Team-BHP > Motorbikes
Old 5th January 2018, 18:36   #1
TusharK's Avatar
Thanked: 57,839 Times
The 2018 Bajaj Discover 110 & 125
Bajaj is set to launch its 2018 Discover range on January 10, 2017. This includes a new 110 cc version of the Discover and an updated Discover 125.
Recent spy images have indicated that the Discover 110 will feature similar styling as the 125 cc version and both bikes will be offered with new design black alloy wheels. Also, Bajaj seems to have swapped the downtube cradle frame for a single downtube frame on both 110 cc and 125 cc versions of the Discover. The telescopic front suspension and dual gas-charged rear shock absorbers have been carried over.
The Discover 110 is expected get a new instrument cluster with both digital and analogue gauges, electric start and handlebar-end weights. Being a budget offering, it is likely to miss out on some features including the front disc brake that may be offered as an option.
The Discover 110 will use a 110 cc, single-cylinder, air-cooled engine. While Bajaj hasn't confirmed the specifications of the engine, it is rumoured to produce around 9 BHP and 9 Nm of peak torque. The engine will likely be paired with a 4-speed gearbox. The Discover 110 will compete with the TVS Victor and Hero Passion Pro in the premium commuter segment.
Source: Thrustzone
Link to Team-BHP News
TusharK is online now   (4) Thanks
Old 5th January 2018, 19:15   #2
Tanveer02's Avatar
Thanked: 647 Times
re: The 2018 Bajaj Discover 110 & 125
While the 110 and 125 Discovers are one of the best sellers in the segment, I personally believe it's high time Bajaj gives these two motorcycles a major facelift. Even the HMC Glamour got one recently. The looks have been almost the same since the bike's inception way back in 2003, and while the 150 was launched with a semi fairing, the bike wasn't well recieved and is now discontinued.
The best looking Discover and the most unique I believe was the 125ST, but looks are subjective
Tanveer02 is offline   (2) Thanks
Old 10th January 2018, 17:16   #3
TusharK's Avatar
2018 Bajaj Discover 110 and Discover 125 bikes launched
Bajaj Auto has launched the new Discover 110 and the 2018 Discover 125 in the commuter bike segment. The Discover 110 has been priced at Rs. 50,176, while the updated 125 costs Rs. 53,171 and Rs. 55,994 (ex-showroom, Delhi) for the drum and disc brake versions respectively.
The bikes measure 2,035 mm in length, 760 mm in width and 1,085 mm in height. They share the same wheelbase which is 1,305 mm, while the seat height is set at 805 mm. Fuel tank capacity is 8-litres.
Both bikes are equipped with a digital instrument cluster with an analogue tachometer and headlight with integrated LED DRLs. The chassis, engine and the new design alloy wheels have been finished in black, while the bodywork features new decals. Both the models ride on telescopic front suspension and twin gas-charged shock absorber at the rear. According to Bajaj, the new Discovers feature 16% longer suspension than the previous models.
The Discover 110 is powered by a 115.5 cc, single-cylinder, air-cooled DTS-I engine which delivers 8.5 BHP @ 7,000 rpm and 9.81 Nm of peak torque @ 5,000 rpm. On the other hand, the Discover 125 carries over its 124.5 cc, single-cylinder, air-cooled DTS-I engine. This unit produces 10.8 BHP and 7,500 rpm and 11 Nm of torque @ 5,500 rpm. The Discover 110 gets drum brakes at both ends, while the 125 gets larger 130 mm drum brakes on both wheels with an optional 200 mm disc at the front.
The 2018 Bajaj Discover range is available in three colour options - Black, Red and Blue.
TusharK is online now   (3) Thanks
