Re: Scoop! Bajaj Urbanite scooter caught testing in Pune Things I've decoded / gathered from the videos and pictures of Chetak so far.. Body/Looks
Metal Body with clean retro looks
LED headlamps, tail lamps and blinkers
Circular surround DRL in Headlamp
Chetak logo inside Headlamp.
Centre stand and side stand
Body coloured side step for saree clad women
Foldable foot rest
Black 12" alloy wheels with red border
Contrasting red stitching for seats
under seat storage as well as front storage space.
Front storage has mobile charging socket, First aid cum tool kit and most probably the portable charger (in a pouch)
6 colours-Black, White, Gold, Matte Silver, Blue, Red/Maroon
Only Chetak branding...no bajaj branding. Thankfully they didn't name it Bajaj Urbanite Chetak Chic Electric as rumoured. Suspension tyres and brakes
90/90-12 MRF Nylogrip Zapper tyres
Disc brake on front and drum brake on rear
No telescopic front shocks but a setup like Activa
Rear mono shock (on left side) Powertrain
The 4KW motor is a direct drive mounted on the Swingarm. This will mean it'll be eerily silent!
The battery pack is located under the storage towards the front portion of the seat and is non swappable! the battery pack looks like a small aircraft cabin baggage! Charging and Range
Portable charger. (Most probably stored in the front storage area).
Home charging station.
BMS with auto cutoff.
Charging port in under the seat where usual fuel filling cap is present-Not sure how to close the seat during charging.
Range in Eco mode 95kms and 85kms in Sports mode. not sure if it is ARAI rated or real world. if it is ARAI rated, it is low IMO The switch-gear
The switches on the handlebar are finished in piano black.
The right side has 5 buttons M (Mode), R (reverse), another button (probably Power button), D (Drive) and the Right blinker switch.
The left side has 5 buttons high beam/low beam, light on/off, another button, (looks like N to me), Horn and the left blinker switch.
This is the first time I'm seeing separate left and right blinkers on left and right side of the handlebar. will take time to get used to IMO The display cluster
It is circular and is further divided into two concentric circular sections.
The outside section has all tell tale lights. moving clockwise from the Chetak Symbol on top, we see high beam, right blinker and battery charging. Moving anti clockwise, we see light on/off telltale, left blinker, Neutral mode lamp and a generic warning symbol.
The inside section is a digital display and has may display features. the top half of the periphery shows speed progress bar. Looks like the max speed that can be displayed is 100kmph and hence the top speed must be around 90kmph.
The right bottom periphery shows the battery percentage progress bar.
The left bottom periphery shows modes - Sports, Eco, Drive, Neutral and Reverse. Not sure what exactly is Neutral mode for. Top portion of the central area has:
Bluetooth symbol
Play-pause symbol
Call alert indicator
Time display
Charging (plug icon)
Service reminder
Side Stand indicator
Battery temperature/overheat symbol middle portion:
Battery full of percentage indicator
Speed (kmph or mph customisable)
range (kms or miles) Bottom area:
ODO 7-segment number area (kms or miles)
This same area shows SOC (statement of charge) during charging
Below that is TTC (Time To Charge) in hh:mm Features
Keyless start stop.
There is a button on normal key slot area which is probably to open the cover for the front storage area.
Luggage hook on the front seat (like Vespa)
Bluetooth connectivity
Call alerts
Song play control of Bluetooth connected device
No touch screen or on-board navigation
Mobile charging 12V cigarette lighter socket
Looking at all these, it looks like Bajaj has ticked most of the boxes with Chetak and as expected, this will be the real competition to Ather 450. Advantage Chetak
Elegant retro looks
Nice Colour options
Feature laden
Silent hub mounted motor
Centre stand
Rear side step
Brand name
Established dealer network Advantage 450
Futuristic sporty looks
Smart, connected vehicle
Touchscreen and on-board navigation
Telescopic front shocks, two disc brakes, rear centre mounted mono shocks
Superb balance owing to the "designed to be an EV" approach
OTA updates
Belt drive that makes sound (sound is actually good)
Overall, I feel that Chetak will appeal to the masses (provided they get the pricing correct) while Ather will appeal to younger geeky people. If Chetak is like Activa/Vespa, 450 is like Dio/Aprilia.
Finally good to see two Indian companies having strong products and leading this new phase in 2-wheeler EV scenario.
Disclaimer: I've tried to collect correct details as much as possible. However since full specs/details of the Chetak haven't been officially revealed, I can't guarantee the correctness of the above!
