Team-BHP > Motorbikes
Old 11th February 2018, 10:43   #1
Thanked: 29,292 Times
Cleveland CycleWerks @ Auto Expo 2018
Big shoutout to Eddy for shooting these pictures & his coverage of the Auto Expo. Thanks for sharing, man!
Cleveland CycleWerks (CCW) is motorcycle manufacturer that designs and assembles small displacement retro style café racers and bobbers in Cleveland. They would be entering the Indian market this year with CKD imports from China. They have set up their assembly unit in Pune and are based out of Mumbai for corporate operations:
Auto expo was the first platform where the company put their bikes on public display in India. CCW being a manufacturer and not a custom bike builder caught quite a bit of attention, although their stall was a little cramped with 6 bikes on display:
Cleveland CycleWerks Heist 250
Let's start with the Heist bobber styled motorcycle. The bike is built on a tubular backbone, double cradle chassis:
The overall styling is retro and has the simplistic feel to it:
The rear wheel has a 2 piston slide caliper brake. The wire spokes add to the retro look of the bike:
CCW Heist is powered by a simple 229 cc engine. Simple meaning no OHC, no 4 valve heads, it's an OHV engine with 1 intake and 1 exhaust port:
The rear suspension setting can be changed by adjusting the seat springs:
No loud stickers. Just a simple sticker on the tank:
The chain tensioner and wheel adjuster is exposed:
Cleveland CycleWerks Ace Scrambler
The bike is a part of the Ace family which also includes the Ace Standard, Deluxe and the Cafe:
The bike carries the textbook scrambler look and is built around a square backbone, stressed engine, high carbon steel frame:
17" wheels with a 110/70 tyre up front and a single piston caliper disc brake:
The Cleveland CycleWerks plate on the side looks nice:
Traditional dials:
Simple American type switchgear:
Round tail light and round indicators look slightly small, but not out of place:
The bike is powered by the same engine as the Heist. It's a 229 cc, OHV, single cylinder, four stroke, push rod, air cooled engine making 15 BHP and 16 Nm of torque:
Omkar is online now   (7) Thanks
Old 11th February 2018, 10:46   #2
Re: Cleveland CycleWerks @ Auto Expo 2018
Cleveland CycleWerks Misfit
The Misfit is in its 2nd generation internationally. The bike is built on a perimeter frame:
The bike looks great in the green paint scheme and has some added chiselled lines unlike other bikes in the line-up:
The cafe-racer type single seat can be converted into double by removing the rear cover:
The tank is long, but sleek. The knee indents on the tank are quite prominent:
The seat height is set at 30". The rear suspension has twin coil over oil damped shocks:
18" front wheel with single 315 mm full floating wave rotor, 4 piston radial mount caliper:
Traditional dials look classy:
Cleveland CycleWerks Ace Cafe'
This is the Cafe' racer cousin of the scrambler seen earlier:
Traditional round headlight with USD forks:
The same 229 cc engine does the duty here as well. The white and blue paint scheme looks refreshing:
Cleveland CycleWerks Ace Deluxe
The third sibling - Ace Deluxe:
38 mm inverted forks here with the round headlamp:
A flat seat unlike the single cafe' racer cousin:
The rear wheel has a travel of 90 mm:
I like how the looks are simplistic throughout. Across the range, you can see the traditional design elements being used everywhere:
Cleveland CycleWerks FXR
The only bike in CCW stall with a different engine. This is the motocross styled bike which is road legal in most countries. CCW is currently in the process of getting approvals from ARAI for an Indian launch as well:
With these inverted forks, the front wheel has a travel range of 195 mm:
The rear has a single shock adjustable suspension which gives the wheel a travel of 150 mm:
Single piston slide caliper rear disc brake:
Omkar is online now   (9) Thanks
Old 11th February 2018, 16:41   #3
Thanked: 86,413 Times
Aditya is offline   (2) Thanks
Old 17th February 2018, 22:39   #4
CarCynic's Avatar
Thanked: 98 Times
Simple yet gorgeous looking motorcycles although I am skeptical about the quality. I wish major manufacturers would take some inspiration from them in terms of styling.
