Motorbikes
Intro.
This is my ownership review of my Duke 390 (The Beast). I was never a bike person for a long time, the love was more of cars, in 2019 the love for bikes started with the Duke 390 1st gen.
Search for the bike
In the year 2020, I decided to buy a bike, I had considered buying a new Duke 390, after some thought and consultation I decided to buy a used 1st gen 390 as it would be a better choice as I loved the nature and character of the 1st gen. So in July, the search began by looking through Olx, Team-bhp classifieds, Instagram, and others. Most of the results which showed up did not impress me, as they were shady, overpriced, too good to be true examples the good ones were already sold before I could strike a deal. By the end of July, I asked my close friend that I was looking for a used 390, and luckily he knew someone in his circle who was selling his Duke 390 and it was within the budget. So we decided to check the bike out on 2nd August.
On a bright afternoon of 2nd August, we both go to check the bike, arriving at the location we meet up with the owner and had a chat, he then led us to the bike, started inspecting the bike. After the inspection we both were sure that the bike's overall condition was good, the ODO reading was 13700, the only aftermarket accessories were the Bosch horns, the other two accessories were the battery tender connecter and hazard flasher which he kept after I bought the bike.
Satisfied with the bike, checked the documents they were all clear. The owner mentioned that the clutch needs to be changed, that amount had been deducted, asking price for the bike was 1.2L as the owner was a known and good mutual friend, the price was brought down to 95k including the clutch job. Paid the token amount and took the bike to its new home, the remaining amount was paid the next week.
History of the bike
The history of the bike is a mystery, the first owner was a Parsi pilot who purchased it on 13 March 2014 and it was barely used till 2017, it clocked around 6km. The instrument panel had been changed somewhere around 2016, ODO reading on the instrument cluster and ECU is off by 2000 km. There is no service records of the bike in the system from 2014 to 2017. When the bike was bought by the second owner it was serviced at the SVC and all the records were there. The mystery part to the bike is that the chassis number has been changed for some reason by the first owner and the document for the change is there, so that turned out to be a relief and the transfer happened without a glitch.
Likes
- The engine & gearbox combination.
- The reasonably priced spares exclude some main components.
- Strong brakes, with sintered pads and better brake fluid.
- Good handling, communicates with the rider .
Dislikes
- The instrument cluster at times is unreadable under direct sunlight.
- The engine under 3k RPM is lumpy and unhappy.
- The heavy clutch, it's an annoyance only in traffic.
- Candlelight headlights, barely light up the road ahead.
Engine and Gearbox
The engine is a 373cc signal cylinder pumping out 43 horses and 33NM of torque. It is a rev-happy motor and raw power silvery combined with a smooth gearbox. The bike is a bit unhappy under 3k RPM at 30 Kmph on 2nd gear combined with the heavy clutch. Past 3k it pulls effortlessly and once it hits its sweet spot 4.4k to 7k it becomes a different animal, it throws the rider back and wants to pop wheelies at almost every gear, in the same sweet spot it can be ridin in a calm with smooth throttle inputs combined with the cable operated throttle, according to me it creates a direct connection to the rider and bike. False neutrals are rare and If it does happen it is due to not engaging the clutch properly or not rev-matching correctly. Neutral is easy to find just need to tap the gear lever gently. 1st to 2nd vice versa needs a little more force, the rest of the gear's slots in nice and smooth. The downside of the engine nature is that in traffic a lot of engine heat is diverted to the leg and inner thigh area, which can get very uncomfortable the only plus side to heat is when it rains and the pants become wet, it can be used to it dry up.
The exhaust note is rattly, loud, heavy and bassy at idle, once on the move, it becomes smooth and has a sweet whine to it. When riding hard its tone becomes aggressive, during downshifting it has a mixture of whining and subtle pops.
Fuel Tank
The Bike has a 10L fuel tank out of which 2L is reserve.
In the city it gives a mileage ranging from 4 Kmpl to 19 Kmpl and a range of 60 Kms to 140Kms
On the highway the mileage it returns ranges from 24 Kmpl to 32 Kmpl and a range of 300 kms and in very rare cases it delivers 42 Kmpl depending on the road and speed its doing.
Handling and braking
The Trellis frame makes the bike feel nimble and handles almost any road conditions which are thrown at it, on long open highways it feels planted and inspires confidence while changing directions and attacking turns. Even riding on rough patches and slight off-roading it communicates in a decent manner with the rider.
