Originally Posted by ashwinprakas I would suggest that you first diagnose where the coolant is vanishing to, if your head gasket is at fault then you'll notice emulsification in engine oil and white smoke from exhaust which would be more prominent at high revs.
If the head-gasket is not at fault then inspect the plumbing, every single bit of it and it wont hurt to proactively change them cause better spend a few hundreds doing that rather than spend thousands recovering from a seizure. |
If he knows from where the coolant is evaporating or vanishing from, the user wouldn't have asked the question in the first place, don't you think
Just kidding.
Originally Posted by ShashankM ...Recently, I had my ride serviced, it was first paid service. After the service I discovered that coolant level has been going down, I got it topped couple of times but the level keeps going down. Water pump and water pump seal was changed as part of first trobleshooting session recently. Still the problem persists. After a ride of approx 150 km the level went down by 5 to 6 mm. I nčed to go for another round of diagnosis now. From my side,
I have gone through some of the earlier discussions on this forum and checked couple of points.
1. Engine oil colour - Got it checked by technician who mentioned the colour is ok and do not see any engine oil - coolant mix problem. He checked oil colour at the drainage plug point.
Need some expert suggestion on what should I do next as Service centre guys are in trial and error mode. |
From your above post,
Though the mechanic checked the oil, the issue can be more sinister than it actually seems.
2. Frothing - I dont see any milky / white frothing from the oil observing glass. However, I do see dark brown froth inmediately after ride but it disappears when the bike is stand still for 15 seconds with engine running. Technician told me that, it could be because of water/water vapour but not coolant. I have attached a picture of the froth.
The mild frothing that you see is of no worry. Most Dukes do the same, but once the engine is warmed up, it should disappear. That layer of froth over the oil that you see is because of the engine oil being whipped by the clutch which momentarily causes to froth and should disappear once the engine is warmed up. If the froth layer stays irrespective of the engine's temperature condition, say after a long ride, we have a leaky coolant system.
3. Coolant leakage - I tried to check if there are any signs of visible coolant leakage but could not find any.
Sometimes mild coolant leakage can vaporize due to the engine heat when riding, or coolant leaks happen when the system is pressurized, which happens once the engine is on the move and a mild leak can go unnoticed. Just Murphy's Law.
4. Burnt coolant - There is no sweet smell of burnt coolant.
Burnt coolant smell would be similar to caramelized sugar, it can be confusing at time, and foul smelling at the same time. It's not always the right way to determine a coolant leak.
5. Exhaust check - Checked exhaust for any oil traces but it is clean and dry. Just 'traces' of black soot.
Again, unless it's a leak that is significant, coolant will almost instantly vaporize when it touches the exhaust system, due to the heat and all you'll be able to see touch and see is mild to medium carbon soot.
6. Radiator grill - I have attached a pic of radiator grill. Technician did not mention any problem with the grill so far but I do see linings bent. Can this be the cause of coolant disappearing?
Though your radiator fins are bent, the effective surface area is still in good shape, so there is absolutely nothing to worry. Your cooling efficiency won't take a hit or is it a cause of your coolant leak, unless there is a leak in the radiator itself or the tubes or the coolant reservoir
There are 2 more points that I want to mention related to the last paid service -
1. Some oil seepage was there from the top of the engine. Some bolt was tightened to fix this. The oil seepage thing was fixed but I felt some sort of 'tighness' in the engine after this.
2. When the bike was started for the first time after the wash, there was 'white smoke' from exhaust. It disappeared when the service supervisor revved the engine. I have checked for white smoke again during the cold start but I do not see any smoke, white or blue.
Most Dukes do weep some amount of oil from the valve cover. Usually, the SVC just tightens the valve cover and/or replace the gasket and it arrests the leak, it's become a trait of the motorcycle itself, these days. It has nothing to do with the engine performance.
The white smoke that you see can be of two types, either it's a water vapor which appears like steam and vanishes like steam. The other is a thick smelly smoke which comes at times during early morning starts or after wash due to rix mixture provided by the EFI itself which again is normal and this smoke vanishes once the engine is heated up.
If the white smoke appears after the engine has warmed up or after a ride, or when you rev the engine after a ride, we have a faulty piston ring set and or valve stem oil seal. But that's for another day.
Hope it helps!
Cheers!
VJ
