Team-BHP > Motorbikes
Old 28th May 2020, 22:24   #1
ACMohan's Avatar
Thanked: 1,063 Times
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter
Yes! I restored another Bajaj Scooter (Restomod to be apt) . This is how it started. So, when my uncle saw my dad’s restored Chetak (The blue one- here’s the link (Restoration of my '86 Bajaj Chetak), if you haven’t read her story yet), he became vocal on the memories of a similar scooter of his. In his eyes, I could see the enthusiasm and a strong desire to get the scooter restored.
One fine evening, dad informed that my uncle was on his way, with something special for me. Guess what! He came with his same old scooter, but in a cargo auto as its brakes were jammed. I couldn’t inspect the scooter thoroughly as it was already dark. So the first thing, I did the next morning was to examine its condition. Upon thorough inspection, it was found that it had a badly rusted mudguard and some other minor issues like missing fuel tap lever, broken lights, cables etc. Also the scooter was a newer version of the Chetak- yes, the one with a fiber horn cast (with turn signals integrated to it). This made me skeptical about its restoration as it lacked a vintage/retro look. But I couldn't ignore my uncle's desire to see his scooter restored. So I decided to get this done.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-1a.jpg
The scooter with all its accessories/ extra fittings and the spare tyre. This is how I got it.
Since we already had a restored Chetak close to its stock condition, I planned to restomod this one. We started the restoration and left the mod part for next stage. We followed almost the same procedure as the previously restored scooter. The clutch, brake shoes, all gaskets, seals, cables, rear suspension bushes, fuel hose, front wheel bearings along with axle were replaced, fuel tank was cleaned and fuel tap lever was fixed. And now the scooter was running again with a slightly throaty exhaust note (due to a leaking exhaust).
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-fiberhorncast.jpg
After the removal of badges, spare tyre and other extra accessories like the grab handle etc. The turn signal section on the fibre horn cast was removed and the seat was modified to a smaller one (dropped this idea later).
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-5.jpg
Fiber horncast was removed and relays/flasher relocated.
Now to the second stage, the modification part!
The scooter lacked a vintage look mainly due to its plastic horn cast. So to replace that, a salvaged metal horn cast was bought. The scooter was then taken to body shop for the much needed body repair.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-6.jpg
The salvaged metal horncast with chrome horn.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-weld-horncast-mudguard.jpg
The metal horncast was welded and the rear indicators on the side covers was removed and the socket welded. The rusty old mudguard and all other rusty bits were taken care of.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-seat-metal.jpg
The stock single seat appeared too large for the scooter when the spare wheel was removed. Fascinated by the café racer seat setup, we decided to make a frame out of metal (May change to a fiberglass one later). Yes! A Café Racer Scooter! It was hinged at the front and locked to the frame with a latch. (More on this later)
Paintjob.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-0candyberry.jpg
Candy red and Berry red. The darker one is berry red. Candy red looked too good in shades and at night. However it was too bright and flashy during broad daylight!
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-2prep-worka.jpg
The preparation before paintjob
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-3base-coat.jpg
After the base coat
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-4somemoreprep.jpg
Some more prep work.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-5final-clear-coat.jpg
After the final clear coat.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-6a.jpg
Seat from the blue chetak was fixed and the scooter was taken home.
Parts
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-beading-lamp-speedo-carb.jpg
Beading, headlamp, speedo cable, brake light switch, speedometer (the older one was damaged beyond repair), Rear shock bush and new carb float assembly.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-4-mirror-indicators.jpg
Black mirrors and bar end turn signal lights. (Planned to fix round bar end mirrors to make it more of a café racer style. However, since it’d rotate with the throttle and gear selector, that plan was dropped)
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-6-combination-switch-accl.jpg
New combination switch (the older one's contacts were worn out), throttle cable.
