Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 29,647 views |
![]() | #1 |
BHPian Join Date: May 2022 Location: Bombay/Delhi
Thanked: 87 Times
| RE Classic 350 long-term performance Hi all, I am looking to hear from people who’ve been using the RE Classic 350 since at least the last year. I remember the old CI bullets were heavy but still came to around 167 kgs. At 195 kgs the Classic 350 is much heavier. Do you find it easy to handle this weight when you are out in the city? I assume it allows for stability on the highways, but is there any way you felt disadvantaged because of this weight out on the highway? I am also wondering how the bike will behave once it is loaded up with some luggage and there is a pillion on board. Overall, the Classic 350 gives one a sense of compactness while riding it. Is this because of the placement of the footpegs? Do you find that it is less tiring over long highway distances or not so good roads? Are the maintenance cost of the Classic 350 much higher than the other REs? In particular, is the newly launched Hunter cheaper to maintain over the long-run? Thanks! |
The following 7 BHPians Thank 2wheelsvaga for this useful post: | chinmaypillay, InControl, Omkar, pachchu77, rj22, RoadMonkey, Voodooblaster |
![]() | #2 |
Newbie Join Date: Aug 2022 Location: MUMBAI
Thanked: 56 Times
| Re: RE Classic 350 long-term performance Hi 2wheelsvaga, I’ve been using the Classic 350 reborn since Jan’22 and it’s been a good experience with the bike albeit with a few niggles here and there. 1. The bike masks it’s weight well on the highways and once on the move in general. Yes the bike stays planted at speeds of 80-100 kmph( not that it’ll go beyond it comfortably). 2. The pillion comfort is really good as I’ve done all my city commutes with a pillion on board 70% of the time and none have complained about pains even in peak Mumbai jams. The fact that my STORMBREAKER (yes that’s what I call her) is equipped with the optional touring seats helps the matter. 3. The maintenance has been to the tune of 2-3k depending on the type of VAS you opt for, I usually opt for Teflon coating(my usage involves a GG tank bag most of the times) as it restores the gloss and finish. Without it your regular service should set you back by 1800-2000₹. 4. RE service is usually a hit or a miss generally, and my experience has been the same with the brand. The drain hole near the fuel cap keeps clogging up frequently with no solution till date except for blowing pressurised air at regular intervals. The major issue I faced was with the rear brake making a heavy metallic grinding noise since Dec’22 and the service centre guys experimenting over every possible component at the back of my bike. The issue has been traced to a faulty calliper of the rear brake which is now to be replaced under warranty.( Many cases seen on YouTube) 5. But what I can assure you is this machine will take you back in time to the good old days of relaxed riding. I’ve taken the longer routes, or missed that turn to my home and also heading randomly for a short ride without a second thought. The classic 350 Reborn is for sure a keeper. I’ll be glad to help you with anything else that you might want to know. Cheers, Dr. Rishi S |
The following 20 BHPians Thank themotohead_doc for this useful post: | ani_meher, chinmaypillay, dkaile, DriverNo.420, farhadtarapore, InControl, KPR, Mrs&Mr_Shenu, pachchu77, RaceCyborg, rj22, RoadMonkey, sainyamk95, shiv11bhargava, SmartCat, SRISRI_90, Viju, Vikram9193, vishal.jayakuma, vj_torqueaddict |
![]() | #3 |
BHPian ![]() | Re: RE Classic 350 long-term performance Here’s my opinion as a RE Std Bullet 350[UCE] owner and it’s been my daily ride for the past 5 years. Yes the current crop of Enfields Bullet or Classic weigh approximately 200kgs and that holds true for both the current J series ones and the older UCEs. The weight is manageable in city traffic and out on the highways. Even in slow city traffic where everyone is moving at snail’s pace the weight of the bike is right at the centre which means you’ll be able to manage the bike while on stand still and even when zipping through traffic. Ofcourse you cannot compare the zipping through traffic with the likes of a Splendor or Activa but even then it’s highly manoeuvrable. With a firm footing while on stand still you can manage easily in start stop traffic without having to worry about tipping the bike off. On the highways the weight adds a plus point where you are more stable and crosswinds do not affect much compared to other lighter motorcycles. You are less likely to be thrown around by potholes at high speeds since the weight of the bike and the decent suspension smoothens out the ride quality. Weight can only be a hinderance if you expect to brutal fast acceleration (the likes of KTMs) and catch up speeds be it in city or out on the highway in which case you’ll be disappointed. It’s after all a cruiser and is meant to be ridden at decent speeds where the current J series fairs much better than the UCEs. Loading