CarCynic is offline
Old 20th September 2018, 10:57   #5
Thanked: 6,658 Times
If I recall right the motorcycles would be officially launched today, fingers crossed!
ashwinprakas is offline
Old 21st September 2018, 12:06   #6
TusharK's Avatar
Thanked: 65,645 Times
Cleveland CycleWerks opens its first showroom in Navi Mumbai
Cleveland CycleWerks has opened its first showroom in India. It is located at Mahavir Arcade, Plot 286, Sector 28, Vashi in Navi Mumbai. The showroom is spread over an area of 1,000 sq. ft. and includes a display section with the company's entire range of products. It also has a lounge, delivery arena and service centre.
At present, Cleveland CycleWerks is offering two motorcycle models in India - the Misfit, which is a cafe racer style bike and the Ace Deluxe, which is a Scrambler. Both bikes share the same underpinnings featuring a square backbone chassis with inverted telescopic fork suspension at the front and twin hydraulic shock absorbers at the rear.
Both the bikes are powered by a 229cc, single-cylinder, air-cooled engine that produces 15.4 BHP @ 7,000 rpm and 16 Nm of torque @ 6,000 rpm, which is paired with a 5-speed gearbox. The Misfit comes with a 320 mm front disc brake with a 4-piston caliper and a 220 mm disc brake at the rear with a single-piston caliper. The braking setup on the Ace Deluxe comprises of a 298 mm disc with a 2-piston caliper at the front and a 210 mm disc with a single-piston caliper at the rear.
Link to Team-BHP News
TusharK is online now   (4) Thanks
Old 21st September 2018, 18:40   #7
aah78's Avatar
Thanked: 3,409 Times
Nice! I'd watched some videos on YouTube a few years ago when they were just getting set up.
Hadn't heard much since, so thought they had folded. Good to know that they're still in business, and coming to India!
The smaller displacement engines should keep the price down.
aah78 is offline
Old 12th November 2018, 15:46   #8
Thanked: 15 Times
Cleveland Cycle works bikes in India
Starting this new thread as I couldn't find any other proper place to put it down. Moderators, request you to place it correctly if required.
Few days back, while riding on my two wheeler, I happened to see an interesting looking bike on display outside a small showroom near my place. On fleeting glance, it looked somewhat like a mix of RD350 or RX100, but since I was in a hurry, did not stop to investigate at that time. Later I tried to search on the net for the launch of any such new bike in India, but couldn't find any information.
Out of curiosity, I specifically visited the showroom last week. Came to know that it was the "Cleveland Cycle works" bikes showroom and they have recently launched their bikes in India. It is an American company and currently have two models, one of which is on sale and was on display.
The model itself looked pretty good and on asking, I also could get a small test ride. It is a 250cc bike. Although I was not quite impressed with the ride quality, the salesman assured that the suspension would improve on more running.
What surprised me that there is no mention of the launch anywhere in the news or in any forums. No adverts either. It seems that their media drive has just been done and the adverts may come out soon.
Although I don't have much knowledge of today's bikes, I once was the owner of the RX100, and the somewhat similar looks of this new bike is what attracted me to check it out. I am sure fellow BHPians must be having more knowledge of it.
Here is the link to their website - https://www.clevelandcyclewerks.in/motorcycles/
SachinVD is offline
Old 12th November 2018, 16:05   #9
blackwasp's Avatar
Thanked: 27,188 Times
Re: Cleveland Cycle works bikes in India
Originally Posted by SachinVD View Post
.. I happened to see an interesting looking bike on display outside a small showroom near my place.
Interesting place, though not a bike fan, I happen to pass that place frequently as I stay nearby as well. I think they need to offer a bit more models. They have only 2 models with the same underpinnings.
Related post (Cleveland CycleWerks @ Auto Expo 2018).
blackwasp is online now   (1) Thanks
Old 12th November 2018, 19:33   #10
Who_are_you's Avatar
Thanked: 422 Times
This is a Chinese brand with just headquarter in America. Just like UM Motorcycles. No offence meant but I won't touch these Chinese products with a 6 feet long pole.
Screenshot of google street view of headquarters.
Who_are_you is offline   (3) Thanks
Old 9th January 2019, 23:33   #11
CrAzY dRiVeR's Avatar
Thanked: 78,823 Times
Cleveland Ace Deluxe review -
CrAzY dRiVeR is offline
