Re: Motorcycle Reliability - The elephant in the room Quote:
Originally Posted by grazd WRT engine Oil replacement Dan suggests every 1000 miles (=1600km) which is more frequent than the manufacturer recommended 6000km. It seems like a major difference. What schedule do you follow? |
You know how thumb rules and round figures work!
Though jokes apart I know a few motorcyclists who've got multiple lakhs on their odo's and stick with 1.5k km's oil changes as the 1000 mile guideline was provided in the road-bike versions of various motorcycle manuals, but then they had smaller sumps i.e 800~900ml.
Personally I stick with the 2k km's per liter guideline, so if my sump is around the 1L mark I change oil at 2k intervals. Many would advise going for premium oils that would last upto 5k km's but fact remains that friction wear is not the only thing deteriorating the engine oil, you have clutch wear residue and combustion blow by, which is more for big displacement single cylinders.
As you can see, the only times I've changed early was during the initial run-in period and when I've had to prep for long rides which is also the times when I had to go a bit over the 2k mark. My factory recommended grade is 10W30 but I prefer to run on 20W50, as I use the same grade on all my vehicles which facilitates bulk purchasing(more discount!), plus the 20W50 holds better for my use, 10W30's never really went well past the 1k mark with my riding style, read gear shifts got super hard around that ball park.
Some manufacturers do recommend 5k oil change intervals but lets face the music, anyone whose ever done their own oil change would strictly vote against extended oil change intervals, from a not so quotable source I got to hear that even Bajaj test bikes had issues of severe premature component wear following the initial 10k replacement interval claims which was a reason for them to lower the claim to 5k replacement intervals which would not show obvious signs of wear in the short run.
Ultimately as I've mentioned before, you have the resources and the motorcycle is your own, its your wish to do as you please with it, just remember that if something is too good to be true then it might possibly be so.
Happy Riding.