While riding along with a passenger, especially with a heavy person, there's a lot more pressure on the hands while changing directions and taking U-turns. The extra weight increases the braking distance. All in all the bike is meant to be be solo as it performs much better.
The Duke 390 comes with Dual-channel ABS as standard, braking duty is done by 300 mm disc with four pot caliper in the front and 230 mm disc along with single pot caliper at the back.
The brakes on the 390 provide a good bite and feedback while pressing the lever and the bike stops
Without much drama, even during panic braking, it will hold its line and not lose control. ABS is more intrusive on the rear compared to the front.
Wheels and tyres
The bike is currently running on Michelin Road 5's. It's been in the bike for 5 months and 3000 kms and I'm impressed with the tyres.
Ergonomics
The rider sits upright with a slight forward lean a comfortable hand leg placement, a decent rider triangle. Gripping the tank with knees is fairly easy and adding tank grips will make it more comfortable and will provide more confidence. The hands fall in place on the handlebar with ease and does not give any discomfort on the wrists and arms.
The stock mirrors of the first-gen Dukes are hopeless and barely provide any view of what's happening behind you, shoulder checks are needed to make sure there aren't any surprises waiting. I replaced the mirrors with the ADV 390 mirrors and provide a decent improvement over the old ones as the stalks are higher and wider compared to the old one.
Side stand is easy to operate and find, if the shoes has a nice horizontal groove, it can be used to slot in and engage the stand.
Ride quality
With the stiff front, soft rear, and 17-inch rims the ride quality can be harsh on rough, slightly bumpy roads, all these conditions make the ride feel uneasy and demotivating.
Once on a smooth road, the stiff suspension setup makes the ride pleasant, enjoyable and inspires confidence to ride the bike as it is supposed to be ridden.
NVH
The vibrations are present in the rev band from 1.8k -to 4.5k, which makes you feel that you are riding a single-cylinder engine, post 4.5k till 7k the vibrations reduces to a level where it is not felt much.
The NVH reacts to normal octane, speed and XP95 differently, on normal petrol the vibes and harshness are more and felt throughout the rev band. On XP95 is smooth.
Styling and Build quality
The Duke 390 takes styling cues from the bigger Duke 690. Styling is a mix of edgy, bulky, edgy and aggressive design. There is nice body lines are flowing through the body panels merging with the lights and seat. The orange frame and wheels along with the decals, underbelly exhaust and piece of art swingarm, gives the bike a nice sporty and clean look.
Fit and finish is ok, at some places the panels do not sit flush and there some
squeaks and vibration sounds at low speeds.
The paint has a nice deep black gloss and blue metallic flakes in it, which is present only in the black color Dukes. The downside is that the paint is prone to scratches.
Switchgear and Instruments cluster
The switchgear layout is a basic Bajaj pulsar layout with backlit buttons the only difference is that the KTM ones are white in color and Bajaj ones are in blue. The switches are easy to find and operate.
Instrument cluster is a nice orange backlit color and displays a good amount of information like distance to empty, kilometer's left for next service, average time and speed, mileage and more. It includes two trip meters l and a clock which is a pain to set up. If any any problems are detected in the bike it displays it. Readability in normal and night riding is not a problem, but if ridden on a sunny day it becomes difficult to read what's goin on.
The main focus on the instrument cluster is the speed then the gear position and R.P.M
Usage patterns
At the start of purchase it had been decided that it will be my daily to office which is 20km for 5 days and weekend rides, the bike used to clock close to 1000 kms a month. Now with the current rising petrol prices it is used only on weekend breakfast ride or late night/early morning city rides.
Lights
Lighting is handled by a LED setup except the headlight. The indicators and taillight unit are nice and bright, the license plate hlder light throws a nice strip of light on the road below.
Headlight throw is adequate and does not inspire confidence at night as it barely illuminates the road ahead.
Work done so far Brakes.
In the initial ownership period the Front brake disc was changed as it was bent along with bleeding the system, new brake pads and new axle and bolt.
Later on the ABS pump had failed so got it replaced along with got brake pads upgraded to sintered pads and fluid to 5.1. Recently changed the master cylinder, the result is now better feedback and bite. Cost: 30k
Tyres
At the time of purchase the bike came with Metzeler M5 Sportec, 7 year old in the front and 4 year old one in the back, used this setup for 8 months. Later on got the front changed to Apollo H1. In January 2022 got a Michelin Road 5's put on the bike.
Cost:21k (including the front Apollo)
Clutch
The previous owner had mentioned that the clutch needed to be changed. The reason the clutch wore out prematurely, is due to the rear brake master cylinder. So got the rear brake master cylinder and clutch and friction plates changed.
