Team-BHP > Motorbikes
Old 4th March 2020, 17:45   #91
Red Liner's Avatar
Thanked: 19,018 Times
Re: KTM 390 Adventure India launch confirmed. Edit: Launched at 2.99 lakh.
Unfortunately happens when you watch too many YouTube videos at home. You build these belief systems in your head. And then begin living by them.
Red Liner is offline
Old 4th March 2020, 18:55   #92
Crhysis's Avatar
Thanked: 40 Times
Though leaving the off road stuff out since I don't know enough on the subject and the rear suspension being stiff which I haven't noticed. I would echo every other point. He paints a pretty good picture of what to expect from the bike in terms of pros and cons.
Crhysis is offline
Old 4th March 2020, 20:00   #93
Cyborg's Avatar
Thanked: 4,353 Times
Originally Posted by drt_rdr View Post
He lost me when he said he hit his bashplate against the footpath or something and immediately decided this bike is not meant to do that kind of "silly stuff". I mean half the point of buying a bike like this is to be able to do things that would be stupid on other bikes
I think it was his mistake. He jumped the footpath and there was a stone underneath which his bash plate came in contact with.
If/when you jump a curb/footpath aren’t you supposed to see if there is adequate clearance below the bike? I feel from what he said (without actually seeing it) if the stone wasn’t there the bike would have cleared it. It’s like going over a speed breaker at speed and complaining your ground clearance is not enough. I hope you get my drift.
Please listen to the same part in the video again and share your thoughts.
Cyborg is offline
Old 4th March 2020, 21:02   #94
PatienceWins's Avatar
Thanked: 927 Times
Most reviewers complan about poor low end torque and bike stalling in initial gears. That would be an issue during commuting in city traffic and off roading, especially off-road inclines. Love Himalayan for the low end torque, seems we cannot get the best of both worlds with a short stroke motor. Hope there will be some modification available.
PatienceWins is offline
Old 4th March 2020, 21:08   #95
Red Liner's Avatar
Simple fix. Lower the front sprocket by one tooth. Globally accepted “modification” on all bikes including the crf 250l Honda.
Old 4th March 2020, 21:44   #96
Thanked: 22 Times
Indeed. Or you can also consider going up by 2-3 teeth on the rear sprocket. Believe this is available as a powerpart from KTM, not sure if a lower teeth front is available with them.
RabidBull is offline
Old 4th March 2020, 23:06   #97
shree_shell's Avatar
Thanked: 351 Times
Originally Posted by Jaggu View Post
The bad
Highway cruising - I have bought this bike for city commute mostly, and for those one-off trips where I might ship the bike, so this may not be really an issue for me.
Butttt for people who are buying it mostly for long highway tours, I would suggest a big NO!. Yes, it is fast, it 'maybe' more reliable yadayada, but just get a Himalayan instead, save a lakh or more and be very comfy during your tours. The issue is ironically this bikes major plus point compared to Himalayan, the weight factor. The laws of physics though doesn't work for it on highways as expected. The bike feels too light, at speeds above 100 Kmph, just a slight wind makes it nervous, so one has to really be concentrating so as not get pulled into a wind drift, say while overtaking a huge container lorry. The tall gearing again results in low engine braking at higher gears, which again adds to a disconnect while touring at speeds. Add to that the vibes from engine and stiffer progression of suspension let in lot of fatigue onto the rider.
I think it is the Rake that's responsible for high-speed handling and turning.
Ktm 350 adv: 23.5 deg / Wheelbase: 56.3 inches
My 2004 XT225: 24.0 deg / Wheelbase: 53.1 inches
My 2004 ZRX1200R: 25.0 deg / Wheelbase: 57.7 inches
Himalayan: 26.5 deg / Wheelbase: 57.7 inches
Every motorcycle is a compromise and while buying you choose what kind of trade-off is enjoyable to live with. I believe the KTM's geometry is more suited to off-road; Himalayan's is cruising, however, they might not have the equipment to be good at that (Himalayan is underpowered).
From personal experience, the low rake XT is very finicky during 100kph curves, while the ZRX wants to do 200kph on curves. But then the former is a dual-sport trail bike and latter an overpowered UJM cruiser.
shree_shell is offline   (2) Thanks
Old 5th March 2020, 01:36   #98
Thanked: 1,563 Times
We have no way of knowing for certain, but yes, it sounds like it was his mistake, which was what I was referring to earlier.
