Team-BHP > Motorbikes
Old 18th August 2006, 18:47   #1
rranjith_kum's Avatar
Thanked: 21 Times
help - to buy an RX100 or RX135
Hi.... I m planning to buy a RX100 or RX135 ... i need some of your advice to wat all to look out for ... i want to buy one that is in good condition and gives good ride ... pretty much unmodified version.... pls help
Ranjith
rranjith_kum is offline
Old 19th August 2006, 03:35   #2
Pretty hard to find an unmodified RX. But look around, might have to look hard to find one in pristine condition. Suggest the RX135 5 Speed. Nothing against the RX 100 but would suggest the 135 5 speed more.
TheCockroach is offline
Old 19th August 2006, 19:43   #3
Thanked: 21 Times
hi... Actually why are you suggesting the RX135 5 speed more ...is there any specific reason... also is there any difference in the performance when comparing RXZ and RX135...
Old 20th August 2006, 03:12   #4
There is no replacement for displacement. 100cc vs 135cc, obvious choice. More power, taller gearing, 5 cogs. Take your pick.
"comparing RXZ and RX135..."
No difference, just cosmetically different.
Old 20th August 2006, 10:06   #5
mail4ajo's Avatar
Thanked: 332 Times
Cockroach is certainly right. But, I would prefer a RX100 to a RX135 for its sweet exhaust note and legendry following. But couldnt get a decently maintained one, hence grabbed a RX135.
Well, while buying a RX series, you need to look out for all stuff that you would do for a used bike. Special things you need to see:
1. Check for the oil pump on the right side of the engine. Most used bike wont have this. Mixing oil in the tank is not preffered. See if 2T is maintained in the oil compartment on the left.
2. Although, the RX series engines can take good thrashing, do care to check them. A look a the spark plugs will tell you the story. There is a plug story reading guide that will tell you whats happening in the engine.
3. Check the gearoil level and colour. Badly maintained bikes will have dark and worn out gearoil. This is neglected by many users. This affects gear shifting and wears out the gear teeth.
4. Check shock absorbers - Front - any oil deposits on the fork will indicate signs of worn out oil seals. check operation. Rear shocks should operate fine.
5. Other stuff to inspect include chain set, wheel bearings, electricals, cables etc.
Maintain the bike well and it will excite you with awesome performance.
mail4ajo is offline
Old 20th August 2006, 21:49   #6
rohitbagai's Avatar
Thanked: 259 Times
the RXZ with 4-Speed has problems in starting while RX135 dont have starting problems.
rohitbagai is offline
Old 21st August 2006, 19:23   #7
Thanked: 21 Times
One of my friend mentioned that RXZ produces more power. Is the change merely cosmetic.....
Old 21st August 2006, 23:37   #8
Nothing as such, I own an RXZ 4 speed. Haven't encountered any starting problems till date.
Old 21st August 2006, 23:40   #9
Yes it is only cosmetic. RX135 and RXZ 4 speeds is supposed to make 12 bhp. The RX135 and RXZ 5 speeds make 14 bhp.
Old 22nd August 2006, 03:30   #10
rohitbagai's Avatar
Thanked: 259 Times
Well at least 5 of my friends had RXZ and I had RXG as well as RX100. The RXZ-G needs more kicks to start even after 4-5 hours stand still. My RX100 starts in First kick even after one month Hault. I know exactly why that happens. It’s to do with the size of clutch drum which was rectified in RX135 5 speed. I was called up at escorts to explain the problem way back. I don’t remember exact year. I took my RXG with RX100’s clutch fitted and it was easy for them to understand. They acknowledged and problem was solved in the next lot.
Old 22nd August 2006, 22:00   #11
Thanked: 21 Times
I actually never knew that there is so many models in the RX series ... RXG- quiet unheard of ... could anyone please post the model's history...
Old 22nd August 2006, 22:14   #12
OK. I'll take your word for it.
Old 23rd August 2006, 00:01   #13
satyamenon's Avatar
@Rohit, This sounds interesting. Could you explain the logic behind the fix?
satyamenon is offline
Old 30th October 2006, 09:58   #14
5-spd v/s 4-spd gear ratio question
Hello ppl
I hav an RX-135 2004 make 4-spd bike
I had fitted a stock 5-spd (14bhp) Barrel
The max speed i could do on it was 110 to 115kmph on a long straight
The only other mod was a modded SILENCER for free flow exhaust (INBUILT... It's called inbuilt in Bangalore and Mysore)
The stock 5 spd bike as per the company profile has to do a 110
so now my question arises
1) Is the final gear ratio of a 5-spd and a 4-spd same?
2) Is it really worth fitting a 5-spd gearbox on my bike?
Finance is not a concern and I know mech's in Bangalore who can get it done for me
and if possible can anyone gimme the gear ratio's for both the 4-spd and 5-spd, it would help me decide whether to go for it or not
iamdstig is offline
Old 30th October 2006, 11:50   #15
jkdas's Avatar
Thanked: 1,492 Times
get a RXZ 5speed, a well maintained one would cost 30-35k at TVM
jkdas is offline
