the seat (see YouTube videos which used car seat headrests).
After hours of research and thought, finally inspiration struck.
1. Buy this type of backrest, which is intended for the pillion rider. Cost Rs.749/-
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-back-rest.jpg
https://www.amazon.in/SGTB-Enfield-B...field%3ABULLET
2. Reverse the mounting clamps
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-reverse-clamp.jpeg
3. Mount it to the nuts that hold the pillion grip in the seat
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-mounting-point.jpg
4. Slight set back
Due to the pre drilled holes and due to the fact that the clamps are reversed, the back rest will be at a weird angle tipped to the front.
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-seat-angle-before-relief-hole.jpeg
5. Solution
Drill a hole besides the default mounting top hole after marking the position after tilting the back rest at the desired angle
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-relief-hole.jpeg
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-bracket-relief-hole-close-up.jpeg
Final set up
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-seat-front-view.jpeg
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-seat-back-view.jpeg
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-seat-angle-view.jpeg
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-seat-angle-close-up.jpeg
Name:	seat angle close up.jpeg
Points to consider
Never install the back rest too close to your back. The reason is that on bumpy roads you need enough clearance to prevent the back rest from poking your back (even though it is cushioned, it is very uncomfortable).
Review (1 month 170 km daily commute)
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-seat-angle-motorcycle.jpeg
Positives
1. Cheap
2. No modifications required on the stock seat
3. You can take it away easily if you don't need it
4.The rider back rest is good for long rides. With the way I installed it in my motorcycle, when riding on highways, you can use it by slightly sliding back. By sitting in the normal riding position, you can stay clear of it (useful in bad roads)
Negatives
1. You cannot carry a pillion rider
2. you cannot use it on bumpy roads
3. Getting on the motorcycle requires the flexibility of doing a high kick
Adrian
adrian is offline   (26) Thanks
Old 21st August 2023, 06:07   #2
Thanked: 86,399 Times
re: DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350
Aditya is offline   (2) Thanks
Old 21st August 2023, 08:47   #3
tharian's Avatar
Thanked: 8,626 Times
Thats a nice idea to fit a back rest for the rider.
What about the luggage space in case you have to use the pillion seat for a saddle bag or tie down something?
The seat that came with the Electra and Standard were the best seats on a RE for comfort and long distance.
Have a safe and enjoyable trip. This is still on my bucket list.
tharian is online now   (1) Thanks
Old 21st August 2023, 10:37   #4
Thanked: 4,730 Times
That's a neat DIY and I'm sure your back will "Thank You" on longer rides.
However, a suggestion, Put those bolts end inwards (with nuts), lest they would hurt your leg or get your rider pants in trouble, if they got stuck while going up or down on a bike. The bolt end (sharp edge) might hurt your hands while putting it on the main stand, if you try to do it with the back support and also can hurt you in a situation of the bike imbalance.
Or
Put a bolt protector, at the end, something like this, so that the protruding edge is well inside the groove.
Safe Riding.
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-img_5800.jpeg
NomadSK is offline   (6) Thanks
Old 21st August 2023, 10:59   #5
vamsi2390's Avatar
Thanked: 277 Times
Good idea but the easier thing is to have a tail bag mounted when on highways. It is soft plus luggage is sorted as well.
Just a sample from a recent trip on my Interceptor. I do the same on my Electra and thunderbird as well.
Also, please do something about those metal brackets protruding out. If you do saddling on bad roads , would be real dangerous for your tailbone
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-img20230721wa0029_original.jpeg
vamsi2390 is offline   (8) Thanks
Old 21st August 2023, 20:32   #6
adrian's Avatar
Re: DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350
For a tail bag, this will provide support and an additional anchorage. As far as a saddle bag is concerned, it depends on the type.
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-saddles.jpg
If you are using the drystack type, there will be no issues as the cross bridges are two independent straps. But the cross bridge in the expedition saddle bag is of a broad sheet type design and the back rest will make one side curl up a little bit.
I am using a Ladakh carrier as well as the Rynox expedition saddle bags and as such will not be a problem in my case.
You are the very first person to wish me on the trip. Thank you very much
Thank you for bringing up a very important point. But unfortunately the bolts cannot be reversed in direction since it will damage the stock seat cover.
I plan to rectify the issue using dome nuts.
Thank you for the wishes.
DIY: Backrest for rider on the bench seat | Royal Enfield Bullet Standard 350-stainlesssteeldomecapnut.jpg
Safe Riding.
I have never seen this thing. So thank you for introducing this very useful contraption.
Actually I am using the rynox storm proof tail bag. Wanted something solid to lean on to, intermittently.
How did the Rynox H2GO pro rain pants perform during your trip ?
Thanks for pointing this out. Will try to grind it away or use some padding or wind it with parachord.
regards Arun
adrian is offline   (3) Thanks