up the bike with panniers and top boxes gives no disadvantages and the bike feels as stable as it is when unloaded. The riding posture with respect to foot pegs is designed for comfort and you’ll rarely feel any physical strain while riding it. When it comes to maintenance my Bullet is serviced only at RE service shops and the maintenance and running costs are well within check. Expect the service costs to be around 1.5k for the first two years and around 3k after that. The current J series have a service interval of 6 months compared to my UCE Bullet which requires a service every 3 months or 3000 kms whichever comes earlier. This 3 months service interval is only specific to BS 4 UCE Bullets not including the Classic of same vintage. Pro Tip - If you’re really worried about managing weight at slow traffic speeds get leg guards for both front and back. They prevent the bike from completely falling over flat on its side and even if you manage to tip it the front and rear leg guards make sure that the bike only lands at around 45 degrees lean angle instead of a complete 90 degree flat fall. I’ve managed to tip it twice in slow traffic and it was completely my fault as I hadn’t set my foot down firmly. |
The following 6 BHPians Thank Skyline_GT for this useful post: | chinmaypillay, InControl, LongDrive lover, pachchu77, rj22, Voodooblaster |
![]() | #4 | |||||
Thanked: 87 Times
| Re: RE Classic 350 long-term performance Quote:
I notice that you’re based in Bombay. Given the high humidity and rainfall, do you notice any issues with rusting, or faulty electricals? Quote:
On a long cruise, I really don’t see myself wanting to go at more than 90 kmph. Quote:
Is it a huge difference between the standard and touring seats? Quote:
To be honest, my main interest in getting an RE is the extensive dealer network. I plan to go to the mountains quite a bit, and say, wouldn’t want to be stranded somewhere with a Honda CB350 haha! Quote:
The following 2 BHPians Thank 2wheelsvaga for this useful post: | vikas8890, Voodooblaster |
![]() | #5 | |||||
Thanked: 56 Times
I cannot comment on the difference between the two as I specced mine with the Touring ones from the factory itself. Quote:
Also your relationship with the SA’s at your regular ASC does help ease things a bit. Quote:
Also, I noticed Bombay in your location too. Would love to catch up for a ride someday soon. ![]() | |||||
The following 2 BHPians Thank themotohead_doc for this useful post: | InControl, pachchu77 |
![]() | #6 | |||||||||
Thanked: 87 Times
Do you think we can expect to see the weight being trimmed in the models to be released in the coming year(s)? Well, if the Meteor 650 is anything to go by, we should expect the opposite! Quote:
Last edited by aah78 : 25th February 2023 at 05:58. Reason: Posts merged. | |||||||||
The following 2 BHPians Thank 2wheelsvaga for this useful post: | pachchu77, themotohead_doc |
![]() | #7 | |||
BHPian ![]() Join Date: Oct 2014 Location: Pune
Thanked: 1,014 Times
I don’t think you will find it difficult to use in the city. The weight is well balanced and taking U turns is also a piece of cake. Also even at sub - 5 kmph speeds you won’t require to put your feet down in traffic, it stands straight. From my standpoint, it’s one of the easiest bikes to ride in the city and highway too. Quote:
Even the lighter Hunter has the same characteristics including the top speed. Quote:
The suspension is a little stiff, especially when compared to the UCE Classic but it provides more stability on the highway and also complements the more rigid and stiff platform. PS - I don’t own a Classic but have taken several extended test rides when it was launched. | |||
The following BHPian Thanks Waspune for this useful post: | pachchu77 |
![]() | #8 | ||||||||||||||
Thanked: 87 Times
| Quote:
I do want to ask if you think the touring seats make a big and obvious difference when it come to going out on the highway for several hours? Quote:
Btw, have you ridden the Honda CB 350? How would you compare its torque availability around the 70-90 kmph band, with the Classic's? Quote:
Unless I am wrong, you have to take the standard seats when you buy the bike, and you end up being forced to buy the touring seats as an after-market accessory. Such a bummer. Quote:
![]() In fact, contrary to common-sense perceptions such stable bikes can be relaxing to ride in city conditions too. The lighter ones tend to be thrown around too easily. The only issue is when you have to push or pull them with your hands. Or, of course, when you have puncture! Quote:
I am, however, curious as to how Honda have managed to eke out more power than the Classic from a similar engine design. Quote:
Last edited by SDP : 5th March 2023 at 11:31. Reason: Merging back to back posts. Please use the multi-quote option rather than typing one post after another | ||||||||||||||
![]() | #9 |
Newbie Join Date: Feb 2023 Location: Paonta Sahib
Thanked: 12 Times