Assembly
Once the painting was completed, we brought her home for the final assembly stage.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-1-assy-combi-switch-indicator-wired.jpg
Wiring was corrected. New combination switch and bar end turn signals were wired. Ignition key cylinder was relocated to headset. Headlamp was replaced with a new one.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-3-love.jpg
Love!
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-4-parts.jpg
Parts to be reassembled. The seat frame was given for upholstery.
PROLOGUE: A Bhpian's Wish
Indeed, your wish did come true, Asish_VK and I've kept my word.
Originally Posted by ACMohan View Post
Originally Posted by Asish_VK View Post
If possible you can fabricate and manufacture a single seet like in Vespa S or in Vespa 846 (attached pics) and remove the spare wheel, It will look fab (IMHO)
Asish, the scooters in the pictures look great though. But, I wanted to keep it in the original form. If I had another Chetak, I would have done that for sure.
Agree with you guys,
I totally understand it, Forgot about the fuel filler cap
As a restoration, what you did is perfect. Wish you get another Chetak to do what I said
And finally, here's the finished scooter.
We've strictly followed a Red/Black theme and that's why chrome was avoided. (horn being the only chrome thing in the scooter now.)
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-side1.jpg
Notice how the seat makes the scooter look small.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-front-quarter.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-rear.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-front-path.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-front-green.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-quater-green.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-seat.jpg
Cafe racer inspired seat. It doesn't give the comfort of the stock seat but it's not bad either. And the riding position has improved, I think.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-side-closeup.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-side-green.jpg
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-side-rider.jpg
This is how it looks with a rider. The seat surely gives the scooter a leap forward stance. The helmet doesn't match the scooter, though.
Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter-side3.jpg
Thank you everyone.
PS
  • Special thanks to Babu uncle for trusting me and gifting his beloved scooter.
  • Unlike the last time, some parts were difficult to source. Thanks to my friends Sudhish, Basil and Ebin for helping me with the parts hunt!
  • Thanks to Mr. Ajayan (Bodyshop), Mr. Jose (Paintshop), and Mr. Shyam (Upholstery) for their effort.
  • Thanks to my cousins Sarun and Jithu for their helping hand.
  • And Thanks to my friend Rohini, for helping me put this whole thing into words.
ACMohan is offline   (113) Thanks
Old 15th June 2020, 06:54   #2
Thanked: 86,368 Times
re: Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter
Aditya is online now   (3) Thanks
Old 15th June 2020, 08:04   #3
saisree's Avatar
Thanked: 2,528 Times
Love the restoration. CHETAK is pure nostalgia and it kindles that tagline “ Buland Bharat Ki... “. Dare to say that the two Chetaks' restoration met the levels of FIATs, Ambys and other classics in this forum.
How is your uncle feeling on getting his ride back in a boyish look? Did you ask him to shed his age and appearance?
saisree is offline   (2) Thanks
Old 15th June 2020, 09:03   #4
CrAzY dRiVeR's Avatar
Thanked: 78,803 Times
Re: Resto-modification of a '96 Bajaj Classic into a Café Racer styled scooter
Brilliant! I'm not sure if I'm a fan of that thin seat - but everything else looks sweet! So, when do you plan to paint this one?
Leaving a link for your beautiful painting of the Chetak for BHPians to get the reference - https://www.team-bhp.com/forum/shift...-drawings.html (The Artworks thread! Paintings, sketches & drawings)
CrAzY dRiVeR is offline   (3) Thanks
Old 15th June 2020, 09:04   #5
deep_bang's Avatar
Thanked: 1,513 Times
Beautiful rendering and making it a retro but yet stylish. No doubt the seat is the most dynamic part of the restoration. But the other like the paint job etc are also done very very nicely.
deep_bang is offline   (1) Thanks
Old 15th June 2020, 09:33   #6
Axe77's Avatar
Thanked: 27,704 Times
This is a really beautiful project - well done indeed. I have a question - doesn't the seat feel too hard for lack of cushioning or not that bad in real life?
