Design, Styling and Features
The Bajaj Pulsar N160 is very similar in looks to the 2020 Bajaj Pulsar F250. It's a bike that will suit a young first time biker - someone who is in college or just starting work. With a claimed mileage of almost 50 km/l, it will not burn the bank and still be a stylish commuter.
Visually, the only differences between the N160 and F250 are the front cowls and the silencers. The F250 has a visor at the front, while the N160 has a much shorter silencer. The indicators are completely different. But everything else is very similar and to the untrained eye, it can be difficult to tell them apart. This may end up creating confusion among potential buyers.
The N160 looks good. The black colour complemented by the red and white streaks is neither garish nor distracting. The styling borrowed from the more expensive F250 works well:
F250 with its Visor and indicators placed below the handlebar:
N160 without the visor and much higher set indicators:
The front end is a bit controversial. It looks like a one-eyed Mahindra Mojo. The indicators are moved way up to be almost at the same height as the handles:
Headlight is bright. Since I was only riding in the rain during daytime, I found myself a nearby mall with underground parking, took the bike into the dark parking lot and checked the effectiveness. There will be no need for auxiliary lights on this bike:
Rear view mirrors are big:
They work well on an open road and provide a good view of the traffic behind, but I found things a little difficult when navigating through stopped cars at a traffic light:
Radiator for the oil-cooled engine is smartly tucked in and looks safe from physical damage:
Crashguard has a simple and non-intrusive design. All the wiring is packed beautifully. There are no sharp edges or difficult to access parts. This bike will be very easy to clean:
17" alloy wheel at the front shod with an MRF 100/80 section tyre. Fork get orange reflectors on both sides:
Big 300 mm brake disc at the front with stickering to indicate the precence of a dual channel ABS setup:
A close look at the detailing on the side:
164.82cc single-cylinder engine churns out 15.78 bhp @ 8,750 rpm and 14.65 Nm @ 6,750 rpm:
Equipped with DTS-i system:
Cute silencer does not intrude into the pillion leg area:
Footpegs force you to adopt a knee bent position:
Main stand is sturdy and can be deployed quite easily by a rider without getting off the bike:
Big rubber stopper has been provided on the main stand:
N160 stickering on the rear panel:
Saree guard is functional. It's mandated by law, but I have no idea what its use is with alloy wheels:
Rear wheel is also a 17" alloy unit. It comes with a 130/70 section tyre. Rear brake is a 230 mm disc:
No protection for the rear disc brake oil sump. But its placement makes me feel that someone will have to be very unlucky to damage it after a fall:
The single rear shock absorber is adequate and my weight was not an issue for it. So, I am guessing two college kids will be more than comfortable on this bike:
Tail-lamps are nice and bright:
Solid grab handles at the rear look great. At 154 kg, this is a heavy bike. I have a little test I always like to perform on new bikes. Stand next to the bike, hold the grab handle, lift the rear wheel and try to push the rear away by a couple of inches. This is something anyone who has parked on crowded city roads needs to master. This bike is quite well balanced and passed my completely unscientific but useful test:
Sleek rear turn-indicators:
Instrument cluster is quite barebones. It lights up with all the myriad indicators and then settles down within a few seconds. The tachometer takes up most of the real estate. The numbers were a little difficult to read in the heavy rain conditions. There are no smart connect features. Just the usual battery, CEL, speed, rpms, time and the gear indicator:
Standard ignition and key:
The clutch is super light to use - a blessing when stuck in traffic jams:
Controls on both sides are placed in a standardized manner. So, there wil be no issues in finding whichever button you need:
Quality of switchgear is acceptable and similar to what we have seen on other Pulsars:
USB charging port is a new feature and very useful in our increasingly smartphone driven world:
Fuel cap lock is protected under a cover:
The seat is comfortable and though the rear seat is a little higher, it's not the weird type that makes a pillion look like
Betaal sitting on King Vikramaditya's shoulders. Saddle height is 795 mm:
![](https://www.team-bhp.com/forum/iipcache/166659.jpg)