Cost:6253
Airbox
As the bike was 8 years old and had some running, it started developing cracks.
Cost:1669
Engine hanger
The left side engine hanger was split into two. Got it replaced as a pair.
Cost:1041
Forks
The forks had never been serviced in it's life, so got it serviced by changing the seals, fresh oil and the oil used was liqui Moly.
Cost:4500
Total: I have plonked alot of money on the bike :p
At the time of writing this review, the bike stands at 26315 KM's on the ODO.
Here the bike chilling with the Duke which taught me to ride a bike and fall in loove with them.
Cheers.
You can get the heavy clutch changed to the post 2015 models slipper clutch a the service station. I got this done for my 2014 390, and it cost me just a shade over Rs. 5k.
Love this bike to bits. Mine was of a similar vintage. Had loads of fun and a lot of learnings from this bike. I Miss this bike and regret selling it. :disappointed
Originally Posted by Dhruv Shetty
(Post 5160609)
The history of the bike is a mystery, the first owner was a Parsi pilot who purchased it on 13 March 2014 and it was barely used till 2017, it clocked around 6km. The instrument panel had been changed somewhere around 2016, ODO reading on the instrument cluster and ECU is off by 2000 km. There is no service records of the bike in the system from 2014 to 2017. When the bike was bought by the second owner it was serviced at the SVC and all the records were there. The mystery part to the bike is that the chassis number has been changed for some reason by the first owner and the document for the change is there, so that turned out to be a relief and the transfer happened without a glitch. |
Firstly, Congrats on the bike:thumbs up
It seems a bit odd as you mentioned that there is no service history available from 2014 to 2017. Surely the guy must have done the 1st 3 free service from the dealership.
Also if the chassis number is changed chances are the chassis was broken or damaged and hence replaced.
I don't want to insert doubts into the mind of the new owner, but my 2013 Duke 390 has now done 80,000 kms, ridden safely and carefully, and its still on original clutch plates.
Why is yours demanding a change on 13,xxx kms even if we're to add 2000 kms to it, still doesn't demand a clutch change?
Dhruv, simple and heart out. This is one such motorcycle one would regret selling, especially who's experienced hands-on what it has to offer. Barring a few kinks in the armor, this is undoubtedly the one for great feel good factor, unlimited fun and adrenaline rush like no other at a pocket friendly price. And at the price you've gotten, it's a steal, though, KTM stole most of it back in a different way. :D
You can replace the older non slipper clutch unit to a slipper clutch unit which makes the clutch pull light by miles, and reduces wheel chatter for the engine braking this thing produces, would set you back by 5 to 6k (IIRC, quote from memory) is a direct plug and play. 100% recommended, if your daily grind includes chock a block traffic. I did infer that the chassis was replaced. Usually chassis replacements are carried and deemed necessary if the chassis is bent in any way shape and form, and a chassis bend occurs only during a crash that was intense enough to deform it, and same goes for the instrument console. The bike did seem to be involved in a frontal collision, hence the chassis and odometer replacement, but that investigation is for another day.
Enjoy the ride, keep her in great shape, and she'll reward you like no other. A simple, fuss free no-non-sense motorcycle. You've made a fantastic choice with the Road 5s. Road 5s are one set of tires I see and hear getting kneeling praises from biking fraternity gamut all over.
Good luck.
Cheers!
VJ
Last November, my 2013 Duke completed 8 years. Due to the pandemic, the bike was not used much. I had a bunch of work done to bring the bike back to shape. Two things which I did and would highly recommend are:
- Seat: The gen 1 dukes came with hard seat. Over the years, the seat cushioning had hardened so that it was almost like sitting on a slab of wood. I got the D200 last gen seats. These are direct fit and have a bit of cushioning.
- Chain Sprocket: I changed the chain sprocket (15-45) to the ones from Duke 250 (14-46). This translates to just about 10% transmission change but the bike accelerates even more freely now and the snatchy low-end throttle response is almost gone :D
Another advantage is that you can use the 6th gear even at speed of 90 kmph. Do note you will lose a bit of top speed.
My biggest regret is not doing this modification years back.
Originally Posted by VijayAnand1
(Post 5327661)
Enjoy the ride, keep her in great shape, and she'll reward you like no other. A simple, fuss free no-non-sense motorcycle. |
Cannot agree more! Other vehicles will come and go but the D390 will be forever bike :D
(Post 5327661)
Good luck.
