Re: Motorcycle Lubrication Points The very term lubricant and the intended use of that lubricant as a lube is equally branched out as the chemistry of the lube in question itself.
Coming to our topic, the important do-it-all lube to keep handy for any DIY-er at home is automotive gear oil preferably, 90EP. Gear oil has varied uses, it can be dabbed over anything that has two metal components sliding, meshing, penetrating and what not. Moreoever gear oil being thick, resists dribbling, holds on to the very part intended to be lubricated, most part.
Case in point, on a motorcycle, gear oil can be used..
1. Clutch yoke, pivot point and the clutch adjuster innards, helps smooth the clutch and lever play.
2. Gear oil can be used to lubricate your motorcycle chain, after it's been rinsed off of all the grime and muck.. Cheap and effective lubrication and prevents chain rusting for the most part.
3. A few drops of this on foot peg mechanism, all fours, would mean less creaky and smooth moving foot-pegs. Same goes foot brake pivot, a few drops on the pivot would smoothen the pedal play. And lots more.
4. WD40 also helps keeping the keyholes of motorcycle in top nick. When hard/brine water enters lockset mechanism, fuel tank cap hinges, control cables they turn creaky and the smooth continuous motion of them becomes sticky. Use of WD40 on these keyholes helps them increase their life and a very small drop of gear oil inside the keyhole post WD 40 treatment would make them brand new. Same goes for control cable lubrication, removing those cables and allowing oil to flow through the innards allows for a longer cable life and smoother feel. Solid Lubrication
Solid lubrication is where greases are involved, and these need to be carried out during every service or depending on the age of the motorcycle/vehicle. Greases are used where high sliding and friction are involved, i.e. like bearings, heavy load bushings, swing arm pivots. These cannot be opened frequently, so these areas should be graciously lubed when they're removed, preferably through a mechanic.
So, to keep it simple. Preventative lubrication is crucial in terms of keeping the motorcycle elements we use on a daily basis at top nick, which in turn makes for a smoother riding experience.
Cheers!
VJ |
