Team-BHP > Motorbikes
Old 15th February 2017, 09:16   #16
Mr.Boss's Avatar
Thanked: 7,585 Times
Re: Black Streak Tale - TVS Scooty Streak Ownership Review
Originally Posted by DWind View Post
I believe the grill on front panel is also a dealer accessory.
You are right. Thanks for pointing out
1. The OE Battery tends to loose juice quickly if not used frequently. We had to change to up-rated / better branded battery. We even had an issue with one of the fuses which caused the bike to not start even when kick-starting it as the circuit was not closed.
2. The Mirror adjustments were either too tight (left) or too loose (right ones). I never got a perfect setting while riding. My wife does not complain about this Either the right mirror when it falls is perfect for her height or she does not use mirror altogether.
3. Not flood friendly. Over here in Chennai, as soon as the water level on the road reaches above 4-5 inches but well below the silencer, the clutch starts to slip causing the rider to raise the throttle to get decent traction.
100% agreed.
1) Amaron holds good (far better) than OE Amco. We had Amaron in Scooty Pep as 3rd replacement battery and never faced any issues even with very limited usage.
2) Adjustment range is very limited (same fate with Pep as well) One of my friend went for TVS Jupiter RVMs which has a decent range of adjustment (spoiling the looks)
3) I'm a victim myself
Mr.Boss is offline
Old 11th June 2017, 22:15   #17
Mr.Boss's Avatar
Originally Posted by Mr.Boss View Post
5k milestone
4 months later it's 5382 on odo now. Minimal running remains so minimal. Did only a couple of tank fills in this 4 months.
Mr.Boss is offline
Old 24th June 2017, 18:51   #18
Mr.Boss's Avatar
Switched to Roots wind tone horn (High tone only)
This portion is chopped to avoid rubbing against the plastic cover
Mr.Boss is offline
Old 19th April 2021, 11:32   #19
Mr.Boss's Avatar
Covid Lockdown hibernation update:
Scooter was left in hibernation for over a year and took a little DIY effort to bring her back to life
This was the condition after 1 year hibernation
Drained the fuel and cleaned the carburetor
Air filter, engine oil & battery changed
A quick wash
And finally she is ready to roll
Mr.Boss is offline   (1) Thanks
Old 21st June 2023, 15:59   #20
Hello,
Wanted to know if non-TVS/Streak rear view mirrors fit my Scooty Streak. I am asking this because one of the mirrors has become loose and does not hold still, I have taken it to the local mechanic and service center, unfortunately, both of them could not fix it and asked me to replace the mirror. I went and checked TVS Spare parts, and they informed that the spare parts won't be available for this vehicle and asked me to buy the Honda Activa's mirror or any third party.
silhouette-r is offline
Old 22nd June 2023, 09:03   #21
Mr.Boss's Avatar
Yes, most of the OE mirrors are direct fit. If you are going for aftermarket ones, check if the thread is M10 (Few aftermarket mirrors come with different thread sizes, which will require additional adaptors)
