Originally Posted by knightrider_7 That conclusion is spot on. I forgot to mention about the higher speeds the bullet is able to do now, without passing me the vibrations. Its now a lot more easier to reach 70 kph. However, the mileage has been reduced to below 40 kmpl after the recent full tank. May be because I was doing higher cruising speeds since the oil change. |
The 350 motor is better than the 500 when it comes to being able to rev higher without throwing a tantrum, hence why you see enthusiasts and tuners strictly sticking to 350's over 500's.
During college I've had a bit of fun with a few 350's, the motorcycle runs best with the stock intake/exhaust configuration, in final drive you can easily do 40 to 115 kmph without breaking a sweat, though it does hit a brick wall and vibrates like crazy at WOT.
I've also had the misfortune of riding alongside a C350 which had an upswept exhaust as the owner was originally from Thiruvanvamalai, on the highways the motorcycle would feel like exploding if going north of 70 kmph, top speed he was able to achieve was around 90 kmph, that was expected as he was running a low to mid end focused exhaust while riding from Palakkad to Bangalore.
I on the other hand was on the P220 which was running on stock sprockets as the motorcycle was brand new at the time. I rode around 400 km's in 4th gear so as not to offend the other rider who was a friend of my best friend.
Only case of busted crank bearings was when a fellow enthusiast went with extended drain intervals as he was under the impression that using FS oils warrants extended drain intervals, total cost of repairs was over 20k which was a huge sum at the time, still is.
So as long as you maintain decent oil change intervals and keep the motorcycle stock you'd be covering a lot of miles before any concerns pop up.
As for FE, anything over 30kmpl is a win for this motor, the twin spark does wonders as earlier the benchmark was 20+ kmpl when pushed hard.
Regarding the pictures of bullet, I always forget to take it while on trip. After finishing the trip only I remember this. |
That used to happen to me, I regret missing out on snapping pictures on the earlier interstate runs, now I just tether a cheap point and shoot camera to my belt, so I wont miss to snap a picture even when I'm stopping for a mere bio-break.
I hate snapping pictures on the smartphone, for some reason I find them to take a lot of time to take a picture.
Thanks for the route tip. I am adding this route to my wishlist. How to do this while coming from Thrissur?
Back then I went from Kochi to Kollam via Suryanelli as I was bored to death with the Aleppy route plus the roads were crap to ride on, could not go towards Bodhimetu as the Wego had a small fuel tank and I wasn't carrying extra fuel, plus there were no fuel bunks in Chinakkanal and I wasn't confident on purchasing fuel from the black market which is a common thing in the area.
From TSR you take the highway and at Angamaly you deviate to Perumbavoor and then head on to Suryanelli via Kothamangalam.
You'll know you've reached Bison Valley when the incline starts to get challenging, at the time of climbing I was seriously considering riding a pushrod up the valley nothing beats the pleasure of thumping up a long and progressive incline.
I've had the fortune of riding pillion on a CI Bullet a few years ago, while riding to Brimore Estate, TVM.
The motorcycle was lazily thumping at final drive, we could feel every cycle of the crank and the motorcycle was not even stressed hauling our weights uphill, if that's not character then I doubt what else is.
EDIT:
Almost forgot, do inspect your intake manifolds, especially the one between the carburetor and the air filter box, I've noticed them to be wonky as a result they come off easily and the rider would not even notice unless hauling load as the motorcycle runs fine with a little more air than normal without displaying any unusual signs on normal riding.
