A few days ago I'd changed the rear shocks to taller ones on my CT100B, if anyone has been following the conversations in the
Offroad Riding - Tips & Advice thread you'd come to know that I've had it in mind for a while now as I was facing the concern of the front wheel lifting off the ground when launching/accelerating on upward inclines an issue I'd not faced with any other motorcycle I've owned.
A quote of my post;
A major challenge I face with the CT100B is that at times the front end is too eager to lift off the ground when encountering rocky uphill terrain and before the motorcycle does a 12:00 I chop the throttle and lay the motorcycle down most of the time......
.....I'm contemplating raising the rear by an inch or two by going for a different set of shocks hoping it would make the motorcycle more front biased as at times even when climbing aggressive inclines on tarmac with a pillion the front tends to come off the ground.
Having confirmed beyond doubt that the issue has been sorted, I did want to know if the feeling I'd had about raising the rear was really what resulted in solving the case or if it was merely me overgearing the motorcycle(Bigger Front Sprocket), so I did spend some time and came across wonderful but scarce resources regarding the same and thought it best to share what I've learnt as I believe there is an information gap regarding how the rear suspension impacts weight transfer under acceleration.
Now it is already obvious that changing the height of your rear suspension can affect weight transfer as well as your wheelbase as your swing arm is fixed at a pivot on the chassis.
But what we do not realize is that the angle at which the the rear wheel axle sits from the swing arm pivot determines how your suspension would react when you accelerate.
Squat
This is when your motorcycle's rear axle bolt is higher than your swing arm bolt, this results in Squat as the pull from the chain results in the rear suspension compressing and making the front end go up, the same is what sends you wide when accelerating out of a corner.
Anti-Squat
This is the opposite of Squat as the name implies, in this case your rear axle bolt should be lower than your swing arm bolt, as a result the pull from the chain results in your rear suspension expanding forcing the front end down, and ensuring that you're in control when accelerating out of a corner.
This is something that is incorporated in sports bikes;
I've drawn some lines to make it more obvious, also do note the placement of the front sprocket, it is slightly above the swing arm bolt to accentuate anti-squat geometry.
So what I've done on my CT100B is change the rear suspension to one that is taller and stiffer than stock to promote anti-squat under load which would prevent the front end from becoming lighter on an already rear end biased(weight) motorcycle, this in effect has returned favorable results.
Plus we've all seen videos on social media of several instances of the CT100 popping an unsolicited wheelie with a pillion on board, a few examples;
I'm no expert by a long shot coming from a non-engineering background but from my understanding promoting anti-squat should resolve such concerns as well.
At first I did consider that this was only effective in sports bikes but a little more probing and I got to know that the same is applicable even for bicycles, in which case it does make sense for commuter motorcycles as well.
Do share your thoughts on the same!
P.S. You can find pictures of my CT100B post suspension change by following the below link:
Bajaj CT100B - Utilitarianism Redefined!
This clearly shows Anti-Squat at work, do observe the rear and front suspension on acceleration.
When on the gas, it is evident that the rear wheel gets pulled in causing the rear suspension to expand which raises the rear end of the motorcycle and in turn mashes the front end downward in the process compressing the front suspension.