By the way, speaking of custom scooter I LOVED what K Speed Customs (Thailand) did with these Honda Cubs. Who better than RacerTV to present the bike in his inimitable style of presentation. Reminds me a bit of our good old Bajaj M 80. Someone could do a similar restoration project using an old M 80.
Axe77 is online now   (3) Thanks
Old 15th June 2020, 10:19   #7
v12
v12's Avatar
Thanked: 7,567 Times
Very beautifully executed Mohan!! The cafe racer seat beautifully gels in with the rest of the scooter and indeed does look like a Cafe Scooter.
Axe77 - someone on the forum has made a cafe racer out of a TVS moped. Do check it out.
v12 is offline   (2) Thanks
Old 15th June 2020, 10:41   #8
ariesonu's Avatar
Thanked: 2,444 Times
Great effort.
Would love to see the handle bar end lights - in action
You are missing rubber gasket around on side trunk flap
The front number plate patch looks too low. I suppose that it is tape. Make the corners rounded next time to match rounded shape of scooter.
Add a six inch high windshield at front OR full size one.
Regards-Sonu
ariesonu is offline   (1) Thanks
Old 15th June 2020, 11:27   #9
arvindmanju's Avatar
Thanked: 578 Times
I was never a scooter fan(especially Chetak), but your red colour scooter looks fabulous and makes me fall in love with it. Great effort put to make it look so adorable, also very beautifully photographed!
arvindmanju is offline   (1) Thanks
Old 15th June 2020, 12:00   #10
Amrik Singh's Avatar
Thanked: 3,651 Times
I have '83 Model Chetak. It is perfectly sound Mechanically and Electrically. No body Rust. One reason for its condition is my almost 20 Years working in Middle East while the Scooter took rest at home. I collided with a Car which had stopped abruptly in the middle of the road, in an attempt to cross the road. The Front Wheel Mudguard was damaged and the front suspension fork was bent. Although I did not need this Scooter, yet got it repaired for running errands from market which my Pulsar could not do.
Though I want to restore it fully, I am in a dilemma considering the future of near vintage scooters in India. Would it be worth spending money on Bodywork repairs and Painting just for the affection with the Scooter ? I am a person of few needs and do not have much outing. And there is no one else who would be using it in future either.
Amrik Singh is offline   (1) Thanks
Old 15th June 2020, 12:31   #11
bharatmarch's Avatar
Thanked: 49 Times
This is a beauty. Loved the colour and the cafe racer styling. Inspiring. My Suzuki Fiero year 2000 is under restoration. This post has given me much needed motivation.
bharatmarch is offline   (1) Thanks
Old 15th June 2020, 12:50   #12
raman.aries's Avatar
Thanked: 164 Times
Hi, I have 2002 model Chetak with me in Trivandrum which needs a bit of restoration. I was wondering where you obtained the spare parts for your scooter from, assuming that you did the restoration in Kochin. I am finding it difficult to source the rubber and plastic parts as well as the speedometer assembly.
Thanks,
Raman
raman.aries is offline
Old 15th June 2020, 13:11   #13
Thanked: 54 Times
Hi Mohan,
This restoration has turned out to be really well. Absolutely loved the color combination and the cafe racer setup. Just one question, incase your uncle decides to go for the longer seat to accommodate 2 riders, is there any scope to do that?
InsaneSpeed is offline   (1) Thanks
Old 15th June 2020, 13:13   #14
Thanked: 199 Times
Assuming you are planning to do more such mods, I suggest you consider converting next version to electric scooter.
Mohitkumaar is offline   (1) Thanks
Old 15th June 2020, 13:53   #15
Thanked: 645 Times
This is Love!!
The idea, the execution and the photos have been very well put together!
I especially love the seat and the red/black theme.
A very well put together project. No surprises that it has come from 'Mods Own Country!'
AlQuazi is offline   (2) Thanks