Cheers!
VJ |
I'm not even sure if the chassis has been changed, as the old VIN number has been scrubbed off and a new a VIN number has been stamped next to the old VIN, maybe the owner didn't like the VIN :p
Switching to a slipper clutch is on the cards for the future, till then I'll enjoy the standard clutch.
Originally Posted by Samarth 619
(Post 5327579)
Why is yours demanding a change on 13,xxx kms even if we're to add 2000 kms to it, still doesn't demand a clutch change? |
Even i was pretty puzzled on how can a clutch wear out so soon. According to the SVC technician the rear brake master cylinder was the culprit for the premature wear.
Hey Dhruv, congrats on getting the ownership review of your bike live on the forum. The 2013-14 390s were a different animal altogether and it’s great to see you take the time and effort to maintain it and get the bike back to the way it was when new, and in some ways better than new.
Hope to see you soon on the next ride together!
Cheers,
TheDarkKnight
(Post 5327830)
Even i was pretty puzzled on how can a clutch wear out so soon. According to the SVC technician the rear brake master cylinder was the culprit for the premature wear. |
What you mentioned about VIN is scary to say the least, but anyhow coming to the point.
How is rear brake master cylinder related to clutch wear? Does the person mean that the brake is constantly engaged and this resulted in clutch wear due to extra pressure applied on the engine?
But its a very far fetched, and more likely a wrong conclusion. I've carried 3 people on a KTM, which is too much of pressure on the engine.
Plus, carrying the bike in higher gears at low rpm, or pressing half clutch to not stall the bike, also puts stress on engine, but that isn't likely to be the reason for this quick of wear.
More often than not, such extreme clutch wear happens only on bikes used for stunting, extreme-pressure commuting, etc.
Anyhow, don't worry about anything. You've replaced the plates, this should be good enough. This would be my last post on this matter, I hope I'm not spamming the forum with continuous replies.
Originally Posted by TheDarkKnight
(Post 5328132)
Cheers,
TheDarkKnight |
Thank you mate, it did take a quite while to pen down this review. Some say i maintain the bike like a Bawa :D.
Sure man let's plan a ride soon.
Cheers,
Dhruv Shetty
Hey Dhruv
Congrats on your ride, it was nice running into you at X-Shaft. Now with the new chain and sprockets, the gearing and shifting will be crisp.
Have fun and wish you loads a smiles with the bike.
Hiren
Update
Recently got some work done on the bike.
1. Did a D.I.Y respray of the frame as the paint was fading and the main reason was the rust, especially on weld areas. Finding a shade of orange which comes close to the KTM orange took quite a while to find and was contemplating wheather to paint it or not, in the end i just went for it.
Did some dismantling on Friday night after coming back from work and a farewell party of a team member from the office
First thing in the morning after breakfast removed the rest of the parts.
Hall table used as part storage.
Next prepping the paint by sanding, cleaning, primer and putty, and masking the bike up. I used Zinc primer to cover the bare metal to prevent any rusting.
Used more primer and putty on the left side as it had alot more rust
Doing this portion was the toughest due to all the cables and brake lines
Next up painting, first used white spray paint over the primer as base layer so the orange doesn't look dull, then started applying 6 coats of orange, i was alternating between dark orange and light orange, last coat was light orange.
After the orange dried, sprayed 3 coats of clear.
During this process i was taking a 10-15 minute gap between each coat and catching fresh air.
The spray cans used on the bike
Finished painting the bike at around 9 o clock at night and decided to call it a day and assemble the Duke on Sunday.
The next morning
After the usual morning routine, got the necessary tools for assembly out.
Putting back the bike together was fun, as i had to route the harness, zip tie the harness, mounting the tank and connecting the lines to it and tried not to scratch the fresh paint, in the end i scratched the paint :p.
Fitting the headlight part was the toughest as i did not place the harness properly. Took me 1 hour to get it or more rl:
And here's the end result
Next post is going be some much needed mechanical work and recent ride to Upper Vaitarana Dam.
(Post 5368278)
1. Did a D.I.Y respray of the frame as the paint was fading and the main reason was the rust, especially on weld areas. Finding a shade of orange which comes close to the KTM orange took quite a while to find and was contemplating wheather to paint it or not, in the end i just went for it. |
That is a lot of work, and an impressive end result.
I see that there is touch up paint kit that is available for the KTM orange. The next time there is a chip, or rust, perhaps you can touchup with the orange, and cover it with the included clear coat. Hopefully that is a long time away. Enjoy your ride!
