3000km Update !!
Covered a lot of kms thanks to a large road trip. Took the bike from Palghar - Nashik - Vadodara -Palghar over a span of 4 days. Sharing the route below.
Bike performed exceptionally well. The build quality shined through. Went through some really bad gouges (Yes I know, pothole seemed a nicer description) at about 70kph. The impact felt so bad, I thought I would lose my rims or suspension. Thankfully nothing happened.
Overall I am getting excellent mileage even after ripping through the highways at 100-110kph. Below is the total trip reading since taking delivery.
Issues observed -
1. I never noticed this until the highway run, but the bike makes a howling sound when at speed on a empty highway. Sounds exactly like how a truck tyre sounds at high speed on highway. Nothing concerning, its just that once you hear it, you always get it even on local roads, albeit less pronounced.
2. I almost had a run in with an Activa riding squid in Nashik (thanks ABS). Only my right mirror came in contact. Post this, that mirror now starts shaking after 110kph. Left is fine. No idea what's wrong. Will have the SVC check it out soon at 2nd service.
Modifications Made 1. Ceramic Coating - Soon after first service, I decided to go for a ceramic coating since I could already see minor scratches from just normal usage. It only cost me Rs.4500 for a 9H coating backed by a 2 year warranty.
2. Tank Grips - I had actually ordered this long back, but was waiting for the ceramic coating to get done. They help tremendously in maintaining grip while braking or cornering. The tank pad helps in preventing scratches.
3. Underseat seals - Now this is bound to be controversial. But it has helped a lot in weather-proofing the bike's internals, especially the battery compartment.
How to apply - You will require a double sided tape (also called tissue tape), fine pointy scissors and rubber tubing. This can be bought from bicycle repair shop owners. It is the tube they use as valve tubes in bicycle tyres. Now, first measure the length of tube you will need. I used about 4.5 feet. Its probably good to get 5 feet of tube incase something goes wrong.
Next, take the tube and measure the runs for the underseat area. Note that you cannot cover all the sections, so target the ones you can access. Next, cut the tube along its length for each run. Now comes the tricky part. First you have to make all your cuts for all runs. Then take the double sided tape, and start cutting the straightest parts. Dont bend the tape, it will come off. Start applying the tape on the edges of the underseat. Half tape on top, other half folded over lengthwise over the body. This will take time and a lot of patience. Once done, peel off the top protective layer slowly and carefully. Now immediately apply the tubing by opening it up and wrapping it over the tape. The reason to cut the tube is for clearance issue. The seat wont close with the whole tube applied. I tried
![Frustration](https://www.team-bhp.com/forum/images/smilies/Frustration.gif)
Repeat this process until you have covered all the accessible area under the seat. Some areas you will have to be creative for the tape and tube to work but it can be done. Finally check all the tube runs, if any have come off, press and hold for some time. If still not holding, replace the tape with a fresh cut.
Post this put the seats back on. I strongly advise leaving it for some time, about a day in the sun if possible. Then go for a ride. Take a pillion if you can. The weight seals the tube firmly in place.
Headlights - I honestly dont know what to say. I spent almost an hour with this to no avail. The adjustment just doesnt have that much impact on visibility. Nor you can adjust freely. The range is pretty limited. I am posting the panel and screw location for horizontal adjustment, but as always, if it ain't broke, don't fix it.
Conclusion - Overall very very impressed with the bike. I was almost nitpicking and looking for issues, but the bike has always triumphed my expectations. I honestly never expected to find a supersport bike to be this comfortable. Even my friends riding pillion said it was good enough for short journeys. Could not have gotten a greater compliment. One thing is for sure, this bike is a keeper.
Looking forward to many more kms with Lola in the years to come.
One of the most mesmerising views from my ride
![Lola is home - My TVS Apache RR310 BS6 ownership review-sceneryimage.jpg](https://www.team-bhp.com/forum/attachments/motorbikes/2101284d1687909131t-lola-home-my-tvs-apache-rr310-bs6-ownership-review-sceneryimage.jpg)
