Hey guys,
At over 25k km's on the ODO, I'll be setting my tappet clearance for the first time on my Bajaj CT100B.
The process is simple, so here goes nothing;
1. Get the Seat off, followed by the tank.
You'd have to remove Allen-Key bolts on either side of the seat, followed by one holding the tank in place, I've posted several pictures of my CT100B naked in my Ownership Post for reference:
Bajaj CT100B - Utilitarianism Redefined!
2. Remove the plastic window covers on the shifter side crank-case, they're easy to spot as they're the only 'BLACK' bits present;
You'd need a 17mm socket to remove the timing inspection cover.
You'd need a Coin and a pair of Pliers wrapped in cotton(To prevent scarring) to get the crank nut cover off.
3. Rotate the crank nut counter-clockwise using a 14mm socket.
4. While peeking into the timing inspection window while rotating the crank you'll spot the 'T' mark, which indicates TDC i.e Top Dead Center, the trick here is to note that you'd need to set it at TDC after compression stroke, so keep rotating the crank until you feel pressure, slow down once you do and keep going at a steady pace until you align the mark with the notch on the crank case as seen below;
5. Now you need to remove the tappet covers for which you'd need to use a 8mm socket.
6. Now using a 9mm Ring Spanner unlock the lock nut on either of the adjusters and with the help of the below special tool(Not necessary, can manage with a pair of nose pliers) adjust clearance with the help of a feeler gauge blade(The ASC uses a regular shaving blade, no pun intended!) as per recommendations mentioned in the workshop manual.
The tool in question, costs Rs.50/-, universal for most if not all motorcycles:
Feeler Blade in place, there has to be minimum friction felt while moving the blade around;
Since it was near impossible to source specifications from the local SVC I resorted to going with information available in a Scandinavian version of the CT100's workshop manual.
The clearances mentioned were Exhaust: 0.10mm and Intake: 0.7mm, now I knew the moment I saw it that the Intake clearance was way too high, even the little girl next door curiously peering into my garage felt that the clearance was too damn high, but keeping faith in the workshop manual I fired up the motor and as expected the motor made the familiar but disheartening sewing machine rhythm.
Comparison of both blades to give you an idea:
Stopped the motor and reset the Intake clearance to 0.07mm and all was well, guess they missed to print a '0', which I've edited and corrected in the spec sheet, see below;
7. Replace all 'O' Rings just to be safe;
Since the kit came with the timing chain inspection window 'O' Ring as well I decided to get it changed along with inspecting timing chain slack which was tighter than I'd expected for a machine that has been through as much abuse as my CT100B, Kudos Bajaj!
8. Now you'll have to put back everything in the reverse order you'd pull them out and then idle the motor for a bit to inspect if all went well, thumb rule states that it's better to go over than under as far as tappet clearances go, because if its over then it'll just rattle but if its under then you run the possibility of loosing compression when hot or even the piston hitting the valve, which would warrant a rebuild.
The plus side of DIY'ing is that you'd easily save yourself Rs.1200~1500/- which is usually the labor charge for setting tappet clearance at the ASC.
Cheers and Ride Safe,
A.P.
![Smile](https://www.team-bhp.com/forum/images/smilies/smile.png)
