Team-BHP > Motorbikes
Old 15th November 2019, 09:11   #1096
cataclysm's Avatar
Thanked: 552 Times
re: The 1st-gen Royal Enfield Himalayan thread!
Originally Posted by mail4ajo View Post
Did you have to upgrade the power cable?
No need to upgrade the power cable. HDT Customs guy also made a video on this.
cataclysm is offline   (2) Thanks
Old 15th November 2019, 09:27   #1097
rakesh_r's Avatar
Thanked: 3,378 Times
Originally Posted by VijayAnand1 View Post
Ajo, I am using the NGK IRIDIUM plugs only and not the PowerTronics. The plug model for the Himma is CR9EIX.
Cheers!
VJ
I presume this is the plug link you have recommended. Can I buy the plug online from Amazon?
rakesh_r is online now   (1) Thanks
Old 15th November 2019, 14:11   #1098
VijayAnand1's Avatar
Thanked: 3,505 Times
Thanks, I saw some places refer to CR8EIX as the model. Did you have to upgrade the power cable?
Nopes! I didn't upgrade my power cable, sticking with stock cable and just the plug alone. If you're in the Americas, you can try your hands on NGK racing cables, red ones, and install with the plug, you will definitely have improvement in performance.
That is the one, right.
Cheers!
VJ
VijayAnand1 is offline   (1) Thanks
Old 17th November 2019, 21:54   #1099
Thanked: 1,002 Times
slight OT - if thats allowed:
talking about Spark Plugs :
https://ngksparkplugs.com/en/resourc...um-spark-plugs
for my K-VerSys, the manual states stock as: (a) NGK CR9EIA-9 (retails for INR 2000), wherein another compatible is (b) NGK CR9EIX (retails for INR 600).
The difference, as per above article is :
Both above have small difference in the structure, (a - stock) slightly better because of bit projected tip than putting the electrode gap deeper in center of combustion chamber, and their difference in usage period.
However, both (a) & (b) will work, and the manual states gap needed 0.8mm to 0.9mm.
regards,
pcpranav is offline
Old 18th November 2019, 21:45   #1100
ArizonaJim's Avatar
Thanked: 2,844 Times
My first thought is to go with the least expensive spark plug.
IMO, there's not enough difference between the two spark plugs you mention to justify any large difference in price.
That said, at least one place on the web warns of fake NGK CR9EIX spark plugs on the market. Here's a link to the article which explains how to recognize the difference between a real NGK plug and the fake one.
https://www.driven2automotive.com/bl...rk-plugs-2018/
ArizonaJim is offline   (5) Thanks
Old 18th November 2019, 22:11   #1101
Thanked: 6,657 Times
Now that's some commonsense that's not so common these days.
You really got to wonder what people are smoking these days to believe that an Iridium plug would extract commendable performance from a lazy motor with 9.5:1 CR, and that too a bone stock motor for which the manufacturer recommends otherwise.
Peace.
A.P.
ashwinprakas is offline   (2) Thanks
Old 22nd November 2019, 20:46   #1102
mail4ajo's Avatar
Thanked: 336 Times
Has anyone found a strengthened rear luggage rack? I see Trek N Ride makes one, but the weld quality looks bad. But its cheap. Any other alternatives?
mail4ajo is offline
Old 23rd November 2019, 22:18   #1103
rakesh_r's Avatar
I am using one from Zana, feels sturdy.
Old 23rd November 2019, 23:30   #1104
mail4ajo's Avatar
Thanked: 336 Times
Can you please post a pic and also can you install the pannier racks with the rear luggage unit?
mail4ajo is offline   (2) Thanks
Old 25th November 2019, 09:48   #1105
rakesh_r's Avatar
Zana has two types of racks, one with the base plate to mount the top box and one without the base plate. I went for the latter.
Old 1st December 2019, 13:01   #1106
bblost's Avatar
Thanked: 17,559 Times
Did a short breakfast run for about 180 odd Kilometres.
Very happy that I have changed to the touring seat. It's a lot now comfortable than the original seat.
bblost is offline   (6) Thanks
Old 2nd December 2019, 11:59   #1107
satishv1987's Avatar
Thanked: 343 Times
I could not find the touring seat on the RE online catalog. I accessed the link you'd shared in an earlier post and it returned a 404. Has the seat been discontinued or is available only via the showrooms?
EDIT : I managed to dig a little deeper and found it elsewhere in the catalog.
https://www.royalenfield.com/in/en/gma/1990208/
Last edited by satishv1987 : 2nd December 2019 at 12:01. Reason: Added additional information
satishv1987 is offline
Old 2nd December 2019, 21:11   #1108
Thanked: 25 Times
It's available at showrooms. Just call up your showroom or the nearest one, they will confirm availability. I did same. They had 2 units, I went and picked up one. Certainly better than stock version. Yet to test it over 100kms at a stretch.
kunwar.g is offline
Old 19th December 2019, 00:47   #1109
True AJ. It's just those little perks of mods that help the bike. Nevertheless, there isn't gonna be a jump in HP per se but definitely yes a little improvement can be felt and trust me that does make a teeny weeny difference. The stock plug UR5CC is extremely cheaped out, any more cheaper and she wouldn't even fire.
Cheers!
VJ
Old 21st December 2019, 00:23   #1110
Ketan's Avatar
Thanked: 452 Times
I asked a showroom close to me, they seem to have it but the next weekend I was going to a longish ride so couldnt pick it up with that short notice. I shall check again and need to get this if its really making the difference before my Munnar ride in couple weeks.
Cheers!
VJ
I've got the NGK spark plug, replaced it and went for a 250kms ride on a weekend 10 days back, I felt the misfire (although I noticed it less frequently) and some irregular firing (this I noticed more frequently) seems to have got better now, I see stable firing and power delivery even at the low rpm and felt its better! I'm thinking if I need to change the power cable as well?
I was thinking of adding K&N as well, can someone tell me if I have to make any other adjustment if I replace the air filter with that one from K&N? I saw some folks doing it for Carbed version, mine is FI so just wondering if I have to make any other changes?
I was also looking at the exhaust by and then powertronics device, read some review where it really changes the character of the motorcycle, makes the engine really peppy and you feel its a different bike while accelerating from low to high RPM. Although its not going to help much in bumping up the top speed or motorway speeds, but getting there becomes really fun with powertrocnis.
Again, I'm holing off on those heavy performance mods while I'm contemplating to get the KTM 390 Adv and may get convinced to sell my Machismo 500 and Himalayan while I do that. I wish I dont sell them but maintaining more than one mo-bike is becoming a big project for me and hence in the dilemma!
Ketan is offline