| Re: RE Classic 350 long-term performance Although many members have beautifully answered your queries. I like to add my piece, I have owned classic 350 from 2015. Most consider Royal Enfield (specially UCE) unreliable but mine has not shown any major issues, only regular service is done. Regarding the weight of the bike, it can be a problem in incline when reversing (I'm 5'5) but other than that once you are habitual you can ride it in city easily. Also due to torque of engine, it can still manage 80-90 km/hr with a pillion.But you have to understand its not fast as KTMs and will not be helpful above these speeds. You will have to work the engine, which is followed by vibrations (Talking for UCE don't know about J series). Also regarding riding on gravel, one has to be careful due to weight at rear it can be slippery sometimes. Have met my fair share when I newly owned it. I have not installed tour seats but I regularly do 350+ km rides.(mix of city, highway and hills) With occasional breaks like after 75km (it is doable). So comfort wise its no problem. Moreover long rides also depends on ones physical fitness. Also gear ratios help certainly I will recommend to find a good local mechanics once your warranty period is off. It will be more cheaper and you will be spared from Service center attitude. I generally order engine oil online and then go for servicing to make it cost effective. Also I find the parts are cheaper compared to other bikes in this price range. My bikes routine service takes about Rs 2000-2500. Also if you decide to buy it, make sure to go to hills. Its torque is addictive. P.S. don't change exhaust. Some are very loud plus irritating and also illegal. Hope it helps. Regards Last edited by Sid_W : 26th February 2023 at 18:39. |
The following 3 BHPians Thank Sid_W for this useful post: | chaosengine, pachchu77, shiv11bhargava |
![]() | #10 |
BHPian ![]() Join Date: Aug 2022 Location: Bengaluru
Thanked: 176 Times
| Re: RE Classic 350 long-term performance I owned 2014 Model Classic 350 Silver for 7 years. The service interval for 2014 model was every 3-4 months and service cost is around 2000 to 2500. I previously owned a Bajaj Pulsar 135 LS and I redlined that bike in every safe chance I get and even potholes were not an issue for that bike. Now coming from that bike to classic 350 was a very big change and initially I could not cope with this change, I tried to ride Classic 350 in the same way as my Pulsar and soon every parts started to get damaged. In initial 2 years I faced lot of tappet noise, changed clutch system 2 times (Rs.5000 *2), chain sprocket changed, battery failure (if kept idle for 2 weeks), clutch wire broke 2 times, in slopes front brake failure due to overheat, slightest pothole will make the bend the spoke wheel (tired of spoke wheel bent I bought alloy wheels , now alloy wheel did not get bent but the bearing inside the wheel broke ![]() even after slow riding, in middle of heavy Bengaluru traffic that too during thunderstorm my bike's clutch wire broke 2 time and mechanic said its very common in bullet and always carry spare everywhere I go. Imagine you are stuck in redlight and every insane Bengalurians honking without understanding our situation. we cannot change gears without clutch isn't it. so wheels wont rotate. Lets take service cost as 2500 for every 3 months so like that if we calculate for 1 year then 2500 * 4 = Rs.10000 minimum (excluding parts change price). service is like maintaining a VW or Skoda car but less reliable ![]() I gradually understood that this bike does not suite me and when I saw classic 350 in every nook and corner like how bajaj pulsar series (especially 150) was in old times (every 6 bikes out 10 will be a pulsar, same is the case now with classic 350 ), I sold the bike in 2021 as the bike was not in use but was servicing it every 3 months and wasting money. I then bought a Pulsar AS200 from my friend and living happily |
The following 3 BHPians Thank DustyWanderer for this useful post: | ani_meher, HillMan, shiv4747 |
![]() | #11 | |
Senior - BHPian Join Date: Aug 2008 Location: Bombay
Thanked: 1,847 Times
As far as the CI 500 is concerned the torque generated by that motor was raw and like punch in the guts. The AVL LB500 bettered it further carried forward by the UCE 500. Sadly, RE has now stopped producing 500 singles. I always say this, "Once you ride the 500, there is no going back to a 350." Having owned RE's from almost all the era's except the 40's, all I can say is RE has come a long way from the days of CI to AVL to UCE to the new J series platform. My suggestion to you would be to rent the new CL350 (Reborn) as well as the Honda CB350 for a day and check the performance. If you are kind of relaxed rider who like to take in the scenery while going on a ride and want to do it in comfort then either of these motorcycles wont disappoint you. The CL350 (Reborn) can take on rough roads but it is primarily meant for the tarmac. Regarding the weight, I have noticed this with all RE's, that the weight disappears once the motorcycle sets in motion. However, one might feel the weight while parking, taking slow turns around steep inclines, declines, etc. For two up riding the CL 350 (Reborn) looks like a good choice compared to the Hunter 350. You can also check out the Meteor 350 as it is a good option for what it offers. Also remember if you are going to use CL 350 (Reborn) for extensive two up touring with luggage then it might have less juice compared to the Himalayan/Scram. P.S. Having owned numerous RE's I have noticed that periodic maintenance coupled with preventive maintenance keeps the motorcycles trouble free. Last edited by navin_v8 : 28th February 2023 at 11:35. | |
