re: OMG! 3rd RX at home - 1998 Yamaha RX135 4S. EDIT: Restoration completed! Quote:
Originally Posted by Mr.Boss But this involves chopping the frame rear end and I'm bit concerned with the same. |
I certainly would suggest you do not modify the frame. Instead of a single seat which ends at the rear shock-absorber, get a longer cafe racer seat with a rear seat cowl to cover up the pillion seat.
If you go ahead and chop the frame, there are two potential problems:
(1) You need to revert to an original frame for some reason - RTO creating issues with fitness renewal or you have to sell off the bike or anything at all. Getting new frames from Yamaha is becoming more and more difficult and the supply may soon dry up.
(2) Rigidity of the frame gets compromised - the RX frame is very light and once you chop an area, especially close to the rear suspension mount which sees a lot of movement and resultant forces, it may create too much flex or worst case, break your frame.
Why not go for something like this? Just search for cafe racer images on Google and you will get a lot of ideas for your project. Looking forward to the progress and the end result! |
