Re: A lightweight adventure bike for 5'6", which is easy to maintain Quote:
Originally Posted by four.bytes I have been following this YT channel- c90adventures. |
YT channels have inspired a lot of people to travel, albeit on 2 wheels or 4 wheels.
Couple of years back, i too was in the same boat. I own a Scorpio 4WD and was planning to do a RTW tour, but realized that paper work, fuel, maintainence would be expensive, complex and time consuming. So had to put the idea in deep freeze.
Some recent turn of events led me to pick up motorcycling, that's when i bought the idea out of freeze and started planning again, this time on a motorcycle.
My thoughts are in the same line as others have mentioned in this thread. I bought a locally manufactured, simple ADV - Himalayan last year. The only other consideration i gave was XPulse (only 2v then), but ruled it out as i felt it was everything on the lower side (highway cruising, luggage capacity..)
My plan now is to ride the bike across the state, the country understand the issues, learn the fixes, modify the bike to my needs and then go international.
I feel weight should not be a problem with proper techniques unless you are alone in high altitude areas.
So, as others have suggested, get a simple engineered bike, ride it across the country, learn how handle it, make some modifications to suit you and then make your plans for RTW.
Apart from current Himalayan, Scram, Xpulse or Dominar you might want to wait for Himalayan 450 and see if it's any lighter. |