The following BHPian Thanks navin_v8 for this useful post: | pachchu77 |
![]() | #12 |
BHPian ![]() Join Date: Jan 2023 Location: Madras
Thanked: 363 Times
| Re: RE Classic 350 long-term performance Hi, I share my points which is absolutely my point of views. I have ridden many bikes in the 150 CC category prior owning RE Classic 350. Most of them owned by myself and my brother. HH Passion, CBZ Extreme, Hunk, Apache RTR, Yamaha FZ 16, Karizma. When I got relocated to Bangalore, I wanted a bigger bike with good pillion comfort. Hence I chose to buy RE classic 350 - Gun metal grey. Bike is much heavier than my other bikes used before(Obviously). I found it bit difficult at the beginning. I am 5'8 with 75kg weight. But once I started using it, I felt much comfortable. Pillion found it comfortable as well but not for too long. I have taken it for multiple long drives. Sometimes I found it hard maintaining the same 80 to 95 kmph even in empty roads. I sometimes lose my patience. I want to save the time when I find the empty roads. But vibration is bit higher post 100kmph. For my weight the bike was not suitable is what I felt. RE needs to be taken extra care all the time while riding. It needs to ridden with much patience and in a gentle way. For city use it was ok. For highways I did not find it comfortable for myself. I used it for almost 2 years. Once I relocated back to Chennai, I wanted to change the bike badly. First reason in due to KA registration which I did not want to use in TN. Secondly I reside close to sea. Most of the parts in RE started getting rusted shade. Hence I sold it and bought a Yamaha R3 abs which I find it much suitable for my style of riding. If you are a guy with a good patience level and maintain it well and dont expect a adrenaline rush type of rider, then yes RE is the right one for you. Hope this helps. Cheers SSB |
The following 2 BHPians Thank shiv4747 for this useful post: | 2wheelsvaga, huntrz |
![]() | #13 | ||
BHPian ![]() | Re: RE Classic 350 long-term performance Quote:
Year on year the maintenance becomes a headache and the bike becomes more unreliable. Everytime it comes from the workshop you would find one new issue. If you see how some of its components are designed you will laugh at it. Many times sourcing its 14AH battery too becomes difficult and it costs as much as a car battery lasting half as much duration. Unless you find a expert mechanic near your house(every RE owner has one on his fast dial) and plan to spend weekends with him ![]() Quote:
The following 4 BHPians Thank huntrz for this useful post: | DocWithWheels9, evil_grin, pachchu77, shiv4747 |
![]() | #14 | ||||||||
Thanked: 87 Times
But I am imagine these are not situations that one will have to deal with regularly. Of course, on the mountains things are different. Did you mostly face these issues while riding in the hills/mountains? Quote:
Can you elaborate a bit? I thought the classic 350 is quite well-balanced. Are you saying it's weight is biased towards the rear? Quote:
Also, I don't want to "waste" the standard seat by first paying for it, and then keeping it lying around, while I get the touring seat. Quote:
I suspect they are reduced to doing small things like oiling the bike, and general maintenance. But troubleshooting sensors etc. is not something they can do. So, how do you manage all that? Also, which oil do you use? Do you go with the RE recommended grade, or do you adjust according to local weather conditions? Quote:
I'd love to hear from you some experiences of how you use the RE gearing when you're in the mountains ![]() e.g. do you find you can manage with 3rd instead of 2nd most of the time? Quote:
The medium size exhaust on the classic looks nice, but the sound is a dampener. I do think, however, that that has more to do with the shortening of the stroke, rather than any changes to the muffler. | ||||||||
The following BHPian Thanks 2wheelsvaga for this useful post: | pachchu77 |
![]() | #15 | ||
Thanked: 87 Times
| Quote:
But I'd like to hear others' experiences here. Do those using the Classic 350 for the last two years feel the clutch cable wears out too fast? Quote:
In fact, that's why I put up this post. It does look like things have changed significantly with this J series engine. Last edited by SDP : 5th March 2023 at 11:32. Reason: Merging back to back posts. Please use the multi-quote option rather than typing one post after another | ||
