Team-BHP > Motorbikes
Old 12th September 2018, 05:47   #1
sarathlal's Avatar
Thanked: 6,075 Times
Hubless 100 mph electric motorcycle by RMK, Finland
RMK Vehicle's introduces an electric motorcycle with a hub less rear-motor wheel, capable of 100mph.
Hubless 100 mph electric motorcycle by RMK, Finland-rmkelectricmotorcyclerearwheel.jpg
RMK Vehicle Corporation Is A New Finnish Company And A Motorcycle Manufacturer.
They will be launching their first model, E2 during the Motorcycle Show In Helsinki, Finland in Feb 2019.
  • The E2 Is An Aluminium Frame Electric Motorcycle.
  • The E2'S Operating Range On A Single Charge Is 200-300 Km.
  • It Takes 2-3 Hours To Fully Charge An Empty Battery.
  • The E2 Is Equipped With A Non-Centered Rim.
  • The Integrated Electronic Motor Has Been Designed Into The Frame Of A Rim.
  • The Motor Has A Computational Peak Output Of 50 KW And A Torque Of 320 Nm.
  • The Speed Is Limited To 160 Km/H.
The Estimated Price Of The Bike Is 24 990 Euros.
Hubless 100 mph electric motorcycle by RMK, Finland-rmkelectricmotorcycleheader.jpg
Source: Electrek.co
Company website: https://www.rmkvehicles.com/
sarathlal is offline   (12) Thanks
Old 12th September 2018, 12:58   #2
alpha1's Avatar
Thanked: 2,993 Times
re: Hubless 100 mph electric motorcycle by RMK, Finland
How does one remove the rear wheel to fix the puncture?
alpha1 is offline
Old 12th September 2018, 13:27   #3
androdev's Avatar
Thanked: 25,170 Times
I am sure they give a provision for it. It's not exactly hubless, but having a hub with a large hole I am more curious about the lack of hydraulic/mechanical brakes at the rear.
androdev is online now   (3) Thanks
Old 12th September 2018, 13:50   #4
alpha1's Avatar
Electric braking using the motors? It is possible.
alpha1 is offline   (1) Thanks
Old 12th September 2018, 13:57   #5
androdev's Avatar
Yes that's what they call regenerative braking. But for faster/emergency braking conventional brakes are still the preferred choice as they work even without power (something is better than nothing).
I suppose that's why they kept the front wheel as a conventional one just for brakes.
Old 7th May 2022, 18:14   #6
Thanked: 436 Times
Re: Hubless 100 mph electric motorcycle by RMK, Finland
Even though it took like 4 years to make an actual bike like this and by a different company, the final product is quite practical. Only unanswered question is about unsprung weight due to heavy rear wheel set up.
VERGE TS with 1000Nm of Torque
Need multiple reviews to actually believe as to what has been said in the review below.
Tucker48 is offline
Old 9th May 2022, 13:13   #7
Thanked: 3,267 Times
Regenerative braking is different and it is not possible to use it as a mechanical brake in the conventional sense.
Yes. I suspect that this is a BLDC motor working on a fly by wire principle. This means that speed control is done electronically and there would be no conventional brakes (Using friction). So your brake is electronic too. You don't mess with motors that put out 1000Nm (Unverified) torque using normal hydraulic or friction brakes.
PS : I haven't watched the complete video.
srini1785 is offline
