Team-BHP > Motorbikes
Old 18th March 2021, 22:15   #1
Shonith's Avatar
Thanked: 254 Times
Made a small visor / display cover for my KTM Duke
I have been looking for a small visor for my 390 since the time I bought it in 2019. Unfortunately, most of the visor in the market are for the previous generation 200 & 390. There is 1 visor for the 390 Duke but its too big for my liking.
So had to think of a way to make a visor as per my requirements. It so happens that the speedocover of the previous generation gixxer 150 is perfect for the 390s display.
However, you need to get the front indicator brackets from the RE classic and use it as a bracket on the indicator of the duke. Make 2 holes on the cover in line with the holes of the bracket adjusting the height of the cover with respect to the display as per your liking. Use spacers and long M6 bolts with rubber bushing to mount the cover on the bracket.
I have fixed the number plate on the cover itself just like the gixxer. I haven't found any other suitable location for the number plate as of now.
Parts used:
1. Gixxer speedo cover.
2. RE classic indicator brackets
3. Rubber bushing from Yamaha RX100 side cover
4. Number plate bracket from gixxer
5. M6 bolts
6. Spacers (its jugaad)
I hope this helps whoever is looking to do something about that bare empty look on the front end of the Duke.
Made a small visor / display cover for my KTM Duke-20210310_114308.jpg
Made a small visor / display cover for my KTM Duke-20210318_215604.jpg
Made a small visor / display cover for my KTM Duke-20210304_184330.jpg
Shonith is offline   (22) Thanks
Old 1st April 2021, 15:29   #2
Urban_Nomad's Avatar
Thanked: 2,389 Times
Re: Made a small visor / display cover for my KTM Duke
To me, it looks like someone put a toupee on Johnny Sins
The install is clean though and I am sure it will find many takers
Ride safe!
Urban_Nomad is offline   (2) Thanks
Old 1st April 2021, 19:32   #3
Vignesh_N/A's Avatar
Thanked: 314 Times
Alternatively, you can also use Bajaj AS200 Visor.
Made a small visor / display cover for my KTM Duke-inked20201205_15461102_li.jpg
Vignesh_N/A is offline   (6) Thanks
Old 1st April 2021, 19:50   #4
Thanked: 66 Times
Reminds me of the modifications made by a fellow tbhpian and a good friend of mine rider60:
https://www.team-bhp.com/forum/motor...ml#post1868559 (Honda Unicorn - Cosmetic and Performance mods - please give your views (Pics on Pg 9))
Hope this thread helps in getting new ideas.
kkr2k2 is offline   (1) Thanks
Old 5th April 2021, 19:04   #5
VijayAnand1's Avatar
Thanked: 3,047 Times
Clean mod for the bits included. The bike would look better if the license plate is removed and the number stickered on the visor (just my liking). As I always say, self help is the best help.
Cheers!
VJ
VijayAnand1 is offline
Old 5th April 2021, 19:10   #6
condor's Avatar
Thanked: 16,191 Times
Originally Posted by VijayAnand1 View Post
The bike would look better if the license plate is removed and the number stickered on the visor (just my liking). ...
However, per current rules, the licence number must be on a separate plate.
Do keep an eye out
__________
13000
condor is online now   (1) Thanks
Old 5th April 2021, 19:25   #7
Do keep an eye out
__________
13000
Haha! Absolutely true that. I mean, it would have looked cooler that way. Of course I am a law abiding city-zen.
Cheers!
VJ
Old 5th April 2021, 22:38   #8
EshanS's Avatar
Thanked: 185 Times
Or you can buy this one from Amazon for Rs 1900. It's a simple DIY, took me half an hour to bolt it on the bike. Wind buffetting up to 100kmph or even 120kmph is good. Anything beyond these numbers is felt directly on the neck and head. Comes in Orange, smoke, transparent and black colored options.
Made a small visor / display cover for my KTM Duke-img_20200619_180644.jpg
Made a small visor / display cover for my KTM Duke-img_20200620_163901.jpg
Made a small visor / display cover for my KTM Duke-img_20200802_165416.jpg
Made a small visor / display cover for my KTM Duke-img_20201024_082926.jpg
Made a small visor / display cover for my KTM Duke-img_20201118_082835.jpg
Made a small visor / display cover for my KTM Duke-img_20201122_133741.jpg
EshanS is offline   (5) Thanks
Old 6th April 2021, 00:49   #9
Thanked: 1,604 Times
Attachment 2141010
I think the OP may have meant this when he said he doesn't prefer the one which he finds too large for his liking
I have the same one as you but in black. Yes, the visor is rock solid at speeds around 130 km/hr
Made a small visor / display cover for my KTM Duke-img_20201213_140941_6932.jpg
rahul4321 is offline   (2) Thanks
Old 21st November 2021, 12:14   #10
Shonith's Avatar
Thanked: 254 Times
Parts used:
5. M6 bolts
I am giving an update on the visor mod done on my 390 duke, It seems like a logical thing to do. After using the visor for a couple of months It was quite evident that the set up didn't work as well as i hoped it would . For one, both the mounting points are a bit too low hence there is a lot of vibration on the top part of the visor. It tends to vibrate against the display It's annoying to see the visor vibrating like that .
And due to the excessive vibration one of the mounting bolt came loose on a ride and the rest of the ride I had to make sure that the visor didn't come off completely, an unnecessary ordeal. This was fixed by using self locking nuts. But I couldn't fix the vibration issue of the visor.
After a few months, I decided that the set up wasn't worth keeping on the bike. Since, it made the set up look not all that well put together. So I decided to remove the visor.
Visor has been since removed and the number plate is directly mounted on the bracket that I used to fix the visor
Made a small visor / display cover for my KTM Duke-20211024_172325.jpg
Made a small visor / display cover for my KTM Duke-picsart_112111.59.22.jpg
Shonith is offline   (3) Thanks
Old 26th November 2021, 14:49   #11
You can use the MT-15's aftermarket visor. They fit the Duke 390 without any major hassle.
Last edited by libranof1987 : 3rd December 2023 at 17:06. Reason: Trimming quoted post. Kindly quote only relevant sections of the post.
Dave495 is offline   (2) Thanks
Old 26th November 2021, 19:19   #12
Shonith's Avatar
Thanked: 254 Times
Thanks Dave I'll definitely take a look.
Shonith is offline
Old 2nd December 2023, 12:13   #13
saikishor's Avatar
Thanked: 2,904 Times
Shonith, are you using the gen 1 390 Duke mirrors? The mirror arm looks noticeably smaller. Are they any better in visibility or worse? I prefer these shorter arm mirrors over the ones on my bike.
saikishor is offline   (1) Thanks
Old 2nd December 2023, 13:42   #14
Thanked: 2,717 Times
Please make sure the visor is plexiglass and has some flex. These days tons of visors are acrylic made which can Crack and result in sharp edged pieces.
Nilesh5417 is offline   (1) Thanks
Old 3rd December 2023, 01:39   #15
Plexiglass and acrylic are basically the same for the most part. Polycarbonate are comparatively stronger but the only grouse being they get scratched far easier than an acrylic. Acrylic visors are simply a waste of money. They fade, they become brittle exposed to sunlight, they also incur fissure cracks and look garish over time. Polys are the best choice.
Cheers!
VJ
VijayAnand1 is offline   (1) Thanks
