Re: Retrofitting CBS (combined braking system)? IMO, retrofitting CBS on a motorcycle or scooter that did not originally have it ranges from difficult to almost impossible.
The easiest way would be to have a vehicle that did not have CBS but it is now available on the latest production model.
The brake parts on the new model may fit onto the old model with little problem (or they may not fit at all if the supporting parts are not designed for them).
If the new model is not equipped with CBS and replacement parts are not available the problem becomes more involved.
First, the only moderately easy design to modify must have hydraulic brakes on both the front and rear wheel.
Only with a hydraulic brake system can the pressure from the master cylinder be directed equally to both wheels at the same time.
This, a hydraulic system will do automatically as long as suitable high pressure hoses are connected to the master cylinder and both wheels brake pistons.
(Fluid pressure in a closed hydraulic system will be at the same pressure everywhere provided modulators or regulators are not between the master cylinder and the brakes).
For this hydraulic system to work properly as a braking system, the sizes of the front and rear brake pistons must be sized correctly.
The size of the front brake should apply approximately 80-85 percent of the braking force with the rear brake applying approximately 15 to 20 percent.
If existing parts are taken from several different motorcycles the likely combination of brake parts being correct is very unlikely.
What if the front end has a disk brake and the rear end has a mechanical drum brake?
A real problem exists with this setup. The two brakes receive their energy in two totally different ways.
The disk brake relies on hydraulic pressure. The drum brake relies on a force that is applied to a steel cable or rod.
The only solution that comes to mind is to design a hydraulic piston connected to the master cylinder that will provide force to the rear brakes steel cable or rod.
To the best of my knowledge, such a thing does not exist unless someone wants to try to cobble up something. (This hydraulic piston must be sized to provide exactly the right amount of force).
Cobbled up somethings do not have the engineering expertise needed for a design that involves a life/death situation.
My first recommendation for anyone seriously wanting a CBS system is to find a motorcycle or scooter that already has it and buy the machine.
Only then will you know that the proper engineering went into the design.
My second recommendation is to learn how to use both brakes on your existing machine properly.
Properly in this case means use the front brake to develop 80-90 percent of your braking and the rear brake to provide the remaining 10-20 percent.
Actually, IMO, this is the best solution.
A CBS system has no way of knowing what the riding conditions are so it must be designed to meet the average conditions. This is fine as long as the actual conditions are average, like a smooth, dry, slightly dusty road.
As soon as the riding conditions are not average, like a wet, muddy, sandy or potholed road, only the rider knows this and by using his/her knowledge they will adjust the amount of front and rear brake force needed at that moment to safely stop the machine.
(Under wet, muddy conditions the best braking combination may be 20-30 percent front and 70-80 percent rear to prevent locking up the front wheel.
The CBS system won't know this at the time.)
