Re: The Duke of Direwolves - Lisbeth, my KTM Duke 200 Went to Motospark today to get my brake pads changed, came out with mixed feelings. The workmanship is ok-ok, nothing much to gauge since it is a standard procedure, but couple of points I did not like:
1. The guy (Aslam or something similar, forgot the name seems to be a partner) took my bike and first thing he told me that the oil seal at the drive shaft is broke and oil is leaking. I tried to explain that I cleaned and lubed the bike today morning and the excess oil dripping is probably the chain lube, but his response was its my line of work, I know it. Ok, I let it slide and asked him to get it checked to make sure if it is a leak. Later I mentioned to him that the reason why I wanted to double check is that I checked the oil level today also and it was not low so he gave me some gyan on how to correctly check the oil level. I agreed and to be on safer side, I asked him to check it he said he will but did not happen.
2. The mechanic emptied a whole bottle of worth brake clean spray (small bottle) to clean the caliper. He cleaned the inside, then proceeded to spray the cleaner on the disk, then washed the outside of the caliper, sprayed it inside again, then sprayed it outside again, then used it to clean his hand in short, made sure that the whole bottle is used. I find it really useless. I can understand they are using it to clean the muck out from the caliper but misusing it so that they finish the bottle and bill it to me a BIG thumbs down from my side.
3. After the pads were changed, the mech said the brake lever action is fine, but the owner guy insisted that there is some air inside and it needs to be bled. I tried but could not find any problem, but still I asked to go ahead. They bled the oil and filled new oil (TVS Girling) and while billing, he asked the mech if he used TVS or Maxima. If there was a choice, I would have gone with Maxima. So, a minor thumbs down for not informing me the choices available. The quality of the bleed was also so-so.
My main aim was to see if they are good enough for me to get my bike serviced and I realised I will be much happy with Highlander. So, not going back to Motospark in all probability.
PS: They did not charge any labor and billed only the parts, but I would have been much happier if they billed labor and judiciously used the consumables.
--Anoop |