He could probably have been sitting down on the seat when he supposedly hopped it off the footpath, and his behind probably came down hard on the seat, bottoming the suspension out and making the underbelly hit either the edge of the footpath or a rock as he claims. Were he standing up, things would probably have been different.
Or maybe he had a pillion with him when he tried this out. Whatever the case, the bike has a bashplate to protect it somewhat against this kind of riding.
drt_rdr is offline
Old 5th March 2020, 05:14   #99
sandeepmohan's Avatar
Thanked: 5,948 Times
Only concern is the huge variation in FE
That lines up right to what I used to get on my 390 Duke. Highway sprints used to range between 26 - 27. Go easy on the gas and you will be rewarded with 30kmpl or so. No use looking at bumper to bumper figures. The bigger problem was dealing with engine heat which I assume has been addressed here, as you have not highlighted any.
True to the brand image this is another hooligan of a bike from the stable.
Considering the motor is essentially unaltered to the 390 Duke, the hooligan attributes are likely to pass on.
Things have improved a lot from day 1 and hopefully, the move to synthetic oil at first service will improve things further.
I assume the Motul oil from the factory is all Synthetic.
Mid range engine vibration
Little you can do about this. The motor is just buzzy at times.
I quite enjoyed riding the Himalayan, during the brief test ride I did. It does not give you much reserve when it comes to power. 100 - 110kmph feels good but demanding anything more from that engine isn't all that rewarding, whereas on the KTM, all you need to do is twist that throttle a little more and you can blast past almost anything.
sandeepmohan is offline   (1) Thanks
Old 5th March 2020, 12:58   #100
Jaggu's Avatar
Thanked: 16,972 Times
re: The KTM 390 Adventure Ownership Thread!
Mod note: Created a new dedicated thread for documenting the real-life user experience of KTM 390 Adventure. Let us continue the discussions here, happy and safe motorcycling
Jaggu is offline   (2) Thanks
Old 5th March 2020, 14:44   #101
Thanked: 3,320 Times
Red Liner, CrAzY dRiVeR & Jaggu
Can we expect a detailed review, with photo shoot like the RE twins "Ridden" thread?
surjaonwheelz is offline
Old 5th March 2020, 19:03   #102
Red Liner's Avatar
Crazy driver can borrow both our bikes and do whatever he wants with them
I think the orange one is faster
And
Red Liner is offline   (5) Thanks
Old 5th March 2020, 19:12   #103
Thanked: 6,657 Times
Torque is Torque is Torque, no way around it.
Playing with the sprockets affects your gearing alone, so unless you feel your overall gearing is too tall for the intended use I'd suggest to let things remain stock.
I don't know about the CRF250L but I've played around with sprockets at one time, the max difference I'd gone up to is +4 Teeth at the rear towards the shorter end of the spectrum, felt WOW at first, MEH later and finally went back to stock because as mentioned earlier changing sprockets affects the overall gearing.
Ideally the "rule of thumb" is that you need to arrive at a balanced final drive ratio of 3.00 speaking of which the CRF250L sits at 2.85 stock and with a drop in front sprocket by 1 teeth you arrive at about 3.00, which surprisingly KTM offers stock with the Duke 390 45/15=3.00.
So to reiterate in simple terms the Torque remains the same, you only mess with the acceleration and top-speed when you play around with sprockets, then again the top-speed part of the equation is a little murky because as there is no difference in torque you simply get the same top speed but at a lower RPM and vice-versa i.e unless you ride something that from factory bounces off the limited in final drive without breaking a sweat and that is merely for over-gearing, when you go under as suggested by RL you'd be breaking more than a sweat at your usual cruising speeds.
Then again the KTM's are electronically limited which makes going only one way practical and the other pointless unless you plan to drag race.
P.S.
If you guys are still adamant then I'd suggest you give Gearing Commander a shot to make educated choices rather than go solely by YouTube content.
Cheers,
A.P.
ashwinprakas is offline   (8) Thanks
Old 5th March 2020, 20:02   #104
Red Liner's Avatar
I have done sprocket changes on prior bikes, and I found the changes good enough for me to do it therefore on all my bikes.
Your mileage may vary.
Old 5th March 2020, 23:07   #105
Red Liner's Avatar
International media rides are on!
Red Liner is offline   (4) Thanks
