Team-BHP > Motorbikes
Old 20th May 2022, 01:21   #1
Thanked: 147 Times
How does the fully-adjustable suspension of motorcycles work?
I have all the theoretical knowledge about pre-load, rebound damping and compression damping but i have one question.
On most the bikes we get rebound adjustment on one fork and compression adjustment on another fork but how does changing the setting on one fork is making adjustment on another fork?
phoenix.rider is offline   (2) Thanks
Old 20th May 2022, 09:31   #2
NoSugarNoSpice's Avatar
Thanked: 404 Times
re: How does the fully-adjustable suspension of motorcycles work?
Originally Posted by phoenix.rider View Post
... how does changing the setting on one fork is making adjustment on another fork?
It does not. The front forks are mechanically linked between the wheel axle and the triple clamp. When leaning over, the forks stay the same length, since the axle and triple clamp stay parallel. What one fork does, the triple clamp makes the other one do. So the rider does not perceive any independent feedback. Coming to adjustable suspension, these are the parameters that are generally adjustable
  • Spring
    1. Preload
  • Damping
    1. Compression
    2. Rebound
    3. High-Speed
    4. Low-Speed
Now remember the forks are 'clamped', so what one fork leg does, the other will ape it. Some engineer got the genius idea to have one fork do the springing stuff and the other one to do the damping stuff. Turns out it's a bit more robust and even cheaper and a hell of a lot SIMPLER. And these were aptly christened Separate Function Forks.
How does the fully-adjustable suspension of motorcycles work?-separatefunctionforks.png
Now this may not always be the case. Some manufacturers are ok with duplication since it saves them the hassle of making, maintaining and stocking twice the number of fork internals. Maybe, they think printing a warning in the manual saying it's the rider responsibility to keep both fork settings the same otherwise it may lead to loss of life or limb, is fine. Maybe they don't want all the back and forth(pun intended) with a customer when the dealership jams 2 spring legs on his bike.
Pic source - https://www.bikesrepublic.com/featur...do-forks-work/
NoSugarNoSpice is offline   (18) Thanks
